Volks AutosMonster Motorsport
Page 1 of 2 12 LastLast
Results 1 to 40 of 42
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Visit s3 Hoggy's Instagram Channel
    Haldex not working?
    Everything with my car has been working sweet as a nut until yesterday. Basicly I put my foot down and get a lot of wheelspin with no signs of the haldex helping out?
    It's always been serviced on time (the haldex) with the last oil and filter change 4,000 miles ago. I don't experience any other symptoms like others have with thee point turns ect, also my car has only done 52,000 miles.
    Anybody have Ideas as to why this might be happening?
    Thanks for reading,
    Matt
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
    alijames's Avatar
    Feb 2008
    Oxford
    1,017
    Matt, The obvious one is the fuse. Failing that, best way forward would be a Vag-com start to the investigation.
    I've got an eBay serial one which works fine on 409.1 on my laptop. Sadly I'm away from tonight, otherwise could have brought it into Oxford this morning...
    Cheers,
    Alistair
    "Why don't you listen to something really classical, like Mozart, Mendelssohn or Motorhead?"
    Arnold Rimmer, 1988
    Commuting & Weekend Fun:
    Yamaha YZF-1000R Thunder Ace in Blue/Black
    Practical Alternative (Still fun though!!):
    S3 2002/51 AMK Silver, Symphony II + Bose + xCarLink + AndyMac Stealth Sub, Metallic Mirrors, Heated Black Leather, Cruise control.
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    best to scan
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Quote Originally Posted by alijames View Post
    Cheers,
    Ah well mate no worries, I'll hopefully be getting it plugged in tonite if the garage round the corner will fit me in,
    2002 S3 REVO
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Just phoned the garage and they can't fit me in for two weeks! Even for a diagnostics check! Think I'm going to buy an EBay lead and see if any thing shows up?
    2002 S3 REVO
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    eBay cable will do
    colicabcadam
    could also be the hand brake switch, if this is fooked, it'll stop the haldex working
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Quote Originally Posted by colicabcadam View Post
    Would this not cause the handbrake light to be on all the time mate?
    2002 S3 REVO
    colicabcadam
    Quote Originally Posted by s3 Hoggy View Post
    in THEORY yes
    alijames's Avatar
    Feb 2008
    Oxford
    1,017
    Matt. if you are getting an eBay lead, I would advise getting a serial one, rather than a USB one. I tried 3 USB ones and none of them worked. 1st Serial one worked perfectly and still does..
    Cheers,
    Alistair
    Arnold Rimmer, 1988
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,062
    Dude, is there nobody else nearby that can do a scan for you??
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Dude, check the fuse as mentioned as first port of call. It's fuse 31. Top fuse in the middle column. Will be orange IIRC.
    Next, have a look at the plug on the diff. I've seen 2 separate S3s where this has become corroded inside and needed repair.
    If you are not getting any Haldex, then expect an error code along these lines:
    Controller: 8N0 907 379 E
    Component: ESP 20 CAN V005
    Coding: 18448
    Shop #: WSC 01236
    1 Fault Found:
    01324 - Control Module for All Wheel Drive (J492)
    49-00 - No Communications
    Homer Simpson
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Thanks for your help guys,
    Checked the fuse, looked fine but I still replaced it. That didn't sort it worth a try.
    Next I will be checking the plug on the diff as Welly said (will have t wait till Saturday now as no light)
    I will be ordering a lead tonight
    Thanks for everyones help so far,
    Matt
    2002 S3 REVO
    colicabcadam
    get the wheels off the ground, see if they all spin when you put it in gear, if thye do, i'd say it's a sensor problem (ie 5% of power is going to the wheels, so the heldex isnt broke)
    Oct 2010
    Hampshire
    294
    Isn't there an earth strap that corrodes back there? Vaguely remember reading about it but may have not been onto the haldex...
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Where abouts is this mate? I had a quick look in the dark with a torch but its bloody cold and windy so I've come back inside! also where abouts is the earth strap?
    2002 S3 REVO
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,195
    Keep us posted with this one Hoggy, hope you get it sorted.
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Quote Originally Posted by The Doctor View Post
    Will do pal
    2002 S3 REVO
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    Earth strap on the rear diff.
    mhr1972's Avatar
    Nov 2004
    37
    I had this last year and it was down to my earthing strap from body to rear diff/haldex.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by SamiG View Post
    yes worth a check....
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Cheers guys I'll have a look hopefully tonite if It's still light, can any body confirm which side the earth strap is on?
    2002 S3 REVO
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    I have found this, could it be the Earth strap? It's bolted from the drive shaft to the underside of the spare wheel well. As you can see it's pretty fecked! Snapped in half
    2002 S3 REVO
    alijames's Avatar
    Feb 2008
    Oxford
    1,017
    Yup. That'd do it...
    Cheers,
    Alistair
    Arnold Rimmer, 1988
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Right I fixed the strap, I'll be taking her for a test drive in the morning, Fingers crossed it's sorted!
    2002 S3 REVO
    Oct 2010
    Port Glasgow
    283
    hope it works Hoggy
  28. #27
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    bad news the strap doesnt seem to have fixed the problem,
    I have found a fault code though, does anybody know what this might be? my repair on the strap wasnt fantastic as I was rushing so might have another look at that in the morning?
    VCDS-Lite Version: Release 1.0
    Saturday, 13 November 2010, 17:09:28:0
    Control Module Part Number: 02D 900 554 C
    Component and/or Version: HALDEX LSC ECC 0009
    Software Coding:
    Work Shop Code:
    1 Fault Found:
    65535 - Internal Control Module Memory Error
    00-00 - -
    Any help would be great,
    Cheers Matt
    2002 S3 REVO
  29. #28
    Oct 2010
    Hampshire
    294
    I thought I'd check the earth strap today while I was changing my oils. I have a pre facelift model 1999 and it does not have an earth strap at all...
  30. #29
    JS1500's Avatar
    Howdy
    Sep 2009
    Granite house, Granite City.
    1,167
    New strap is only summin like Ł13, IIRC.
    2001 Audi RS4 2.7 Bi-Turbo - Nogaro Blue
    1975 MG Midget 1500 - Tahiti Blue
    2003 Audi S3 - Dolphin Grey; SOLD!
  31. #30
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    Definitely that earth. Get a new one from Audi.
  32. #31
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Does anyone know if the earth souls be bolted to the chasis and the spare wheel well? As I've only bolted it back to the wheel well
    2002 S3 REVO
  33. #32
    Mar 2006
    lincolnshire
    254
    did you find the problem in the end s3?
  34. #33
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Not yet mate but everything seems to be pointing towards the haldex controller, havnt got s lot of time to get it sorted at the moment, as soon as anything changes I'll update this thread
    2002 S3 REVO
  35. #34
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    WooooooooooooooHooooooooooooo! Fitted a second hand haldex controller this morning and now I have my 4wd back! Big thankyou to Rob (aka Cecilthesausage) for the part
    2002 S3 REVO
  36. #35
    Feb 2011
    southampton
    229
    Hi mate was this easy to fit..
  37. #36
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    It wasn't that hard as such, I done it on ramps as you are best off with as much room as possible. It's just a case of removing the cover plate that protects the haldex plug, then unplug it there and also unplug the haldex at the controller itself, two Allen bolts hold the controller on undo these and your away! You loose a spoon full of oil. Then just repeat in reverse to fit the new one, holding the gasket in place is the biggest pain in the arse! I would reccomend getting the top screw in first a couple of turns then the bottom ensuring you still have the gasket it the right place. Tighten it all up and reconnect the plugs and your there.
    So yeah it's not a difficult job just fiddly and I kept getting crap in my eyes!
    2002 S3 REVO
  38. #37
    Feb 2011
    southampton
    229
    Cool cheers mate as I will need to get hold of one soon and fit it..
  39. #38
    cecilthesausage's Avatar
    ...It's Never Finished...
    Jul 2010
    Teesside
    933
    No bother mate glad to help nothing worse than a sick S3
  40. #39
    Jan 2011
    6
    how much and where do you find these contol units
  41. #40
    Jul 2010
    Teesside
    933
    I sold mine to Hoggy for Ł100 pound which I think is about the going rate.... Dont know how often they come up though bud
