Hi guys is there an how to for changing a front wheel bearing on an A4 tdi as I need mine doing so any advice would be greatly appreciated
Thanks in advance
I'm pretty good with the spanners and yes I have access to a press but people do things differently and I just wanted to know I how many ways there is to do it of there is any. I've searched on here bit its not bringing anything up
You don't need a press to change the front bearing on a B7, it's held in by a few bolts. So undo centre drive shaft bolt, lower arm (to get shaft out) and then you can see the bolts holding it in place
