  2. Dismiss Notice
What have you done today?
jojo Nov 17, 2013
  1. Daniel M
    Daniel M Registered User
    285
    96
    Gave the S3 (and my A4 avant) a good clean today.
    [​IMG][​IMG][​IMG][​IMG]
    One of the A4 for the sake of it.
  2. Avatar
    snack-media
    Advertisement
  3. Tj 0785
    Tj 0785 Registered User Bronze Supporter Silver Supporter VCDS Map User
    3,877
    1,185
    Wash the r32 today
  4. Daniel M
    285
    96
    S3 had it’s MOT this morning. Passed no worries
    DCH and hydro s3 like this.
  5. DCH
    DCH Registered User
    74
    40
    Fitted Forge FMIC kit that i picked up recently. Missing a few hoses, picked them up from silicon hoses for not much pennies. Coat of stove high temp paint, bit of a refurb to the headlights, replaced upper boost hoses, removed and painted grill inserts while bumper was off, and fitted a new LCR splitter. Happy with the outcome. MOT looms tomorrow.
    hydro s3 and Daniel M like this.
  6. hydro s3
    hydro s3 S3 amk
    1,365
    410
    What did you use to paint the grill inserts?
  7. DCH
    DCH Registered User
    74
    40
    I had some primer and topcoat left over from doing my blades. ( lower bumper inserts only)
    Car failed it’s MOT on power steering pipe leak ...looks like the o rings / crush washers
    DCH
  8. Oldskool Andy
    Oldskool Andy S3 APY
    23
    Fixed my remote case after trying to fit a new battery - the plastic was old and brittle but a bit of plastic weld goop and all is good :)
  9. hydro s3
    hydro s3 S3 amk
    1,365
    410
    @DCH Is p00 when ur car fails a mot cracks me up. That's for that about the spray. It say grey but urs on the car look black?
  10. DCH
    DCH Registered User
    74
    40
    Only failed on that leak .... thing is it only started this morning on day of test , typical . It’s definitely grey, the surrounds ( as well as the upper grill I went over with back to black .
  11. Alex C
    Alex C Well-Known Member VCDS Map User
    3,423
    412
    Hit 200,000 miles this week
    superkarl, DCH and <tuffty/> like this.
  12. Avatar
    snack-media
    Advertisement
  13. S3AMJ
    S3AMJ OEM+
    2,200
    787
    Jumped started the Bosses Rolls Royce Ghost......
    Power of the S3 ;)
    yoursixx, hydro s3, Tomsy and 3 others like this.
  14. DCH
    DCH Registered User
    74
    40
    Haha .... brilliant
    DCH
  15. MPH
    MPH Registered User
    711
    243
    43
    Had the same issues on mine ordered new bolts various sizes as a couple snapped got new torque wrench gaskets bolt remover etc bit of a pain but all worked out in the end good luck.
    Sent from my SM-G930F using Tapatalk
    DCH likes this.
  16. MPH
    MPH Registered User
    711
    243
    43
    I would definitely recommend a good quality torque wrench to do them up as they need to be evenly tightened in a certain order if I remember correctly if you do them hand tight gasket will probably end up with the same problem also the half moon joint on the right hand side needs a small dab of sealant as it can weep otherwise I also recommend using a good quality gasket in the first instance hope this helps.
  17. Daniel M
    285
    96
    Finally bought a non res Milltek system for the S3 which also came with a pipe werx decat :)
  18. anderswhk
    anderswhk Registered User
    234
    Timing belt, waterpump and thermostat. Getting that bracket which the RH engine mount sits on off was a nightmare and it wasn’t any easier getting it on either. There has to be some sort of trick to it. Raising and lowering engine didn’t help much either. Lots of fidgeting around
  19. anderswhk
    234
    Almost forgot, one of the 4 bolts that goes through the crank sprocket snapped off. That was fun
  20. Daniel M
    285
    96
    I also bought a pipewerx downpipe today
    Now have the joys of fitting everything. Not looking forward to doing the downpipe at all.
  21. Dohcwp
    Dohcwp Setting the Standard
    330
    185
    43
    bought new rear pads, discs and calipers, struggling to wind the old caliper back, it bent the plate of my caliper winding kit, so i decided to just stuff it and bought 2 new calipers instead, the old ones are 20 years old already give or take.
  22. Daniel M
    285
    96
    Picked up some turbo-downpipe nuts, gasket and engine cover screws from TPS and my powerflex dog bone bush and new spigot rings arrived.
    Those turbo-downpipe nuts and the engine cover screws are crazy expensive for what they are
  23. DCH
    DCH Registered User
    74
    40
    Managed to pick up a milltek exhaust myself, gave it a little clean and polish today. I’ll get the motor up on a mates ramp next week and see where this annoying blow is coming from. Depending on the outcome, i might be looking for a DP and sports cat as well, just a little undecided at the moment as I’m really not chasing power.
    sideways pic.... can’t be ***** faffing about changing that ....
    DCH
    Daniel M and hawesy25 like this.
  24. Erikn89nl
    Erikn89nl Registered User
    953
    388
    Technically it was yesterday, but I picked up a few bits for the old A3:
    Had these kicking around in some random geezer's shed for about 3 years... @Prawn
  25. <tuffty/>
    <tuffty/> Badger 5 Edition...Its all about the flow... Staff Member Moderator
    24,364
    5,601
    I know Prawns car is a little battle weary but its a bit harsh to call it a shed :)
  26. hawesy25
    hawesy25 Registered User
    89
    93
    Went out for the first proper drive in the S3 since purchasing it couple weeks ago. It needed all 4 tyres replacing so opted for Michelin Pilot Sport 4’s and they really have transformed the car.
    Absolute blast to drive and considering it’s age couldn’t believe how well it still performs!
    DCH likes this.
  27. DCH
    DCH Registered User
    74
    40
    Shows you how good my hearing and diagnosis is .....no exhaust issues, it was the alternator belt making bizarre noises. New belt and tensioner to order next week, get that and the milltek fitted then it’s off to hibernation it goes.
    DCH
  28. Daniel M
    285
    96
    Today I bought an almost mint condition cup holder for £35.
    Slowly gathering good condition parts to help the restoration.
    Mine will be going into hibernation in around a month. Although it’s sort of semi hibernating all the time.
    It’s being dropped off tomorrow night to have the downpipe fitted Tuesday. May book it’s cambelt and water pump when I drop it off too.
  29. jojo
    jojo Looking for Boost! Staff Member Moderator
    29,081
    3,822
    I’m just gonna leave this here. :D
    IPG, hydro s3, DCH and 1 other person like this.
  30. S3AMJ
    S3AMJ OEM+
    2,200
    787
    You kept this very quiet mate! Nice results
  31. DCH
    DCH Registered User
    74
    40
    Picked up the battery surrounds parts from work, kindly sent from S3AMJ. I’ll then finally get to fit my cover. Cars been washed waxed and tucked away for a month, but got the car cover off today removed battery and it’s now on charge. Also took laptop home from work and dug the vag com lite lead out. I’ll scan it tomorrow because before i tucked it away it had started lumpy cold start and getting worse as temps get colder. I’ve replaced the CTS, thermostat yet to fit and I’ve got a spare set of 2nd hand coils and new spark plugs so I’ll tinker away until hopefully that’s fixed. And in other news I think I’ve bagged a front bumper for spares, with all the grills and lower inserts, h/l washers all present, for a steal.
    Now away crack open some fine ales and eat loads of cheese and biscuits with caramelised onion chutney
    DCH
  32. jojo
    29,081
    3,822
    It’s mainly on my personal Facebook page, and this car isn’t the most reliable car, it’s jinxed even! Lol
    I may create a thread on my build soon though.
    Rainbird and S3AMJ like this.
  33. Avatar
    snack-media
    Advertisement
  34. S3AMJ
    S3AMJ OEM+
    2,200
    787
    Ah yes bookface I don’t have that. Deffo do a right up on here honestly..... you find me a reliable S3 and I’ll buy it haha. Mine has decided a week before the MOT to give me some grief! They know I tell you, they just know it. Dam cars
  35. S3AMJ
    S3AMJ OEM+
    2,200
    787
    Got the car MOT’d with my friendly tester passed with flying colours....
  36. <tuffty/>
    24,364
    5,601
    Today I mostly watched while some fella dug a hole...
    FB_IMG_1575748567826.jpg FB_IMG_1575748548136.jpg Screenshot_20191207_195843.jpg Screenshot_20191207_195905.jpg FB_IMG_1575748590206.jpg
    jojo likes this.
  37. Tj 0785
    3,877
    1,185
  38. HOGG
    HOGG Registered User
    851
    284
    Mot bay?
  39. <tuffty/>
    24,364
    5,601
    Yes and yes...
    Nah... Please see above :)
  40. S3AMJ
    S3AMJ OEM+
    2,200
    787
    Omg this is happening?! Exciting times! Roll on the big move.... my services are still available @badger5
    Tj 0785 likes this.
  41. Tj 0785
    3,877
    1,185
    4wd dyno?
  42. <tuffty/>
    24,364
    5,601
    Yarp :)
    S3AMJ likes this.
  43. S3AMJ
    S3AMJ OEM+
    2,200
    787
    I’m keen to get my car on there to see what she kicks out on the new system. Did Bill get an answer on being able to get comparisons like his current system.
