What's happened to my radio?!
Westy
I got in my car this morning and the radio was already on with all the lights lit up. The screen was blank and there was no sound coming out. I've tried pressing all the buttons but it doesn't work and my VCDS cant communicate with the radio module!
Anyone got any ideas? I've thought about disconnecting the battery and leaving it for an hour and connect back up to see if it clears the problem.
I have a Symphony 2 double din jobbie.
Broken Byzan
Photographic Moderator
Staff member
Moderator
That doesn't sound good. I don't see dropping the battery doing any harm as the HU is useless as is. I assume you have the code in case this fixes it?
Westy
I need to check I have the code before I do disconnect the battery. Just as I'm about to fix one problem I get a new one! 4rings are spending a day on my car on Wednesday so if I dont get anywhere myself this weekend I'll get them to have a look.
Westy
I have just fixed the problem by leaving the battery disconnected for 45 mins while i went and had a beer in the work social club, DIY at its best :icon_thumright:
Westy
I just wanted to add to this that since disconnecting my battery for an hour I now get much better MPG than before? I was getting around 25mpg and now i'm getting around 30mpg!!!
wibble111
needs to scratch the itch
Thats a good increase, do you use 98 ron all the time?
Westy
No sometimes I have to use 97 because the garages near me are rubbish and dont do anything higher. I used to have shell garage down the road but it shutdown a few yeaws back.
I think my MPG has increased because my ecu has gone into learn mode and i've been driving round like my nan!
mattyboy199
pull the fuse should sort it out happened to mine a few years ago.
Westy
Thanks Matt I'll try that if it happens again but with any luck all my electrical issues will be cured after me visit from 4rings on Wednesday.
LordNelson
Do you think it would be worthwhile disconnecting my battery to re-set the ecu into learn mode. my mpg has always been shocking, but just fitted a new MAF and spark plugs.
LordNelson
does the battery have to be disconnected for any certain period of time to reset the ecu? and do both terminals need to be disconnected?
I just took the black earth cable off for 30 mins or so and this reset the clock, MPG etc but the stereo retained its settings. however, when i turned it on, the stereo display showed "LEARN" for a cpl of seconds....and ideas?
and, the god dam door locks have gone loopy on me again (making the interior light flash when the doors are closed)
