Hi just wondering if anyone has replaced their wishbone bushes on the front using a vice or other method and if so how easy are they to push onto the arms. Can't find a good "how to" for this.
Cheers.
Best approach i found was to make up a "puller" set using a bit of studding, nuts , a large socket (recess for bush to move into) and then push on the sleeve using a correct size hole saw........a bit makeshift but works well.
a bit hard to describe.... i will try to sketch and upload for visual reference.
i believe it did.....although the more stubborn bushes on the car received some melty blow-torch treatment to get them out. Just set the rubber alight and when it is burnt out you can start attacking the sleeves. Typically with a hacksaw to split it, then a cold chisel to bend it in and that makes it easy to get out.
