  2. Dismiss Notice
XL Tyres for a Golf GTD
Pinky1959 Aug 3, 2018
  1. Pinky1959
    Pinky1959 Well-Known Member
    632
    375
    I have ordered new tyres for the GTD but I clicked on the ones with the extra load symbol by mistake , The garage say the tyres will last longer as they will be better as the GTD is a heavy car and I wont notice any difference .
    I am not sure , does anyone know if they are right or should I get them changed .
    Thanks in advance
  2. Avatar
    snack-media
    Advertisement
  3. Rideen
    Rideen Well-Known Member Team Brilliant Black saloon Audi A3 TDi Manual
    1,146
    366
    Those are the advantages. Disadvantages are greater fuel consumption, a bit harsher ride and they are more noisy.
    Lol, they are pulling your leg with that one. If that was the case, everything except for superminis would be coming on XL tyres from the factory.
    X3man likes this.
  4. X3man
    X3man Well known member Gold Supporter X3 M40i Carbon Black
    6,016
    7,608
    I would say you would want to go XL if likely to load up with roof box etc, more more so in SUV/Estate.
    Get them changed before fitting if you can, but not the end of the world. Think I have had XL before, definitely a bit "louder" road noise wise.
  5. DieselJake
    DieselJake Well-Known Member VCDS Map User
    3,676
    1,073
    I generally go for XL if I can, last longer and more rim protection. Can't say I've experienced more fuel consumption, harsher ride, more noise or anything above, if anything you can get better fuel economy as they will withstand higher tyre pressures.
  6. Rideen
    1,146
    366
    I'm sorry but no. Normal tyres can withstand like 3x more pressure than people usually use so getting XL because of the higher pressure limit is weird to say the least. If anything, even if you'd use more pressure (which you can safely do on a non-XL tyre) the comfort will suffer.
    Physics behind higher fuel consumption of XL tyres are simple - reinforcement of the tyre increases the rotational mass and the additional thickness on the face and wall of the tyre increase rolling resistances.
    On the other hand, I do agree with the last longer part.
  7. DieselJake
    3,676
    1,073
    People don't get XL tyres to run higher pressures it's just a perk, I wouldn't buy an LSD to do burnouts but I could. Reinforcement and extra material "should" cause more fuel consumption but as said this hasn't been my experience and like I say you can run more pressure in them if you want to offset consumption... run 3x regular pressure in tyres and let us know what happens :playful: definately won't withstand it.
  8. Pinky1959
    632
    375
    I went to get Bridgestones fitted and they are on back order (good as I had paid on line ) so got Michelin PS4s , they look good on the car and I will get another two eventually .
