DNA TuningW8 Performance
Results 1 to 25 of 25
    S3 TAM's Avatar
    S3 TAM is offline Hole in pocket getting bigger!
    Oct 2009
    London & Hertfordshire
    474
    Post Thanks / Like
    Cam adjuster Gasket, Cam Cover Paint (Pics)
    Hi All,
    I have a slight leak from the cam adjuster gasket, so I thought I would replace it while i'm there might as well do the cam cover gasket. Anyway last night I managed to get the cam cover off give it a good clean up and powder coated it black.
    but i'm stuck,
    How do I get to the cam adjuster gasket is there a easy way of doing it. Elsawin wants me to start moving the timing belt so the vavles are in a certain position then move the cams in to another position and remove the chain and lift the assembly out. can I do this with out removing the chain.....
    Also do you think i should put a coat of Clear Lacquer on top of the powder coat for easy of cleaning later on?
    any help will be great. here are some pics so far more to come.
    Revo Stage 2 with all the Gear
    BHP = 274 / Torque = 293
    FOR SALE
    STANDARD DOWNPIPE & CAT'S
    STANDARD AIRBOX
    FOG LIGHTS
    PM ME
    Google Adsense Circuit advertisement
    Advertising world
    Westy's Avatar
    Westy is offline K04 Murderer!
    Dec 2008
    Hertfordshire, sometimes Cambridgeshire
    11,365
    Post Thanks / Like
    I knew it wasn't going to be as simple as you thought it would be haha.
    Looking good though mate.
    WANTED - Rocker Cover (push down coil pack type)
    PM me
    Dani_B19's Avatar
    Dani_B19 is offline Audi-sports own special child.
    Nov 2008
    Barnsley
    4,973
    Post Thanks / Like
    when is anything ever simple with these cars?
    Imteyaz is offline Crunching gears....
    Oct 2008
    Warwickshire
    477
    Post Thanks / Like
    I take it you mean the VVT gasket? If it is that, you need to get hold of VAG Tool 3366, this tool will allow you to gently lift the metal gasket and half moon gasket and replace them (it gives you about 5-7mm to play with!). Tool is available to buy from TPS or here: Laser 4581 VAG Vw Audi Seat Camshaft Retaining Tool
    The gaskets look like:
    Part no: 058 198 217
    I can't fine the 'How To' on it at the minute but do a quick search for "VVT Tensioner" and I'm sure you will come across it...
    Imteyaz.
    Welly's Avatar
    Welly is offline 8L S3 - Badger 5 Edition
    Aug 2009
    Gloucestershire
    9,907
    Post Thanks / Like
    LOL, how weird, I did my spare one the EXACT same colour on Sunday! I'll post some pics as well when I get home.
    "All right, let's not panic. I'll make the money by selling one of my livers. I can get by with one." Homer Simpson
    Welly & Bumble
    FP Green - 411 BHP/330 LBFT
    Badger 5 Edition....
    S3 TAM's Avatar
    Oct 2009
    474
    Post Thanks / Like
    Quote Originally Posted by Imteyaz View Post
    Yes this is exactly what i'm trying to replace. now i know the correct terminology I might be able to find it.
    FOR SALE
    STANDARD AIRBOX
    FOG LIGHTS
    PM ME
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    4,973
    Post Thanks / Like
    Do the non vvt engines have these gaskets or is it just the later vvt models? Its just i need to do my rocker cover gasket too.
    Welly's Avatar
    Aug 2009
    Gloucestershire
    9,907
    Post Thanks / Like
    They all have them mate, it sits under the timing chain tensioner. The non VVT models still have the tensioner, just a different type. They still have the gasket.
    Welly & Bumble
    Oct 2008
    Warwickshire
    477
    Post Thanks / Like
    I wish I could help you there mate, unfortunately I don't have a clue about the non VVT engines (AGU?). I'm sure somebody else will have the right info for you and will post here soon....
    Thinking about it, the cam chain will always be there to connect the two cam together (whether the VVT unit is or not) so I would imagine that the gaskets would also be in place... again, I'm only guessing that this is the case.
    Imteyaz.
    S3 Nattie's Avatar
    S3 Nattie is offline Quattro ist für sissies
    May 2009
    Cardiff
    1,600
    Post Thanks / Like
    For sale
    3" Downpipe and de cat (will be going on ebay soon)
    Autogauge boost gauge
    Chrome Audi Number plate surrounds
    PM for info.
    S3 TAM's Avatar
    Oct 2009
    474
    Post Thanks / Like
    Quote Originally Posted by S3 Nattie View Post
    Good find matey.
    FOR SALE
    STANDARD AIRBOX
    FOG LIGHTS
    PM ME
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    Post Thanks / Like
    If you have any problems report back and let us know. I have not long ago changed my VVT unit so pretty familiar with what you should do.
    Nathan
    For sale
    PM for info.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    4,973
    Post Thanks / Like
    Cool, cheers welly.
    S3 TAM's Avatar
    Oct 2009
    474
    Post Thanks / Like
    F~##*%$$%~#. Not happy.
    Right changing the the VVT Gasket was really easy I just undone the 4 x T30 torx screws highlighted in red. Then just lift the hole unit up about 2cm which gives you enough room to remove and replace the Gasket. don't forget to put a little sealant on the blue areas on the gasket.
    All done tighting the the nuts for the cam cover doing the last one and snap the hole nut and stud is in my hand. B***cks.
    What annoys me is I was using a torque wrench to the correct setting of 10nm. another trip to stealers for a new stud and nut....
    FOR SALE
    STANDARD AIRBOX
    FOG LIGHTS
    PM ME
    Westy's Avatar
    Dec 2008
    11,365
    Post Thanks / Like
    Mate you have the worse luck with cars!
    Hope it's not too much of a pain to get the stud out. This is why I hate tackling any jobs like this.
    PM me
    S3 TAM's Avatar
    Oct 2009
    474
    Post Thanks / Like
    Yeah tell me about it. Just need to get mole grips on the stud to get it out. Just ordered 9 new studs and nuts from audi £4.59. I can live with that. this will be tomorrow nights job. yey
    FOR SALE
    STANDARD AIRBOX
    FOG LIGHTS
    PM ME
    s3_kev's Avatar
    s3_kev is offline Stage2'd!!!!!!
    Feb 2008
    1,917
    Post Thanks / Like
    how even wierder i done mine a while ago exactly the same
    EURO S3 PT2
    S3 TAM's Avatar
    Oct 2009
    474
    Post Thanks / Like
    Quote Originally Posted by s3_kev View Post
    EURO S3 PT2
    I must be something in the air!!!
    FOR SALE
    STANDARD AIRBOX
    FOG LIGHTS
    PM ME
    S3 TAM's Avatar
    Oct 2009
    474
    Post Thanks / Like
    Right finally got round to sorting the car out this weekend. managed to sort the studs out ended up changing 3. also got myself a jetex cone filter and cleaned the TB. here are some pics.
    I think i'm gonna take the inlet mani off and powder coat that aswell.
    will post pics when done.
    FOR SALE
    STANDARD AIRBOX
    FOG LIGHTS
    PM ME
    s3tle is offline 1st Gear
    239
    Post Thanks / Like
    hi, what gasket sealant do you guys use?
    not sure i want to spend £16 on the tube from audi!!!
    S3 TAM's Avatar
    Oct 2009
    474
    Post Thanks / Like
    na don't. I got some stuff from my local car shop "chastillian" for about £6. Does the same job.
    FOR SALE
    STANDARD AIRBOX
    FOG LIGHTS
    PM ME
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    Post Thanks / Like
    I used some Locktight gasket sealant on my rocker cover gasket and sump and was only a couple of £ from Halfords.
    Nathan
    For sale
    PM for info.
    239
    Post Thanks / Like
    cheers guys, i'll pop into halfords
    Dazboss's Avatar
    Dazboss is offline Like A Thristy Dingo ;)
    Jul 2010
    West Midlands
    366
    Post Thanks / Like
    What paint did you use on the rocker cover / cam cover. Looks good might do mine.
    Audi A3 Quattro Sport 180bhp
    Pic's comimng soon !
    s3gazz is online now 3rd Gear
    Aug 2010
    bradford
    559
    Post Thanks / Like
    hi im going to do mine on saturday how long do ya think it will take to change both gaskets and the half moon
    im no good with messing with main parts of the engine but needs doing and got oil coming down the side
    of engine under the vvt valve and the half moon has popped out got a quote of 100 for it doing but think ill have a go mi sen
    got sealent both gaskets and the special tool plus alother tools that all i need tar
    gaz
    Silver s3 amk 2001, hybrid turbo, silicone hoses, forge 007p yellow spring, HID kit, 3 intercoolers, jetex filter, badger 5 3" tip, boost gauge, n249 bypass, 10 & 20 spacers, gloss black 18" alloys, xs 3" downpipe & de-cat, privae plate s333 gln, tints, liquid gauge, red dog bone mount, quick shifter, lcr brembo's, oil catch can, r32 arb, agu Largeport, genesis 550cc injectors, Milltek non res, kw v2 Coilovers, s3dave adjustable tie arms
    coming up
    xs manifold
    rods
