What load and speed rating on 1.8tQS tyres?
JAM35F
Am about to replace the pirelli 6000s on my car, they are at present: 225/45/17-91Y.
Am thinking about Bridgestone RE050 225/45/17-91W
Everyone has opinions on brands so that is not my question.
My question is does the lower speed rating (W) matter or do I need a Y rated tyre as it's available in both.
Also is the 91 load rating important on a quattro? Should I only get 91 rated tyres because of the quattros extra weight?
cheers in advance
AndyMac
Retired from service
Y = 186mph
W = a puny 168mph
So unless you're planning on caning it on the motorway at more than 168mph the W will be fine.
The load rating is really more to do with commercial vehicles. The extra few kilo's of the quattro system is neither here nor there, however if you regularly carry 3 fat yanks on the back seat then it may become an issue.
alijames
I'd like to see a fat yank squeeze themselves past the front seats to get in the back.
I find it tricky enough at >6ft & 12 stone!!!
Cheers,
aragorn
"Stick a V8 in it!"
Staff member
Moderator
the tyres load index translates to a weight in KGs:
http://www.tyreline.com/wheel_tyre_info/tyre_load_index.htm
As you can see 91 = 615KG.
This means that the maximum axle loading for your car, when fitted with 91 Load index tyres, is 1230kg. You need to compare the VIN plated "maximum axle weight" with this load index value, to ensure the tyres are legal. If your car was fitted with the aforementioned `91` tyres, and the axle loading was say 1300kg, then those tyres would technically be illegal, and if spotted by a jobsworth police officer they could technically fine you for them, even if your vehicle isnt loaded up to that weight.
I think 91 will be ok, but dont quote me on that, go check whats printed on the vin plate to be sure!
JAM35F
Wow what a comprehensive reply, thanks Aragorn.
I had no idea about the technicalities of load ratings. I'll have a look at the VIN plate tomorrow morning to check all is ok. As you say I doubt anyone would notice but now I know I may as well check.
As for that the speed rating I think I'll be ok with a W!!
JAM35F
Oh and thanks Andy Mac for the speed ratings. Brilliant site this, someone always knows the answer!
Siena
James, sorry to deviate here - you wouldn't fancy making me a banner like you've done on your sig?
jcb
get the highest you can for the moeny you are spending
and ditch those P6000....they are the worst tyres in history IMO!
JAM35F
I'm going to go for the Y rated tyres as they are only a few quid more, will get the best I can and not scrimp on tyres.
Yeah the P6000s are dire, looking forward to changing them.
Siena, would be happy to do you a sig picture as you've helped we with lots of advice since joining.
I'm a graphic designer so have used photoshop everyday for last 12 years or so, so is no trouble at all. Should be able to do something soonish as I'm off work with a broken hip so have lots of time to spare!
I'll PM you my email address then if you can send me some pics I'll sort something out. The more choice of pics you can give me the better and if they are large hi-res it helps with cropping options. If you have a rough idea of composition or text or colouring let me know that too. I can always do you a few options until you find something you are 100% happy with.
JAM35F
PM sent Siena, will try and do something special for you.
Mine still needs work, but they were the only pics I had to hand and it took me about 5 minutes.
