What power D3S Xenon bulb?
flipmyflipper
My drivers side main headlight bulb has gone. I've looked for a replacement but they seem to range in power from 4300k - 8000k. What power are the standard bulbs please? as I only really want to change the one for now and would like them to match
Steveredman
Hello, the numbers you are quoting are not the power, they are the colour temperature. Lower is warmer (so yellower) and higher is cooler (so bluer). Somewhere in the middle (about 5000K) is what most people would call white.
I just replaced mine with Osram Nightbreakers which are 4300K, they appear just off white. It's all down to personal preference.
dpaz
It will be difficult to get a perfect colour match. Xenon bulbs and their colour temperature degrade over time. So if the bulb that's working is pretty old it likely won't be operating at OEM colour temp.
Also, the colour temperatures advertised by non-OEM manufacturers are typically very inaccurate. Don't even get me started on eBay xenon bulbs!:gun2:
Nilz
Defo worth the wait :)
Did you buy a pair, if so it would be worth changing both bulbs, as already mentioned the colour match will more than likely be somewhat off due to the age of the original one.
Where did you get them from too, you do know that we have a site sponsor @t8ups who is the lighting guru!!
LukeyC
After spotting this thread I started looking around a bit and ended up swapping my (perfectly fine) ones for these Osram Nightbreakers:
Have to say that they are way, way better than my OEM (philips xenecostart in mine), and I've not even driven at full night yet!
A worthwhile upgrade in my book, and easy to do aswell (I removed both my headlights so I didn't risk touching the filament.
gary_a4_quattro
How old were your original OEM's @LukeyC ? Wonder what the fall off in light output is as Xenon bulbs age ?
LukeyC
My car is a 2009, bought it on 38k miles so I guess they were the original ones which is why i thought it was worth having a look at replacing them.
Obviously milage doesn't affect light output, its to do with hours of use, but unless it had spent alot of its life in traffic jams they probabily hadn't seen too much use. I guess they just degrade over time anyway
LukeyC
I bought them from Amazon because my plan was to fit one, and go for a night drive to see if I could spot a difference - if not I would have returned them to amazon.
In reality I fitted one, turned the lights on and could instantly see an improvement so fitted the other one and am keeping the originals as spares just in case.
gary_a4_quattro
Thanks for the info @LukeyC Its a difficult one to quantify, in terms of the burn time on the bulbs, especially with a vehicle before your ownership.
With the auto lights on mine, they have a tendancy to be quite pessimistic, in that thay turn on at the slightest hint of the approach of dusk and then stay on after I would have turned them off, if wasnt being a lazy b****r and using the auto mode!
(btw - The MMI setting for the lights is set on 'later' )
Steveredman
Did you need to remove the bumper cover to remove the headlights?
LukeyC
Hi guys, sorry for late reply only just picked this up.
Yes they were easy to replace - 5 minutes per side, with no removal of the bumper or anything like that - just take the back of the headlight off, twist and they pull out. Very simple :)
dave_beastttt
Standard for that year is 5000k
GjrBartlett
A4B82.0tfsi-12
I can't grasp why you would spend 300 to get that kit, instead of just buying a new pair of good d3s. Money in the trash can, if you ask me.
A4B82.0tfsi-12
Yeah I've seen the pics. There are significant differences between xenon bulbs, and the change is clearly not showing the difference between a good d3s and the kit. They wouldn't be selling any conversion kits then.
GjrBartlett
Why....
Well, as posted I've already had a D3S bulb blow, so as advised above its better to change the pair as opposed to just one.
So a decent pair of D3S is going to set me back somewhere approaching £100 - £150, so for at the same again, I can get a significant improvement over a decent D3S set-up & what price do you put on having a top notch headlight set-up on a dark twisty back road with the family in the car, if it saves me a potential accident, that's priceless.
Oh, you can keep your trash can!!
gary_a4_quattro
@GjrBartlett - look forward to seeing the results, I saw the pics before the Photobucket debarcle , out on the road, there was a strong improvement in range and illumination within the beam pattern.
Correctly focussed and powerful illumination within the beam pattern area are a real safety improvement for both the driver & passengers in the car they are fitted to and other road users alike.
GjrBartlett
The initial pics looked very impressive..
I'll post some pics up in my project thread hopefully by mid next week.
PenttisHSR
Look at my photos Link above.........
D1S at 50W in LH side OE D3S at 35W in RH side
GjrBartlett
