JUS3IN
14.0 @ 98mph 2s 60ft
- Joined
- Mar 31, 2013
- Messages
- 1,159
- Reaction score
- 103
hey all, was thinking today how much my darn 8l s3 wouldve cost me if i werent handy with the spanners and without you guys, what have you replaced due to failure? what have you added too?
must be the most unreliable car ive owned! thank god for vcds!
add mileage and length of time owned.
149700 owned 22 months
chinese turbo fitted (previous owner) i removed and sent to bill for porting as overboosting
ball joint
rear brake caliper failed (nipple just started leaking and wouldnt stop!)
brake slave cylinder failed
crank sensor failed
coolant temperature sensor failed
thermostat failed
spun 2x big end bearings so minor bottom end re build possible due to blocked pickup so pickup and oil pump changed
fuel guage lieing, added fuel system cleaner to fix
2x maf
wiper mechanism seized
drivers door dropped (jacked back up)
turbo elbow pipe failed
sai failed (deleted now)
rocker gasket failed
coilpack failed
brake pedal fell off!!! bolted back on fine!
power steering pump failed
stuff to do
missing pixels on din
codes atm inc;
lambda sensor intermittent
brake switch intermittent
added all mods in my sig too!!
ball joint
crank sensor failed
thermostat failed
2x maf
coilpack failed
stuff to do
codes atm inc;
