Yet another problem with my A3
MikeCrum1996 Mar 5, 2018
  1. MikeCrum1996
    MikeCrum1996 Member
    207
    17
    so lately my car has been making a loud clunking/popping sound from both side of my front suspension.. it’s happened since I installed coil overs (Fk) it never used to do it on my old suspension but it seems to be getting worse.
    It only happens if I full lock. If I full lock to right the right side clunks and same for left side.
    Any ideas?
    Much appreciated.
  2. Avatar
    Google AdSense Advertisement
  3. <tuffty/>
    22,417
    4,486
    I would imagine its the drive shaft hitting the anti roll bar... you will need shorter drop links
  4. MikeCrum1996
    MikeCrum1996 Member
    207
    17
    It doesn’t sound like it but I never thought of that.. it’s like a loud dong noise
  5. <tuffty/>
    22,417
    4,486
    lowering an A3 on coilovers almost always causes the drive shaft to hit the ARB... generally need adjustable drop links to over come the issue...
    There should be witness marks on the shaft from where its rubbed on the ARB
  6. MikeCrum1996
    MikeCrum1996 Member
    207
    17
    Yeah I’ve heard, only thing is the sound doesn’t get quieter or louder it’s always the same noise.. also it does it a lot more when cold don’t know how it affects it but it does.. but I’ve ordered some adjustable drop links hope it solves it
  7. MrAudi2017
    MrAudi2017 Member
    30
    Failing that check that the top mount bearing hasn't seized up.
  8. MikeCrum1996
    MikeCrum1996 Member
    207
    17
    I have Powerflex top mounts which come with coilovers they have been making this noise since putting coilovers on the noise has recently become more noticeable
  9. <tuffty/>
    22,417
    4,486
    I assume you fitted the bearings? Noise could be the springs winding up as the turn
  10. MikeCrum1996
    MikeCrum1996 Member
    207
    17
    Yeah it mainly happens when turning around or if I full lock it rarely makes noise driving in a straight line
  11. <tuffty/>
    22,417
    4,486
    Springs binding up... did you refit the OE top bearing with the top mounts?
  12. Avatar
  13. MikeCrum1996
    MikeCrum1996 Member
    207
    17
    No didn’t because I didn’t have spring compressors.. but I bought the coilovers second hand so literally it was altogether so just walked it straight on the car
  14. MrAudi2017
    MrAudi2017 Member
    30
    Yeah now to me sounds like the bearings in the top mount have seized... had it a few times over the years. You'll wanna get your hands on some spring compressors switch them out.
  15. MikeCrum1996
    MikeCrum1996 Member
    207
    17
    Do you have to get oe bearings ? Or is it an eBay jobbie? I’m now regretting throwing my old struts out
  16. MrAudi2017
    MrAudi2017 Member
    30
    Either or really. But usual buy once cry once rules apply I would think.
  17. MikeCrum1996
    MikeCrum1996 Member
    207
    17
    Do I have to completely remove the strut? Or can I just unbolt from the top and pull arm down?
  18. MrAudi2017
    MrAudi2017 Member
    30
    Looking at the technical drawings for it whole things gotta come out... springs have to be compressed and then you can get to the bearing...
    Shamelessly pinched link for you
    http://workshop-manuals.com/audi/a3...exploded_view_of_suspension_strut_components/
    Found this site for sorting my clutch out and it's been a goldmine of info!
    Hope it helps
  19. <tuffty/>
    22,417
    4,486
    You will need to remove it...
