Wheel Bolt Covers Issue
Arcam
OK, it's a bit of a weird one but in the last 1400 miles (since new) I have gone through 2 sets of wheel bolt covers, they are pinging off when driving.
A couple of times I pressure washed the wheels I noticed they were a pretty loose fit, my RS4 before my RS3 never had this issue and it had the same sized wheel bolt heads (17mm) and style of cover.
I did think that someone was nicking them to start with <g> but I have now ruled this out, is anyone else having this issue?
Orange225
A couple of mine kept coming off on my 8p. I just fired a load of thick grease in them, they've stayed on since
Arcam
Bit too messy solution for me as I will be removing the covers on a regular basis to replace pads, check wheel bolt torque etc (I do loads of track days) and with the heat from elevated brake temps the grease will run all over the place.
Orange225
Ah ok. Try spraying some spray paint inside them and leaving to dry, make the diameter smaller
Arcam
I like your thinking :)
I have flagged it up to Audi for a (hopefully) more permanent solution.
Terminator x
I didn't even spot they had covers :eek: will check upon my return to the car!
TX.
45bvtc
The Older I Get The Better I Was
Supporter
Gold Supporter
Never lost one yet Arcam and really can't understand how you are, however, I respectfully suggest a mm or two of silicon sealant to one face of the bolt prior to fitting the cap and that'll hold and allow you to remove the cap when you need to perform those oh so necessary RS3 tasks
PS: don't hold your breath waiting for Audi UK to come along with a solution; I've been waiting since 2011 for them to resolve a way more serious issue than loose wheel-bolt-caps but with my warranty now expired am no longer waiting on 'em...
josedebardi
Well-Known Member
I've lost all but 2 (as in 18 are gone!).
I wondered about just spraying the tops of the bolts black rather than finding some way to stick the covers on better.
S3DBW
Yep, same problem, just bought 10 new ones! Discovered that the new ones are a much tighter fit than the ones the car came with which were rattle fit at best, despite having the same part numbers. Will probably end up replacing all of the remaining ones as well!
josedebardi
Well-Known Member
Ah that's interesting S3DBW. I'm waiting for a call back from my dealerships service manager now to see what they say. It'll be fixed under warranty either way.
xBox
What about some friction paste - used on CF road bike seat stems, so you don't need to tighten the bejesus out of the clamp?
Schuey
Interesting, mine have started going missing as well.
Terminator x
LOL now that I've checked four missing so far!
TX.
josedebardi
Well-Known Member
Dealer spoke to Audi Technical who said they had no reports - so he showed them this thread!
He's going to order a new set and see what they are like.
Terminator x
Do you have the part nr + where did you get them from?
TX.
S3 AD
I have experienced exactly the same thing! I also thought they were nicked. Then whilst washing the car noticed the about 25% that were left were a very loose fit. I haven't had this issue on any previous Audi including a 8p S3 & 8P RS3. I am not really that concerned as in the greater scheme of things is a pretty small issue. I will just tell the dealer at 1st service and get them replaced under warranty.......unless someone on this thread comes up with a easy fix or gets it acknowledged as an issue and altered replacements are available before hand as 1st service could be a while off, I have only done 2026 miles since 26 July.
RGBARGEE
Well-Known Member
You guys must be driving like tearaways ;-)...
S3DBW
TX.
Part number is 4M0 601 173 B, just ordered them thru my local Dealer, note this part number is for the standard bolt cover, not the ones for the locking wheel nuts
Arcam
Thanks for all the replies, there looks to be a definite QC issue with the bolt covers on the RS3, I might well get a set of the RS4 ones (silver only) as they were a much tighter fit and despite 8 track days last year I never lost a single one.
I am posting some pics up shortly (in a new thread) of another potential issue I have found and some info on the tyres.
LuckyLee
After seeing your post I checked mine. I had 4 missing off one side rear & 3 off the other side rear. Front ones are all still on.
Went into Coventry Audi on Thursday and told them and mentioned this thread.
Service desk said I had to pay for them myself. I told them no chance. They finally agreed to give me them free. They ordered them and they came in the following day. There is a revised part number apparently. I fitted them myself and they seem a very tight fit
Arcam
That's brilliant news, I will speak to my dealer again, thanks for the post.
josedebardi
Well-Known Member
Any chance of someone posting the old/new part numbers?
Arcam
My dealer (Preston Audi) have confirmed that modified part(s) are available and will be shipping me a full set out, I will try and get the new part numbers(s) posted assuming they come with the bag they will ship me, failing that I will ask for them.
josedebardi
Well-Known Member
Popped into the dealer today and they fitted a whole new set (only the locking nut ones were still on by now.
The Master Tech speculated that the B was a revised version over the original loose ones. New ones were all a good snug fit :)
Arcam
Nice one chaps, thanks for posting the part number up :thumbsup:
