  2. Dismiss Notice
What have you done today?
jojo Nov 17, 2013
  1. djarchive
    djarchive Member
    295
    9
    Changed my coolant temp sensor. (Green plug (4 pin) for a new Green plug (4 pin) from Euro C.P. + then put a litre of G12 coolant in.
    Wasn't half full of **** / slime.
    • Job's a good-un & running like a dream :D
  2. Avatar
    snack-media
    Advertisement
  3. StaceyS3
    StaceyS3 Well-Known Member
    2,514
    520
    Turbo Tuesday and been dreaming of boost!
    Smallest below is a gt35
    Can’t wait to see what it can do
    SamHendry, Rainbird and S3 Hilife like this.
  4. badger5
    10,205
    2,374
    thats what you will say whilst waiting for it to spool up :p
    craigt1985, Rainbird and S3JACKSON like this.
  5. StaceyS3
    2,514
    520
    That’s what launch control and flatshift are for.
    Should still have around 4000rpm on decent boost, about the same as the average GT30 lol
  6. badger5
    10,205
    2,374
    what you planning on revving it to?
    i fear for your gearbox with your kill rep on them.... eak!
  7. StaceyS3
    2,514
    520
    High enough lol, hoping for another 800 or so rpm more than previous.
    Should be livelier off boost with high comp and sooner boost onset with different fuel
    Will be full dog kit as OEM wouldn’t stand a chance in hell against this probably on actuator
    Rainbird, SamHendry and superkarl like this.
  8. Warsuperior
    Warsuperior Active Member
    505
    67
    Rennsport intake ready to be bolted to engine. Sorry for bad pictures.
    Fits to your engine bay and you can close hood. <-this was what some people wondered
    NIGE28, andrew_wright and hydro s3 like this.
  9. SamHendry
    SamHendry Active Member
    827
    165
    43
    Ap coilovers I hv sitting in my garage need some tlc, but having done only 7k and barely 2 years old they only really needed cleaned up and coat of paint on strut springs, will be on offer in classifieds soon,
    After
  10. BenS3270
    BenS3270 New Member
    Any one help me ? Have a slight issue of knocking/rattle on front end when driving over in even road surface... taken it too three different garages and they cannot seem to find what it is .... any help appriciated
  11. <tuffty/>
    23,984
    5,367
    I assume from your profile pic you have an 8P S3... you would be better off asking this question in the correct section dude... this is the earlier 8L section and this thread isn't really for asking questions in...
  12. Avatar
    snack-media
    Advertisement
  13. StaceyS3
    2,514
    520
    At 6 gpm this will empty any tank in no time
    SamHendry and IanPG like this.
  14. bbb76
    bbb76 New Member
    21
    Replaced the clockspring and made the airbag light go out. Yay!
    Have replaced it with the ESP light instead. Boo!
    VCDS Lite says 00778 incorrect or no basic settings at least the light is orange and not red.
  15. bbb76
    bbb76 New Member
    21
    Have now got a fully working rear wash wipe. Pushing the washer stalk resulted in a puddle under the engine, reconnected the pipe under the black trunking behind the air-box. Sense of achievement rapidly disappeared as a pool of washer fluid rapidly appeared behind the rear wheel. Took out the trim panel, cd changer ad sub reconnected the other joint and all working.
    Wedged by the sub and covered by foam padding is something that looks like a pump with a blue and yellow hose connected to it, the hoses look to run under the boot door and into the off-side trim panel before joining a red and black set of hoses. What are they for??
  16. <tuffty/>
    23,984
    5,367
    Central locking...
  17. bbb76
    bbb76 New Member
    21
    Compressed air? - you live and learn. Cheers
  18. RS4B5
    RS4B5 5 pots
    547
    210
    43
    Started the a3 today and cleaned it after standing for six months starts first time every time most reliable car I've ever owned although there is a water leak straight in the bottle straight out its coming from the back of the block???
  19. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,416
    411
    6 gallons per mile...!!
  20. StaceyS3
    2,514
    520
    Haha probably not to far off! 6 gal per min (about 1600 litres per hour) at 100 psi for the pump though at 8k iirc. Will flow even more at higher rpm
    If calcs are correct will do up to 4 litres per run down the strip
  21. Dohcwp
    Dohcwp Setting the Standard Team Silver Audi A3
    270
    129
    43
    coolant reservoir cap wasnt holding pressure anymore so decided to replace both the cap and reservoir as the old one was beyond tatty looking, i can see my coolant level now yay. bled the system afterwards, everything flowed freely, doubt there was much air in it
    jojo and S3AMJ like this.
  22. Tj 0785
    Tj 0785 Well-Known Member Silver Supporter VCDS Map User Bronze Supporter Audi S3
    3,301
    955
    296D765C-854F-4E9F-AB30-9409DDEC9DEA.png 4B100237-DED8-4E07-A3CA-0556F257DF20.png Not really s3 related but gave the r a good wash
    Can’t wait to unwrap the s3 and start rebuilding it few more months and than the transformation begins as amazing as the r32 sounds I just don’t get the same enjoyment as from the s3
    SamHendry, S3JACKSON and S3AMJ like this.
  23. GeorgieS3
    GeorgieS3 Active Member
    324
    75
    Nice mate, what you got planned then? Just collecting more bits? Looking forward to see what you make of it.
  24. Stuart B
    Stuart B Well-Known Member
    3,448
    742
    Very nice golf
    Tj 0785 likes this.
  25. Tj 0785
    3,301
    955
    I’m thinking v6 turbo route as price wise there’s probably not much difference than full rebuild and gt30/35 and can run on less boost on the 3.2 with gt 30/35 and standard internals and do them over time plus the v6 sounds better . I don’t want to rush it but I want it done cars been off the road 2 years now and it kills me walking past it everyday. I pick up the 18z calipers for it on Monday from powder coating aswell
  26. Joewhyte97
    Joewhyte97 Member
    64
    20
    Started striping it put for cutting and sorting soon, 6 months without it and its driving me mad!
    [​IMG][​IMG]
  27. Tj 0785
    3,301
    955
    What’s up with it?
  28. GeorgieS3
    324
    75
    Sounds exciting! You going to use the motor from your R then? I often get tempted to chop mine against a nice mk4 r32 - but then I go for a blast and can’t being myself to do it
  29. Tj 0785
    3,301
    955
    No the mk5 r32 engine won’t work plus that will be sold/ traded in at some point. I’m going to get a mk4 r32/mk1 tt engine or the 2.8 4motion engine
  30. Joewhyte97
    Joewhyte97 Member
    64
    20
    Ilegal immigrants smashed in to a van that i then went up the **** of back in December, my insurance refused to cover me as in my small print i wasnt covered for traveling to and from work even tho i selected social and domestic so after getting all the parts i need bar a headlight my mechanic is now getting ready to sort her up[​IMG][​IMG]
  31. Tj 0785
    3,301
    955
    C0BF9AB5-3646-4458-92BC-289192A78534.jpeg 16B2CCBA-B658-4285-A32C-7E667071F528.jpeg 3F6E13D8-4B7D-47C8-9F30-9B3E1C27AC23.jpeg 1BDBB369-DCB5-4C75-A446-B904378F39CF.jpeg PIcked up my 18z calipers from powder coating. Wish I didn’t I’m happy with the colour but the paint finish looks terrible think il be sanding them down and painting myself like I was going to do in the 1st place
  32. S3AMJ
    S3AMJ OEM+ Team Brilliant Black Audi S3
    1,674
    502
    liking the colour TJ, but yeah that paint job is a bit rough! I wouldn’t be happy with that either. Maybe you could use some fine sand paper to even it out and cover with clear VHT?
  33. Avatar
    snack-media
    Advertisement
  34. Tj 0785
    3,301
    955
    Yeah I can’t belive it took them a week and it looks like a rushed job can’t believe they let them go out like that. Told them when I dropped them off that I’d have more bits to get done like the tears and some engine bits but won’t be going there again
  35. S3AMJ
    1,674
    502
    I think I could have done better job with a dirty paint brush and on eyes closed. Not acceptable. Hope you can square it away and get them looking how they were intended to be.
    Tj 0785 likes this.
  36. warren9022
    warren9022 Active Member
    466
    216
    43
    I’d be taking them back and asking for a refund mate. Don’t let them get away with that.
    I did mine with a dremel, sandpaper, wire brush, VHT primer, paint and clear coat with no previous experience and it still puts that ‘professional’ job to shame.
    S3AMJ likes this.
  37. S3 Hilife
    S3 Hilife It's an addiction Team Dolphin Grey Gold Supporter VCDS Map User Audi S3 quattro
    968
    593
    93
    TJ are those pistons in backwards? They look odd and no dust seals visible
    Love the color but it’s a shame about the finish, that’s terrible workmanship. Hope you are able to send them back to be done properly
  38. Tj 0785
    3,301
    955
    Ha no no pistons or seals fitted yet will be doing that when the new pistons arrive. The old pistons were chipped/ damaged It seems each Caliper has 3 aluminium pistons and 3 phenolic pistons which I didn’t realise until I went to order them
    S3 Hilife likes this.
  39. S3 Hilife
    968
    593
    93
    Haha, that would explain it :)
  40. S3JACKSON
    S3JACKSON Active Member
    168
    85
    Thinking of retro fitting heated seats, brought a set of heated seats for the heating elements to fit in my mint seats
    Lots of work but i know more about Recaro's seats now:chuncky:
    ToughlilT likes this.
  41. Dohcwp
    270
    129
    43
    Scored this deal during the week
    S3AMJ likes this.
  42. imz
    imz Member
    353
    Will the airbag and buttons work mate?
  43. Dohcwp
    270
    129
    43
    airbag = yes
    Buttons = Maybe, and the primary reason is if i was running an RNSE then i would need to fit a4 8k buttons since they're based on an older version of the lin gateway that is compatible with the a3 8p steering control module, im running an win ce hybrid headunit however and im hoping my canbus emulator will be able to communicate with the newer 8v gateway otherwise ill just have to fit the a4 button set also. but steering controls is doable
