if the bolt pattern is the same, the centerbore is the same and it clears your brake calipers, it will fit. If youre bent on having these on the car and your brake calipers touch the inside of the wheels, you can get spacers and possibly longer bolts(depending on how big the spacers are) and that will give you the clearance. if you get spacers(for correcting offset) make sure its a high quality hubcentric spacer. if the wheels youre putting on have a bigger centerbore you can correct that with hubcentric rings to fill in that gap. some companies sell premade ones, some can cut you custom ones(i have these as im running Lorinser wheels on my car and they have a MUCH bigger centerbore diameter than my OEM ones). Even if the bolt pattern is different, theres always adapters to go from one bolt pattern to another, plus you can get a set made custom for you to fix the centerbore diameter difference and be a certain thickness so you dont add in spacers. If you are trying to fit wheels that have a smaller centerbore, they wont go on, or youre going to have to get some custom made adapters with two different centerbore sections, inner and outer, but keeping the bolt pattern the same on inner and outer sides. I hope its not too confusing.
