Which Turbo?
SteveSAS May 16, 2018
  1. SteveSAS
    SteveSAS Guest
    Hi guys, just been looking at KO4 Turbo's for sale. Are they all the same or different for different engines ie amk, bam? I'm seeing a code on them of 5304 101 5078 stamped on them but the price varies widely from a few hundred to a few thousand. So whats the deal?
  2. Avatar
    Google AdSense Advertisement
  3. andrew_wright
    andrew_wright Member
    105
    24
    You could buy a cheap ass China eBay ko4 and stick a genuine cartridge in it. Cost would be somewhere near £400 for all the parts and assemble yourself or pay someone to swap the cartridge and check balance for maybe £100 or just replace your cartridge in your ko4 you have now.
    Sent from my Nexus 6 using Tapatalk
  4. <tuffty/>
    23,359
    4,947
  5. Stuart B
    Stuart B Well-Known Member
    3,448
    739
    why do you want a new turbo? is yours kaput - or down on power or the hotside cracked etc.
    as the others have highlighted Badger5 sells CHRA for a K04 - pretty sure you will have some form of an issue if you get a fake Chinese - although from Alibaba they are about $120 for a K04 - so maybe worth a port exercise and a risk?
  6. andrew_wright
    105
    24
  7. <tuffty/>
    23,359
    4,947
  8. andrew_wright
    105
    24
    It's not really a full on hybrid, more a fancy OEM version, but yes I guess the ECU couldn't cope with it? I think it would have no issue running this as it's only standard size but mapping would help give it's full potential if any.
  9. <tuffty/>
    23,359
    4,947
    I am sure the ECU would have headroom on a standard map but I would imagine it would potentially get a little antsy about it all the same
    Considering a std K04 on most 'mapped' scenarios is close to maxing the std injectors out and how hardware changes on mapped engines can massively affect the now narrower tolerance window of the ECU's protection params I would argue that nothing like this is simply bolt on...
    hydro s3 likes this.
  10. Stuart B
    3,448
    739
    Is there more to a hybrid than a CHRA?
  11. andrew_wright
    105
    24
    Except making a bigger wheel fit, no. Most if not all will buy a cheap eBay ko3/4 and bore that out to fit whatever they need, should see some of the stupid **** they do in America. Housing must last a day at best.
  12. Avatar
  13. badger5
    10,042
    2,276
    yes
  14. SteveSAS
    SteveSAS Guest
  15. <tuffty/>
    23,359
    4,947
    Just need to watch the wastegate port on copy turbos... they are generally too small and need porting to prevent over boosting problems (which forces the ECU into limp mode or worse...)
    The wastegate arm bush in the hotsides have a tendency to go loose and causes the wastegate to drop into the hotside...
  16. <tuffty/>
    23,359
    4,947
    ...oh and AMK/BAM need a turbo with an EGT probe boss (the one you linked appears to have this)... APY don't have an EGT probe so the hotsides are a little different
  17. badger5
    10,042
    2,276
    in my experience of chinese k04, they vary hugely in finish/quality & spec. I personally trust none of then out of the box to be reliable.
    Most common is a very very small wastegate hole which will cause boost creep/overboost. Another is as tuffty said wastegate sleeve comes loose and drops into hotside jamming the wastegate. (easily fixed by a little tak weld on sleeve to hotside) Who knows regarding quality of balancing or reliability. they're very cheap.. They can be used as a donor to cheaply replace a cracked hotside however (with the caviat I mention above re porting its wastegate out). With a genuine BW core being a little over £200, and if you just want like for like std item, then recoring your existing unit may be suitable for you. you wont know until removed of course if the hotside is too badly cracked if its cracked.
    If you're chasing blue smoke, have you checked your charge pipes for qty of oil, and if they are pretty oily, then finding out source would be the next thing. It may not be turbo, and may be excessive breathing from the engine itself. to determin this, you need to clean all your charge pipework out and fit a catch can (temporary) and isolate breather from intake so to remove a potential source of oil *(blue smoke) If oil straight out of turbo it is usually white smoke..
  18. JsAudi
    JsAudi Member
    57
    Out of interest what size should the waste gate port be on a k04 turbo?
