  2. Dismiss Notice
  1. who-sijones
    who-sijones New Member
    19
    Anyone good with wheel sizes on here?
    S3 8p 3 door with 225 35 19 tyres on. My wheels are 19" et 35 8.5J.
    Just put the rear back to standard height and I'm still rubbing now and then.
    What can I do/what's cost effective to stop?
    I've removed the wheel arch screw too.
    Tia
    Sent from my SM-N950F using Tapatalk
  2. Avatar
    snack-media
    Advertisement
  3. nluk100
    nluk100 Well-Known Member
    1,483
    304
    ET35 is too low for the S3 - ideal offset is ET43.
    Either you can change the camber on the rear to tuck them under your arches or roll the arches (or swap out your alloys - what made you choose ET35?).
  4. who-sijones
    19
    Coincidentally I'm going to get tracking and wheel balancing done this week, I'll ask if they can add a small bit of camber as it's only just catching. I've read that the rears can be easily adjusted.
    It was a mistake, the guy said he wasn't sure but thinks 45. I didn't even check when I got them .
    I hoped going back to standard height would fix it, it's helped but it's still there.
    If not I'll just have to try and sell the wheels or swap them.
  5. Sayam
    Sayam Well-Known Member VCDS Map User
    2,786
    661
    Wouldn't going to a factory spring from a lower one will mean a less stiff spring, which will deflect more and may make rubbing worse?
    As others have said you can change the alloys, add some camber and another option would be to get an engineering company to mill up to 5mm off the rear of the wheel, increasing the offset. Depending on the wheels I don't think it's advisable to remove more than 5mm. Someone who knows more about engineering and mechanics will be able to advise.
