  2. Dismiss Notice
What size Jubilee for N75
mcpickering Nov 8, 2012
  1. mcpickering
    mcpickering Registered User
    121
    hey guys,
    after a bit of advice,
    i have just bought a Badger5 V2 TIP, second hand and there is no jubilee for the N75, i was wondering what size do i need?
    also, the silicon sealant that bill puts on the billet adapter to seal around the turbo, does it matter what type you use(probably a silly question i'm sure)
    thanks,
    James
  2. Avatar
    snack-media
    Advertisement
  3. mcpickering
    121
    any help?
  4. <tuffty/>
    <tuffty/> Badger 5 Edition...Its all about the flow... Staff Member Moderator
    24,315
    5,588
    Sealant requirements are documented in the fitting guide (link in the stickies and in Bill Badger5 forum in the sponsors section)... don't know the size of the clip off hand but you could just measure the N75 outlet on the TIP and get one thats suitable?
  5. mcpickering
    121
    thanks tuffty
    i can see anywhere mentioning the sealant spec?
    im afraid i dont have the TIP to hand and wanted to go grab the clip today if possible. just on the off chance someone may know the size.
  6. <tuffty/>
    24,315
    5,588
    Give Bill a call...
    Tel:01453822880, Mob:07976 800775
  7. s3dave
    s3dave TFSI Hybrid Supporter
    10,099
    738
  8. Jason.s
    Jason.s Registered User
    2,875
    348
    ETKA says 8-12mm?
    I also used the same sealant as Dave although got the 500degree option just because it was available at local factors lol.
  9. mcpickering
    121
  10. Jason.s
    2,875
    348
    It probably would be bigger due to thicker piping yeah. I`d perhaps get a couple if you can get singles instead of packs.
    That silicone should be alright. High temp silicone sealant is much the same it seems.
  11. jojo
    jojo Looking for Boost! Staff Member Moderator
    29,078
    3,818
    RE:N75 Jubilee, use a small cable tie unless you are OCD! It's not going to pop off under boost pressure or anything where it's positioned I think?
