Facelift wheel spacers problem
cillerucho
Spain
Hi. I have a wheel spacers problem. My car is an audi sportback a3 8v (year 2017, facelift).
The problem is that the spacers won't fit all the way in because they bump into the hub cap. Any solution?
Wrong spacers for your car.
The taper inside isn’t big enough to accommodate your disc lip.
You need to contact whoever your bought them off and ask them for a set that fits your car.
Reactions: cillerucho
Fixed issue. Apparently this model is only valid for the front.
If they're the 10mm ones then they'll only fit the front as you've established. 12mm and above should be fine for the rear.
Damian @ DPM Performance
How does that work then? There aren't front and rear wheels for an S3, so I assume all wheels have the same chamfer. Why/in what way are the spacers different?
The hub lip on the rear tends to be deeper than the front and because of the spigot depth and chamfer on the 10mm spacers, they only go over the front hub lips.
Makes sense (a bit anyway). I messaged Performance Alloys, as when I searched for the S3 I got 8 results (6 H&R, albeit three part numbers with a & b options, and two Eibach od different part numbers).
https://eur05.safelinks.protection....TyzW1anSL509kcqmQXjyucld4Ur7NXDoQ=&reserved=0
I got this initial response:
"So there are two part numbers listed with H&R:
2055573A
2055573B – REAR AXLE ONLY"
I then asked
"Does 2055573A fit both front and rear then, or front only? Do you know the difference?"
And got
"H&R don’t list any advisory beside 2055573A so yes it should fit both.
The difference in both A & B:-
2055573A – Max Hub Lip Length 15mm
2055573B – Max Hub Lip Length 12mm
So you will need to measure the hub lip length front and rear."
Not a great response from a supposedly specialist company! From what you say, the longer lip capacity should fit both front and back, but the one for rear only is specced as a 12mm max lip, rather than 15mm.
A picture would be worth 1000 words to me in this case!
https://eur05.safelinks.protection.outlook.com/?url=https://www.performancealloys.com/carsearch/accessories/spacers/?spacer_pcd=10451&spacer_width=9-11&data=02|01||3cc22c3c01be4de22db608d85af7b962|84df9e7fe9f640afb435aaaaaaaaaaaa|1|0|637359367291695088&sdata=MqWGnm9rTGTyzW1anSL509kcqmQXjyucld4Ur7NXDoQ=&reserved=0
2055573A
I then asked
And got
Did you buy them from said company?
Well the ones I have are 2055573A, and the rubric on the box says suitable for up to 15mm hub lip, so as the helpful guy at Performance alloys said, good for front and rear of the S3.
564
863
708
9
859
27
4K
