G
gokiwi64
Guest
So a tad confused here, some say I need to unplug the ABS pump fuse and relay (but that suggests you then need to have the engine running to bleed the brakes), some say you need vcds/vagcom and others you cannot vacuum bleed .
So what is the correct answer ? ......3 virtual pints and a meat pie to the answer that works
