Wireless Charging Retrofit
Adam14
Hi all,
I tried looking on the forum and internet but couldn't find anything! Just wondering if anyone knows of someone or if it is possible to retrofit the wireless charging unit in to my B9 S5? I put my phone in my arm rest a lot so wireless charging would be pretty useful.
Sent from my SM-G965F using Tapatalk
Hi all,
Got it in mine and cant imagine not having it. Very handy indeed
Adam14
Adam14
Audidave69
I have it in mine but don’t use it as I connect with lightning cable so I can use sound cloud on CarPlay.
Think you can get aftermarket ones a lot cheaper.
Adam14
DarkyUK
I only recently realised that it 'attempted' to boost your mobile signal when on the charger :)
cuke2u
Buck
My understanding is that they are not repeated devices as they connect via Bluetooth and do not use the mobile frequencies to connect?
cuke2u
S32B
DarkyUK
I wonder if they did a recall and disabled the existing ones or not?
cuke2u
I don't know and I don't think mine's been disabled, perhaps they were applying it to new cars only. However this was always existing legislation since 2006, just never applied for some reason. It maybe also that Audi successfully applied for and was successful in obtaining a licence.
Although in the configurator it no longer advertises this feature within the phone box:
"Audi Phone Box with wireless charging
Offers wireless charging (with Qi-enabled compatible phones) and creates an additional Bluetooth interface for a second device, meaning 2 mobile phones can be connected to the vehicle simultaneously".
DarkyUK
As we don't have the NFC Key Option on the A5's I wonder if this ever had the booster?
cuke2u
Neither has mine got nfc but it has the booster, taken from the my17 brochure:
bruce_miranda
Look in the boot on the right inside the storage bin. You will either see the booster module or not. The issue wasn't about the booster itself. In 2018, Audi changed the booster to include more bandwidth and cover more regions. This caused the issue. All cars had their boosters removed before delivery or as part of a recall. You will see 3 wires wrapped in foam, if yours was removed and an error on the cars error log, to show that the aerial is disconnected. Now the booster is not even advertised as an option.
DarkyUK
Cool, mines a 2017 S5 so probably still has this, certainly I have no errors logged for it.
bruce_miranda
You'll see a fault in the 5F module if it has been removed after the car was built. The fault is only visible by the diagnostic tools. See mine below.
3086 - Antenna for Telephone Mount
B1564 01 [009] - Electrical Failure
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 1
Mileage: 2 km
Date: 2018.04.17
Time: 13:19:04
Voltage terminal 30: 12.6 V
Status of telephone-Antenna diagnostic: OK
Status of telephone-Telephone baseplate diagnostic: not connected
Status of telephone-Handset in handset holder (cradle): not selected
Status of telephone-Handset holder (cradle): not connected
DarkyUK
I checked, I have a small unit there with two aerial connections and a small block connector in the middle so I guess mine still has something :)
Buck
Hi all,
I have the wireless charging cradle that I bought intending to upgrade but haven't done so. If you are interested PM me.
Adam14
Thanks mate but decided to hold off on it for now. Saving for a road trip round Europe so can't justify these sort of things at the moment (how boring I know)
bruce_miranda
Just buy a central console organiser and put any old wireless charger under the place for the phone. There is a USB socket in the armrest which is perfect for it.
The BIGGEST advantage of the factory option is the useful voice reminder that you have left your phone on the car when you try to leave the car without it.
Buck
Road trip sounds good!
Evil Derboy
Thats the point if @creweaudiparts can get the OEM mat and the cable assembly then you could code it with VCDS. You do also get the phone reminder if your car is plugged in via USB also though.
cuke2u
S32B
bruce_miranda
Nope, CarPlay is not wireless on this generation of the MMI.
Also you dont need half those cables in the Kufatec kit. You literally, just need the power cable and the charging cradle, which isn't even included at that price. The cables included are for the mobile booster, which is being disconnected and discontinued anyway.
DarkyUK
I don't think they have an active program to disconnect the boosters, just the ones they 'tweaked' or 'upgraded' as mine has been for a service but is still there :)
b0k
I see the latest wireless charging mat has increased in size. My phone can't lie flat on mine from 2017.
Does anyone know if this can be upgraded? Pref OEM
Obviously wiring and coding is in place from original. I asked my dealer who said they couldn't do it.
strandgaard
Buck
I’ve got a wireless charging cradle for sale ignore anyone is interested?
Came out of an S5 (2017) but my phone isn’t wireless charging and the planned upgrade isn’t happened so it’s still in its box!
If you’re interested, let me know.
b0k
Buck thanks but I think that is probably same as mine (2017), the link Strandgaard sent looks promising as newer one but minimal info/dimensions on that site - I'll need to contact them.
Anyone had experience of fitting these?
strandgaard
Did anyone end up installing a charging mar in the console?
I did - and it works perfectly. I bought the charging pad on eBay and the cable harness and coding dongle from Kufatec. I would imagine that anybody with VCDS could do the coding without the dongle. The Kufatec wiring does not include an aerial wire to the roof aerial, but assumes that you mount an extra aerial on the right side behind the rear bumper.
I did put the amplifier in the back, but haven't had the time to install the extra aerial just yet. I don't imagine that the difference in signal strength is that significant though.
