  2. Dismiss Notice
ZERO HOUR FOR AUDI H-TRON QUATTRO CONCEPT IN DETROIT
Sandra Jan 11, 2016
  1. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group S tronic Audi S3 quattro Platinum Supporter Audi Main Dealer
    31,533
    14,387
    Fuel cell-based e-quattro concept with zero global emissions capability marks another Audi milestone along the path towards future mobility
    • Fuel cell drive with additional lithium-ion battery for boosting and recuperation
    • Range of up to 372 miles (600km) on one tank of fuel, consumption around one kilogram of hydrogen per 62 miles (100km)
    • Refuelling takes approximately four minutes
    • Up to 110 kW (can be temporarily boosted by a 100 kW battery), 550 Nm of system torque, 0-62 mph in under seven seconds, 124 mph top speed
    • Electrified quattro layout with one electric motor front and rear
    • World’s largest in-car solar roof, up to 320 watts output or additional range of up to 620 miles (1,000km) per year
    Ingolstadt/Detroit, January 11, 2016 – The next step towards the long-term Audi goal of CO2-neutral mobility is being presented at this year’s NAIAS in Detroit in the form of the Audi h-tron quattro concept car – a striking SUV that uses a highly efficient fuel cell with an output of up to 110 kW, and a further on-demand power boost of 100 kW courtesy of a lightweight lithium-ion battery. The car can be fully refuelled with hydrogen in around four minutes, and is then ready to drive for up to 372 miles (600 km).
    Whether with purely battery-powered drive, plug-in hybrid, combustion engine or fuel cell – Audi has a command of all alternative drive technologies and offers tailor made solutions for its customers worldwide.
    In another major step, Audi will go into production with its new technologies for piloted driving and parking in 2017 along with the next generation of the luxury A8 saloon. The technology study already provides a glimpse of things to come.
    The Audi h‑tron quattro concept is closely related to the Audi e‑tron quattro concept, a purely electric SUV first showcased by the brand with the four rings at the 2015 Frankfurt Motor Show. Both are based on the second-generation modular
    longitudinal platform (MLB evo). This concept is especially flexible. For example, both cars use a virtually identical floor assembly despite their different technology.
    The Audi h‑tron quattro concept presents the fifth generation of fuel cell technology from Audi and Volkswagen. Lighter materials reduce the weight and improve performance, responsiveness, service life and efficiency. With an efficiency rating in excess of 60 percent, the fuel cell now surpasses any combustion engine. The “stack” comprising 330 individual cells is housed in the forward structure.
    The three hydrogen tanks are located beneath the passenger or luggage compartment but do not impinge on the interior. At a pressure of 700 bar, they store enough hydrogen for a range of up to 372 miles (600 km).
    Every tank is made up of several layers – the inner tank from gas-tight polyamide is wrapped in carbon fibre reinforced polymer (CFRP) and glass fibre reinforced polymer (GFRP). Like a car with a combustion engine, refueling takes about four minutes.
    Powerful booster: battery supplies up to 100 kW of power
    Ideally complementing the fuel cell that develops up to 110 kW, there is a compact lithium-ion battery designed for optimum power output. The battery, weighing less than 60 kilograms, is located beneath the passenger compartment to optimise the centre of gravity. It supplies up to 100 kW of power, ample for a temporary, forceful burst when accelerating. When the car is braked it stores the recovered energy. With 550 Nm (405.7 lb‑ft) of system torque, the Audi h‑tron quattro accelerates from 0 to 62 mph in less than seven seconds; its top speed is governed at 124 mph.
    The power from the fuel cell and the high-voltage battery drives two electric motors – one located on the front axle and with an output of 90 kW, the other on the rear axle and developing 140 kW. This concept makes the technology study an electrified quattro. An intelligent management system controls the interplay between them as appropriate for the situation, placing maximum emphasis on efficiency.
    A heat pump for the interior air conditioning and a large solar roof that generates up to 320 watts, equivalent to adding up to 620 miles (1,000 km) to the range annually, also boost efficiency.
    Zero global emissions with renewably produced hydrogen from the Audi e-gas facility in Werlte, Germany
    According to the New European Driving Cycle its fuel consumption is around one kilogram of hydrogen per 100 kilometres (62.1 miles). The Audi h-tron quattro concept achieves not merely zero local emissions, but zero global emissions if the hydrogen it runs on has been produced with green power. The brand with the four rings realises this at the Audi e-gas facility in North Germany.
    Since 2013 the world’s first power-to-gas plant has been using electricity generated by wind power to break water down into oxygen and hydrogen by electrolysis. In a further process, this gas reacts with CO2 to produce Audi e‑gas, or synthetic methane, for the Audi A3 g-tron and the A4 g-tron with CNG drive.
    Many customers are already using the e-gas fuel card to buy Audi e‑gas via the existing natural gas network at conventional CNG filling stations, enabling them to drive almost CO2-neutrally. But in future it will be possible to tap into this hydrogen source so that fuel cell cars can run on this climate-friendly fuel.
    Elegant and streamlined: the exterior
    The exterior design of the five-door technology study blends aesthetic appeal with aerodynamics. The Audi h‑tron quattro concept is 4.88 metres long and 1.93 metres wide but just 1.54 metres high. Its silhouette has an extremely flat greenhouse that tapers strongly toward the rear lends it the dynamic character of a coupé. The flowing shoulder line forms distinctive blister contours above the wheels in an expression of the electrified quattro drive. Wide wheel panels and angular side sills underscore the robust character of the car.
    The Cd value of 0.27 makes a major contribution to maximising range and efficiency. Aerodynamic elements down the flanks, on the underbody and at the rear improve the way air flows around the car at higher speeds. Cameras take the place of exterior mirrors, further enhancing aerodynamics and efficiency.
    The headlights of the technology study are divided into two sections. The upper section generates the light using the new, extremely high-resolution Matrix laser technology. The lower section, which corresponds to the slats in the Singleframe grille, forms the lighting signature.
    In addition to the white daytime running lights signature, flat OLED (organic light emitting diode) elements radiate a homogeneous blue light to the sides and upwards. Beneath the lights there are two large air intake slots.
    The sills incorporate a light strip in Matrix LED technology which again emits white light when the driver approaches the technology study with the remote control key. When the car is driving in piloted mode, this is signalled by blue horizontal lines lit up down its sides. Mirroring the front configuration, the rear lights likewise consist of two elements. Each of the upper zones features nine red OLED units that handle the tail light function, with three more below.
    Fusion of architecture and operating concept: the interior
    The package of the Audi h‑tron quattro concept enables a spacious, comfortable interior for four persons and 500 litres of luggage. Intelligent software provides assistance when loading up: two small sensors scan the items of luggage and display the optimum loading order on a monitor mounted on the rear cutout.
    The interior of the Audi h‑tron quattro concept has a light and open feel to it; its architecture merges harmoniously with the operating and display concept. The three large displays in front of the driver are designed using OLED technology – their wafer-thin films can take on virtually any shape. There are also two touch displays in addition to the central Audi virtual cockpit curved OLED. The driver controls the lights and the systems for piloted driving with the left one. The large display on the right is for managing media and navigation, and also displays the drive system’s operating statuses. The steering wheel serves as a further control level. Its spokes are equipped with contoured touch surfaces.
    The selector lever for the driving mode is mounted on the console of the centre tunnel. In front of it, there are two further OLED displays – for the drive status, the air conditioning and for freely programmable information functions. The front one offers gesture controls. The curved displays in the front section of the doors serve as digital exterior mirrors.
    The two rear passengers sit on comfortable individual seats. They can share data with the driver via the Audi tablets, which again have OLED displays. The tablets are designed as a mobile Rear Seat Entertainment system.
    Nerve centre for piloted driving: the zFAS
    The Audi h‑tron quattro concept comes equipped with all the technologies that the brand has developed for piloted driving – radar sensors, a new kind of video camera, ultrasonic sensors and a laser scanner.
    The driver assistance systems are now usually managed by spatially separate control units. In future, Audi will be implementing this function in a central domain architecture: All available sensor information is processed by a central driver assistance system (zFAS). It computes a complete model of the car’s surroundings in real time and makes this information available to the assistance systems and the piloted driving systems. They can assume driving tasks during parking or in stop-and-go traffic on motorways at speeds of up to 37 mph.
    Audi has been performing pioneering work in this domain for many years and in 2017 will be taking this technology into production for the first time ever with the next generation of its Audi A8 Saloon.
    htron.jpg htron 2.jpg htron 3.jpg htron 4.jpg htron 5.jpg htron 6.jpg htron 7.jpg htron 8.jpg
    Jake 61 and veeeight like this.
  2. Avatar
    snack-media
    Advertisement
  3. wolfie138
    wolfie138 Active Member
    508
    126
    43
    i like everything but the colour and that silly flat-bottom steering wheel.
    Sandra likes this.
