dultanur
all promises, no action :)
when logging requested vs actual boost, how much would you say is normal, and how much is a boost leak?
dultanur said:ok. i guess my car has developed a problem, as it used to be just fine, now theres close to 0.1 bar loss...
what should i check? theres nothing obvious like hissing sounds and such...i haven't seviced my DV for 8000km, could that be it?
dultanur said:there are some irregularities with my logs, i guess i'll have to make a serious log run in 4th gear through the rev range to get some solid results.
jm-baker said:Foot down all the way. No fault codes. Seems strange how the boost spikes early on then drops off.
MAF peak's at 172 g/s @ 6440 rpm.
Could it be anything else other than the MAF?
dultanur said:ok. i'll do said things and get back to you once again. thanks for your help :icon_thumright:
dultanur said:about the N75, i have no idea but it seems to me that the N75 should keep seeing 100% until it gets the boost right...isn't that logical?
