What is this ?
Ryan s3 Nov 6, 2018
  1. Ryan s3
    Ryan s3 Active Member
    238
    31
    A0667E34-F6DC-4FEB-97DE-5FADAED4459B.jpeg Hi
    Please look at the image attached.
    Coolant was leaking from it.
    It’s bolted to the cooling fan with torque bolts and 2 coolant hoses attach from each side.
    My car got hit by a lorry and must of happened from the impact.
    I’ve have bye passed it and need to order a new one.
    What is it’s purpose and do I need it??
  2. Avatar
    Google AdSense Advertisement
  3. <tuffty/>
    23,390
    4,987
    After run pump... yes you need it :)
  4. Ryan s3
    238
    31
    Thanks.
    So just ask for an after run pump ?
    Will order from TPS in the morning.
    Any harm in using car with out it for a couple of days ?
    What does it do ?
    I presume distributes coolant when not running or something like that ?
    Tomsy likes this.
  5. <tuffty/>
    23,390
    4,987
    Helps cool the turbo after you turn off the ignition...
    Be ok for a couple of days... not unusual for them to fail and leak
  6. Ryan s3
    238
    31
    I was just looking online and started to **** myself.
    I will order it in the morning.
    What sort of money are they ?
    Thank you as always !!!
  7. <tuffty/>
    23,390
    4,987
  8. Ryan s3
    238
    31
  9. Ryan s3
    238
    31
    TPS charged me £110 for this today. Expensive but needed, This car is expensive!!
  10. Ryan s3
    238
    31
    Just a bit of advice please. I have whining noise which I thought was the drive belt tensioner.
    I have removed the after run pump but it’s still connected electronically.
    I parked the car today and heard the whine when I walked away from the car and also when I went to get in before I turned the key.
    Will this be the after run pump trying to work.
    I have the water pump and will do it in the morning.
    Is this the likely cause for the whining?
    Thanks again
  11. <tuffty/>
    23,390
    4,987
    More than likely the pump... they do make odd noises when in the throws of dying and/or running dry
  12. Avatar
  13. Ryan s3
    238
    31
    Cool, Hopefully it stops raining so I can go put it on.
