  2. Dismiss Notice
Xenon - Downgrade RetroFit
tr7 May 17, 2020
  1. tr7
    tr7 Active Member
    141
    52
    Has anyone replaced a set of Xenon Headlights with Halogens before?
    I know Kufatec do the adaptors to upgrade, but what about the opposite direction?
    I have two cars and would like to swap the xenons across into my 08 car
    Has any one done this? I'd like to leave the existing car with working headlights.
  2. Avatar
    snack-media
    Advertisement
  3. NHN
    31,655
    2,300
    Can be done, are you swapping levelling & headlight washer system too?
  4. tr7
    tr7 Active Member
    141
    52
    In theory I can do. In practice it's if I can be bothered to go to that length.
    Just wanted to know some one else has done the downgrade, I know it can change the setting in VCDS but I haven't looked at the wiring which is the hurdle I see
  5. NHN
    31,655
    2,300
    As I said can be done.
    I'd do it as per factory, proper connectors & wiring.
  6. Sidrick
    Sidrick Well-Known Member
    498
    323
    I've a Kufatec loom sitting here if you need pictures. Might help backwards engineer a solution?
    If you're selling the levelling system I'd be interested to hear what it's worth to you :)
  7. tr7
    tr7 Active Member
    141
    52
    Yes @Sidrick that'd be much appreciated
    I have a second xenon car if you want any bits
  8. tr7
    tr7 Active Member
    141
    52
    So no Kufatec adaptors then?
    Ideally factory would be the goal
  9. Sidrick
    498
    323
    I'm after as much of the levelling system as I can get :)
    Headlight side - loom side
    5-5
    6-6
    7-7
    9-9
    10-10
    11-into car (32 pin grey connector)
    12-8
    tr7 likes this.
  10. tr7
    tr7 Active Member
    141
    52
    Thanks for that, I wonder if the connectors can be bought by themselves and can swap the pins over
    As for the SL system, I’ve another full xenon car (red) so let me know what you want (and where it is in the car).
    None of the xenon parts away yet bar the Lights themselves
  11. I'm Just Rob.
    I'm Just Rob. Moderating or something, Staff Member Moderator Gold Supporter VCDS Map User
    14,547
    6,810
    Sorry to drift off topic but if you are breaking a setup I could use a headlamp washers pop out assembly, mine gets stuck out on a regular basis, well if you have one.
    cheers
    tr7 likes this.
  12. Avatar
    snack-media
    Advertisement
  13. tr7
    tr7 Active Member
    141
    52
    I'll drop you a PM to keep thread on topic
  14. tr7
    tr7 Active Member
    141
    52
  15. Sidrick
    498
    323
    Yes, looks the same.
    tr7 likes this.
  16. tr7
    tr7 Active Member
    141
    52
    @NHN do you see any reason cutting the plugs off and soldering these replacements won’t work?
  17. tr7
    tr7 Active Member
    141
    52
    Cheers again, this was really useful as my Kufatec adaptors arrived are the individual cables hidden behind a sheath/wrap
  18. tr7
    tr7 Active Member
    141
    52
    So it turns out these are Adaptive/AFS Xenons so I'm definitely going to the effort now to swap these over.
    Question: Has any one removed the Self Levelling Wiring/Loom?
    Is it even possible, or a purchase only option from Kufatec?
  19. tr7
    tr7 Active Member
    141
    52
    So just to say big thanks to @Sidrick for helping with the wiring info and making it painless.
    I have a set of Kufatec adaptors already to upgrade my other car but are almost useless for downgrading as the individual wires are covered/wrapped and each of them are white so would have had to destroy the loom wrapping to identify them myself. So cheers.
    Also turned out the replacement set of Lights I bought came with plugs cut and still attached. And so it turns out if you use the same connector from the same side the wire colours actually line up with the car's loom colours from the original factory loom which was also reassuring that what I was soldering was correct. All plugged back in working first time. So big cheers to @Sidrick for headsup giving me the confidence to cut perfectly good loom/connector out of the car!
    VCDS did take a few attempts to get the codes right and errors out as one would not change and the Self levelling errors would not disappear but was resolved once I disconnected and removed the Headlight control module from behind the glovebox.
    So car now successfully swapped down to halogens and no errors displayed.
    Sidrick likes this.
  20. Sidrick
    498
    323
    Great work :D
  21. tr7
    tr7 Active Member
    141
    52
    We have light!
    I would just add I connected one extra wire as it seems like it should be
    5-5
    6-6
    7-7
    9-9
    10-10
    12-8
    14-3
    Sidrick likes this.
