What rods to go for and how much?
s3evil34 Jun 6, 2018
  1. s3evil34
    s3evil34 Member
    135
    Hi there been trying to find the answer to this but can't. What rods should I fit to my bam engine? Just collecting parts to tune the car to 300bhp plus. So far got the 3inch down /Jr Air filter and beach buggy hybrid /intercooler. Still thinking about not doing the rods and just hopefully getting 300 out of it. But if I do what ones do I go for and how much will they set me back.
  2. Avatar
    Google AdSense Advertisement
  3. <tuffty/>
    23,190
    4,866
  4. scotty_24
    scotty_24 Well-Known Member
    1,160
    321
    Do the rods, rods can go standard map. Old tired engines now
  5. superkarl
    superkarl MAN OF STEEL
    9,894
    2,597
    andrew_wright likes this.
  6. s3evil34
    s3evil34 Member
    135
    Cheers guys will call badger 5 as I want them to map the car. What are the standard injectors good for power wise ?
  7. hydro s3
    hydro s3 S3 amk Team Ming Blue Audi S3
    827
    218
    43
    Do a Google search for 20mm rifle drilled rods there is quite a selection for our cars and at a range of prices,depending on your budget.
  8. badger5
    9,946
    2,239
    choice of rifle drilled (advised) or non (cheaper), IE or PEC, H Beam or I beam designs..
    270bhp is 100% IDC on std 386cc S3 injectors in my experience as a guide
  9. antwan64og
    antwan64og Well-Known Member
    1,033
    271
    Most of the quotes I got were around £1500 for drilled rods fitted including new cambelt kit.
    If you Factor in a basic cylinder head refresh the price obviously goes up.
  10. Stuart B
    Stuart B Well-Known Member
    3,292
    712
    This is why ~350bhp costs 6k.
    Rods, head refresh and valves, injectors, fuel pump, exhaust manifold, turbo, downpipe and sports cat, cat back, intake, FMIC, map. - how much extra is a big turbo?
    But you can get 275bhp from an intake, downpipe, fmic and map. ~1k
  11. S3AMJ
    S3AMJ OEM+ Team Brilliant Black Audi S3
    1,110
    301
    You could probably add another £3k on top of that if you want to go BT.
    Tj 0785 likes this.
  12. Avatar
  13. S3Powerxz
    S3Powerxz Member
    106
    Does 3" downpipe really makes such a differrnce in performance on S3?
  14. S3AMJ
    1,110
    301
    The S3 should have come with a 3” downpipe from the factory. The standard one is the most restrictive part of the exhaust system. Regardless what level of tune your at, changing this is critical in my opinion.
    scotty_24 likes this.
  15. scotty_24
    1,160
    321
    Best bang for buck after a TIP. Have a look at Badger5 facebook, Bill only yesterday I think did back to back runs of a car with a downpipe change inbetween!
    Its bloody awful, why they couldnt use a simple 3" downpipe is beyond me. These teenie turbos need as much free flow as possible. To quote Badger5, its all about the flow.
    S3AMJ likes this.
  16. Stuart B
    3,292
    712
    TT's use the same ridiculous stock downpipe.
  17. b2
    b2 Member
    71
    100% agree standard exhaust systems are always extremely restrictive. Even if you just upgrading to a 3" exhaust system with zero engine mods, you would notice a massive improvement. In my opinion I would pay that little extra for a decent exhaust system, because its a simple mod that is essential to unlocking power gains, and reputable brands retain their second hand value.
    S3AMJ likes this.
  18. s3evil34
    s3evil34 Member
    135
    I must say my friend had a 3 inch downpipe fitted to his standard s3 I had my just decat fitted to mine. Both cars were neck and neck before mine pulling away abit in 4th. After he had the 3inch downpipe put on he pulled 2 car lengths away from me. All about the flow for sure.
  19. badger5
    9,946
    2,239
    3" downpipe just on a k03s based turbo.....
    makes a big difference. backpressure is the enemy
  20. s3evil34
    s3evil34 Member
    135
    That's a massive difference! Amazing it makes that much difference. Well worth doing
  21. Stuart B
    3,292
    712
    How on earth have you got 259bhp from a k03s turbo? I thought they could only be mapped to about 210-220?
  22. superkarl
    9,894
    2,597
    Read again. Ko3 ‘based’ turbo
  23. Stuart B
    3,292
    712
  24. badger5
    9,946
    2,239
    £1590 here for rifle drilled rods supplied and fitted.. includes end to end balanced rods, water pump, cam belt, tensioner, tensioner pulley and rings and bore hones where appropriate..
    Pyeman, antwan64og, s3 Hoggy and 2 others like this.
  25. Stuart B
    3,292
    712
    That's a good deal - but I suppose if it is your bread and butter you can keep the hours down, do you leave the engine in situ? also would you recommend having some other easy to get to bits done at the same time eg head refresh, valves, seats etc.
  26. badger5
    9,946
    2,239
    there's no need to remove an engine to fit rods
    head off sump off, all the access you need
