Whistling like a kettle after CAI
TomSx
Right, fitted my CAI and between 3-5k I get an annoying whistle like a kettle. Now I've put a full new set of jubilee's on it, double checked everything which I can only think leaves the maf? It sits in tight and I've also put some silicone around the outside, but still i'm getting the noise! Any ideas? lol
I have the same issue with my Revo CAI, could be just one of them little anoying things you have to live with lol
Reactions: TomSx
Yes very lol mine only does it when I boot it, its getting to the point where it is making me drive like Miss Daisy...OMG did I just say that :keule:
Same here. It also seems to only be between 3-5k when it's at it worst but then that' peak boooooooooost.
I had this with my APR Carbonio but dont seem to get it with the Unitronic, just more of a whoosh then a whistle
I am hoping its normal, I dont seem to be suffering from any performance issues, you?
It's certainly going better than without it. I just really don't know where it could be coming from. Anyone know if you can buy the rubber maf seal? I really don't know how it could be leaking with the amount of silicone I've plastered on there though.
You're not getting the same as us then. I get plenty of whoosh, just a whistle too..lol
I have no idea what part mine is whistling from, if you find it let me know lol
I took the whole thing off yesterday, fitted everything again (with new jubilee's) taking as much time as possible. It's still there..
I also have a much noisier intake. Sounds like Darth Vader is hiding under there. Not much whistling though.
I would say whistling is more likely to be the boost side rather than induction ! As the CAI is not under any boost pressure.
Have you checked you DV ? as i had a slight whistle a while back and it had a slight split in the diagram and i believe this was there before i fitted the Revo CAI but you can just hear it more with those fitted ! Also i take it its not a fluctuating hiss noise ? as this is the N75 valve venting boost and is normal this sound like if you had a small pipe in your hand under pressure and you came off and on the end blocking the flow with your finger...
Example of a split DV valve....
DSC02116
Reactions: sliced
your DV might be split :eek: mine was, and managed to get rid of the noise once i changed it
Certain cold air induction kits suffer with this problem. There is nothing you can do other than change it for a different cai. Think it is more prominent on kits which have a lot of alloy piping tho. You could potentially replace a section with a longer piece of silicon tubing
I have this noise too after fitting my evoms CAI. I also have a boost gauge and i don't notice any drop in pressure when i hear the noise if the dv is split.
As above it's 100% not the dv on mine. Just an annoying noise. I have since lift it as little on the turbo end and it's made a huge difference.
I've got he carbonio ram air induction an it whistles too.
get used to it or ditch it.
Yeah I've got used to it now although I did find an old S2000 K&N filter in the cupboard so may fit that and see if it dies down over the foam ramair..lol
it makes the car suck in a lot more cold car and on the dyno produced more BHP
