Wheel Spacer issues?
Henda
Hi all,
I have bought some 8mm h&r hubcentric spacers for my A3, went to install them today to find fitting issues. The spacers fit perfectly and sit on the hub as they should, but when i have offered my wheel up there is approximately a 2mm gap between the wheel boss and the front of the spacer.
It looks as though the chamfer on the spacer around the centre bore is preventing the wheel seating fully on the spacer.
Has anyone had this before and could suggest any fixes to sort it. Spacers are brand new bought from a site sponsor.
NHN
Site Sponsor
Pics?
Henda
Different chambers? I have a set of h&r 12mm spacers on the back without any issue. Just assumed the chamfer would be the same. Never had issues like this before have numerous sets of h&r over the years. Could i just stick the spacer in a lathe and machine the chamfer myself to correct it?
NHN
Site Sponsor
Show us pics of the spacers.
Henda
I am currently at work. I might be able to get some photos. What exactly are you wanting photos of the chamfer or the whole spacer
Henda
These are the ones i was sent by DPM.
NHN
Site Sponsor
Ok now show them on the car & wheel as tbh I can't see what the issue is, hub centric & damian aka dpm doesn't make mistakes usually.
When you place the spacer on the back of the wheel, does the 2 faces sit flat against eachother as though it was part of the wheel.
Henda
No if i put the spacer on the back of the wheel it doesn’t sit flush on back of wheel there is a 2mm gap all the way around, no matter how had a push it doesn’t go in fully. Wheels are Revo rfo 19’s, can’t get a photo of that at moment at work.
NHN
Site Sponsor
Need to see inside the wheel hole where spacer would sit.
Henda
The actual centre bore part of the spacer (non chamfered bit) fits perfectly in the centre bore of my wheel. It’s literally the chamfer on the back of the wheel hitting the chamfer on the spacer which is stopping me sliding wheel on fully.
NHN
Site Sponsor
If I'm understanding this correctly, due to the 8mm thickness, the tapered edge is causing the gap & I suspect a 10mm or 12mm will fix this as there's more meat on the inside to create that edge against the bearing to be hub centric & snug fit.
You could lathe the inside of the wheel to accommodate the spacers, but thats upto you.
Henda
Yeah thats what a think is happening, but i was thinking of putting the spacers on a lathe and machining the chamfer to fit the wheel
NHN
Site Sponsor
Not sure I'd do that tbh as not enough meat on it, hence why its affected as is.
