  2. Dismiss Notice
What have you done today?
jojo Nov 17, 2013
  1. AdzA3AGU
    AdzA3AGU Active Member
    180
    26
    Just got off the phone from AH Fabrications I should have my V2 Intercooler by weds/Thurs Get it fitted then Saturday and up to Badger5 Tuesday for a map :)
    Pubemammal likes this.
  2. Avatar
    snack-media
    Advertisement
  3. Dohcwp
    Dohcwp Setting the Standard Team Silver Audi A3
    275
    134
    43
    Finally fitted the Facelift Vents this weekend, definately not a five minute procedure
    Last look at the PFL Vents before removal
    after removal i had to use the soldering iron to pierce a hole in the venting and then made it bigger with a screw driver
    After feeding in the wiring i connected it to the led of the ashtray so that it also works with the interior dimmer
    FL vents then fitted
    and voila job completed
    AdzA3AGU and jojo like this.
  4. IanPG
    IanPG Well-Known Member Team Nogaro Blue Audi S3
    1,841
    778
    what headlight switch are you using?
  5. Dohcwp
    275
    134
    43
    its an A6/S6 C5 FL headlight switch, requires quite an extensive bit of trimming to fit, i still need to make some minor trimming and adjustments before i'll be satisfied with the final fit
    IanPG likes this.
  6. jojo
    29,072
    3,799
    Getting my turbo rebuilt and hopefully book in a remap slot sometime soon!
    AdzA3AGU and Erikn89nl like this.
  7. vanilla_ice
    vanilla_ice Active Member
    796
    37
    Going hybrid?
  8. jojo
    29,072
    3,799
    Thought about it, but decided not to, as I'm running standard internals. Not really chasing 300bhp to be honest.
  9. Replaced tired hatch struts with Nitro-lift struts. What a difference, highly recommended!
  10. vanilla_ice
    796
    37
    Got link? Easy job?
  11. Avatar
    snack-media
    Advertisement
  12. jojo
    29,072
    3,799
    Rebuilding the turbo in the boot of my A6! lol I was suppose to get it rebuilt at the time of getting the CHRA, but my mate felt the hotside was too filthy, so took it away to shot blast it all clean, so the turbo is now fresh as a daisy for fitting! :)
  13. Broken Byzan
    13,232
    470
    The sealer for the comp cover?
  14. jojo
    29,072
    3,799
    I think so.
  15. Sam_
    Sam_ Down under
    3,061
    514
    New rad (old one leaking):
    New tyres:
    AdzA3AGU likes this.
  16. AdzA3AGU
    180
    26
    Got my New AH Fabrications V2 on the Car Saturday and with some light modifications she is sitting lovely!! FMIC.jpg
    Also got new Tires up front as my inner Edges were a tad knackered, Went to the fitters with the idea of getting Toyo Proxes T1 Sports however when i got there they had a pair of ContiSportContact 5's to be sold at cost as someone had driven all of 5 miles on them and decided he dident like them and brought them back. £60 a tyre and they still had the fresh markings in them. So far a brilliant tyre, Gives excellent feel and turn in response but they are a tiny bit harsh at Motorway speeds
  17. fingermouse
    fingermouse thats me
    4,233
    195
    duff alternator removed,
    cam belt and water pump replaced.
    New alternator tomorrow with a new belt and tensioner then put her back together and check to see if I have a power steering leak.
    then Holiday :)
    jojo likes this.
  18. AdzA3AGU
    180
    26
    My trip to Badger5 yesterday was thankfully quite a success!!! More than impressed with what he has done with the car and it now drives Spectacularly! few bits to get for the car now such as a maf and a new fuel pump and then she will be right as rain until its time to go hybrid.
    Also extra thanks to bill for increasing my knowledge on the 1.8T engines!!
    Now for the bit you actually want to Read.
    scotty_24 likes this.
  19. Nathan Barnes
    Nathan Barnes Active Member
    152
    46
    Fitted one 4mm macrolon (perspex) window before it started raining again.
    One of the joys of living in Wales.....
  20. AdzA3AGU
    180
    26
    Fellow Welshy here bud i feel your pain haha
  21. IanPG
    1,841
    778
    Cleaning out this one
    (plastic?) **** stuck in the suction pipe
    Them stock rods... gotta change that
    No joke - sump is cleaner than the interior LOL
    S3 Hilife and AdzA3AGU like this.
  22. sparkysi90
    sparkysi90 Member
    33
    What's your suspension set up?
  23. Mark Greenall
    Mark Greenall Member
    188
    17
    Done the rear axle bush's and front brakes. Rear axle bush's took an hour and a half reasonable easy once I hammered them out.
  24. Mark Greenall
    188
    17
  25. Mark Greenall
    188
    17
    Brakes
  26. IanPG
    1,841
    778
    s3/k04??? what's the process of removing the turbo without having to rip everything else apart?
  27. jojo
    29,072
    3,799
    Undo the manifold from the block with the turbo attached was how it came out on my S3. I'm also running a 3" down pipe, this was the easiest way?
  28. IanPG
    1,841
    778
    I ask cuz I wanna port out my turbo and would rather not pull the head if I don't have to. I also have 3" DP. I'm all good disconnecting that after pulling the sub frame. After that I've not tackled anything further.
    So assuming this is the way
    - remove everything above to undo top DP nut
    - get under and undo subframe and rack and let it dangle
    - undo DP (remove?)
    - undo mani
    - undo tip & turbo oil and water lines
    - Lift out mani and turbo as one???
    I know most of the nuts on the driver's side are accessible. What about the ones behind the turbo?
    Any special tools needed to detach the manifold?
  29. jojo
    29,072
    3,799
    I wish I could answer you bud, but my mate is tackling it for me. He told me it was easy to undo the manifold and remove from the top. Exhaust and dp is still in situ, turbo was lifted off with mani as one unit.
    IanPG likes this.
  30. S3JACKSON
    S3JACKSON Active Member
    168
    85
    Took my car to AITP and put it on the ASN stand
    Had some nice comments about the car which made my day
    Some nice cars on the S3 Owners Group stand
    IanPG likes this.
  31. S3 Hilife
    S3 Hilife It's an addiction Team Dolphin Grey Gold Supporter VCDS Map User Audi S3 quattro
    968
    593
    93
    As I missed out on AITP again I thought I'd crack on with some pipework upgrades I had ordered a 63mm MAP pipe from Stuart at IWS Developments which replaces the restrictive OE pipe. I also ordered a 63mm-60mm reducing elbow, 63-70 reducing elbow, 70mm swaged alloy pipe (100mm long) a 70-64mm reducing elbow and a 70-80mm reducing elbow (for when 80mm tb is fitted)
    Which kind of looks like this:
    Pulled out the old, and took a comparison shot:
    And set about trimming and fitting the new
    Fits really well and should hopefully be a good improvement
    Steve
  32. Avatar
    snack-media
    Advertisement
  33. Sam_
    Sam_ Down under
    3,061
    514
    Hey mate, it's got:
    - H&R RSS Clubsport Coilovers
    - Ground Control top mounts
    - Tubular control arms front (IDF) and rear (Gruvenparts/Mad Max)
    - Solid front subframe mounts (Tyrolsport)
    - Solid steering rack mount (Tyrolsport)
    - Rear rose jointed drop links
    - Vibratechnics top engine mounts and ECS billet dogbone
    - Team Dynamics Pro Race 1.2 17x9 ET15F/20R with Yokohama AD08R 235/40s
  34. Tj 0785
    Tj 0785 Well-Known Member Silver Supporter VCDS Map User Bronze Supporter Audi S3
    3,496
    1,019
    image.jpeg image.jpeg image.jpeg Not car related but started dismantling my pond I dug this out with just a shovel and graft! And built in in the evening after work was fairly big at 16000ltr but need garden back for little un it did get a proper rendering (mine fell off) but not pics of that image.jpeg image.jpeg image.jpeg
  35. syncro
    syncro Active Member
    226
    78
    [​IMG][​IMG] [​IMG] [​IMG] [​IMG]
    I got a mk2 TT airbag cover off e-bay and a round airbag from a 6n2 polo and made a single stage airbag for my 8P S3 fbmfsw, I tried a few different vw/audi airbags before I found one the right size, it just needed an adapter bracket fabricated to mount the polo bag in place of the TT one.
    Next job is to get the multi-function buttons to work the rns-e
    AdzA3AGU, Dohcwp and vanilla_ice like this.
  36. S3JACKSON
    168
    85
    Front fog lights coming on with side lights
    Dreaded window clip broken
    Visited the trade counter at TPS today :sunglasses:
    Mav190sline likes this.
  37. IanPG
    1,841
    778
    bit of this - bit of that
    Relay added (above 53/100) for any accessories i want to run)
    accessory 1
    accessory 2 & 3 are mono block and 4 channel amp which are hidden :D
    accessory 4
    Dohcwp likes this.
  38. A3-Lee
    A3-Lee Active Member VCDS Map User
    939
    226
    43
    Lies lol
    undo the 3 turbo to mani bolts then undo mani to head bolts remove mani undo everything else remove turbo from top why people remove the head is beyond me .... Should be fitted up soon mate just finding time
    IanPG and jojo like this.
  39. jojo
    29,072
    3,799
    I was close! :laugh:
  40. IanPG
    1,841
    778
    Are you taking about s3 or a3???
    I know on an a3 access is available to do that. S3 different story
  41. <tuffty/>
    24,105
    5,459
    Have removed K04 turbos from S3's 'easily' with not removing the head on the std manifolds... they are a little more awkward than K03's for sure but doable... probably getting confused with the work required to fit old relentless manifolds as they were a complete c*** to do...
    IanPG and AdzA3AGU like this.
  42. AdzA3AGU
    180
    26
    [​IMG]The next Job, Turbo died last week due to the oil pump being a tad old i think.
