White spots on lights?!? Paint?
Tom V
Good morning
Cleaned my A3 for the first time and noticed that both sets of rear lights have white spots on them.
I have only had the car a week (used) so have only just noticed it!
I assume it may be paint? But not sure why or how.
Any advice of how to remove it? Without damaging the lights.
I would use white spirit, but try just a little in a small inconspicuous area first.
The main problem I think, is that if your lights have these white paint spots, then I wouldn’t be surprised if some of this paint will also be covering your body paint......what colour is your car?
kcpism
It could be paint, it could also be compound/polish from a rotary if you haven’t had it for that long but most likely paint.
Tom V
Yeah I’m thinking it’s paint too :confounded:
What’s best to clean it off the lights?
Someone at work recommended WD40?
jassyo06
T-Cut King !
Diluted ipa
Scotty75
+1
Either is compound or paint overspray. Could use IPA Panel wipe, WD40, white spirit and in the last instance some rag soaked with a little petrol. Works wonders of needed . No smoking though
Sent from my Nokia 8 using Tapatalk
kcpism
Start with that as you probably have some already, then try IPA, if you don’t have any of that you could use some old aftershave/perfume.
Don’t forget to use something soft like a micro fibre cloth or cotton wool.
S32B
Looks like they have done a repair somewhere on the back of your car and the overspray has got on the lights, it will probably be on your paint as well! Clay & lube should get it off easily enough.
AlexA4Avant
Have you tried a little lube and clay. Wouldn't use white spirit on new paint may cause a reaction. then you might need a full bumper respray. Start the least aggressive removal method and work up. Chemicals are usually quite harsh straight out the bottle
Sent from my FIG-LX1 using Tapatalk
