  2. Dismiss Notice
yatour digital music changer
hubbo1 Feb 26, 2013
  1. hubbo1
    hubbo1 Registered User
    120
    hi
    hope someone can help
    i have a4 tdi 05 with concert single cd player,i have been looking at usb/sd card interface (yatour yt-mo6) for installation it says to connect to cd changer port-but as my h/u is single cd player would it have a cd changer port?
    thanks
    andy:unsure:
  2. Avatar
    snack-media
    Advertisement
  3. B5NUT
    B5NUT Well-Known Member VCDS Map User
    5,082
    1,241
    Yes, All Audi head units are CD-Change capable. You just need to make sure you get the right lead, you will have a standard ISO connector.
  4. hubbo1
    120
    right! clear as mud lol
    i had the head unit out 5 mins ago-there are no spare ports
  5. NHN
    31,779
    2,335
    It would probably appear to be full up, but infact it would connect into one of the connectors positions, that may not have any wires going into it currently, if that clears the mud :)
  6. hubbo1
    120
    not really lol!
    there is connectors with space for other wires,electrics are not my strongpoint.
    you do get 2 harnesses with the unit but what goes where?
  7. B5NUT
    5,082
    1,241
    the bit in green is the cd-changer port, you need to put the wires in the right hole, but the device should give you full instructions!
  8. hubbo1
    120
    that looks different to the layout on the back of my h/u, ill have to take it out tomorrow.
    maybe ill post some pics of ports and wiring connectors i goy with the unit!
    thanks for your help
  9. B5NUT
    5,082
    1,241
    That is an old HU image, the layout of the connectors may have changed but the actual ISO connectors are still the same.
  10. NHN
    31,779
    2,335
    You will have either a single connector to plug in, an adapter to go inline with existing as such or wires with pins on end to push into the spare wire locations.
    Just show us a pic of the wiring for your yatour, so we can advise specifically.
  11. hubbo1
    120
    IMG00280-20130226-1921.jpg IMG00281-20130226-1921.jpg the first picture connects to the yatour unit on the other end
  12. Avatar
    snack-media
    Advertisement
  13. Joe_Murphy21187
    Joe_Murphy21187 S-Tronic
    1,054
    72
    Does this yatour device have the same limitations as the carlinx unit with the 99 folder structure, file limits & 6 CD folders?? If anyone knows...
  14. hubbo1
    120
    yes it does have the same limltations
