  2. Dismiss Notice
Dani_B19 Feb 12, 2016
  1. Sidrick
    Sidrick Well-Known Member
    467
    311
    Calipers?
  2. Avatar
    snack-media
    Advertisement
  3. I'm Just Rob.
    I'm Just Rob. Moderating or something, Staff Member Moderator Regional Rep Gold Supporter VCDS Map User
    14,221
    6,753
    It was late last night scott , very possibly yes, I started writing down p/n and comparing then fell asleep.:sadlike:
    Just looking back now at another old thread by James c on the same upgrade.
  4. I'm Just Rob.
    14,221
    6,753
    do you have the caliper p/n for your original calipers and also the p/n for the s4 carriers?
    Maybe send them over and i'll compare them to the list I started comparing, well if you are still thinking of doing the swap.
    Rob
    Sidrick likes this.
  5. docurley
    4,084
    94
    Did some headlight work
    Bobbytea and Dan_Avant like this.
  6. Bobbytea
    Bobbytea Active Member
    164
    110
    43
    Hi Sidrick,
    I’ve done the S4 carrier upgrade and yes the gap is tight to the disc. However I’ve been running them now for quite some time and have not had any witness marks on the callipers showing the discs have touched (the paint hasn’t even been marked). I’ve got them plenty hot enough too - I would’ve liked a little more gap between the disc and the callipers but so far so good.
  7. Pie-eyedpiper
    Pie-eyedpiper Active Member
    504
    231
    43
    Are the calipers and carriers a lot larger and is it a worthwhile upgrade?
  8. Bobbytea
    164
    110
    43
    Took my disc size from 320mm to 345mm, handy increase in braking performance and fade resistance especially when you’ve upped the HP. Gives you the confidence to push on a little harder.
    No change in calliper size as it’s the same size as the 320mm Special Ed’s - possibly a different part code as the previous posts mention.
  9. Pie-eyedpiper
    504
    231
    43
    Thanks.
    Is it just the carrier size that changes then?
  10. Bobbytea
    164
    110
    43
    Yep just the carrier changes, oh and of course the discs change.
    Pie-eyedpiper likes this.
  11. Pie-eyedpiper
    504
    231
    43
    Thanks for that Bobby.
    Do you happen to have the carrier part number at all?
  12. Avatar
    snack-media
    Advertisement
  13. Sidrick
    467
    311
    I went with 1K0 615 125 B.
    Interested to hear if that's what others had.
    I believe 8E0 615 125 C is an option but the only difference is those are painted black.
    I'll have new discs and carriers for sale....
  14. HOGG
    HOGG Well-Known Member
    839
    279
    Needs less amber in the headlights
    Sent from my SM-G930F using Tapatalk
  15. UisT4
    UisT4 Active Member
    111
    101
    43
    Primer done on wheel #1. Doesn't look too bad considering it had a bit of kerb rash.
    Two of the others are in pretty good shape so just need keying and the last one is a bit rough but hopefully not need any filler...
    #NotPerfectButGoodEnough
    I'm Just Rob. and Sidrick like this.
  16. BakPak
    BakPak No Gear
    1,484
    218
    Very well done. Where do I start lol!
  17. UisT4
    UisT4 Active Member
    111
    101
    43
    230 grit paper, bucket of soapy water and some beer, well that's my afternoon anyway
    Sidrick likes this.
  18. Shaun Osborne
    Shaun Osborne Member
    127
    10
    Dan_Avant likes this.
  19. BakPak
    BakPak No Gear
    1,484
    218
    Stella obviously
    Sidrick likes this.
  20. Ricky Burrows
    Ricky Burrows Well-Known Member
    1,478
    725
    Yeah thats what i had planned looks good subtle but enough of a difference to be worth doing.
  21. TOM.S
    TOM.S Active Member
    617
    159
    43
    interior upgrade vol2 more red & black bits...
    20200411_162329.jpg 20200411_162358.jpg 20200411_162350.jpg 20200411_162340.jpg 20200411_162312.jpg 20200411_162300.jpg 20200411_162245.jpg
    next up rear view mirror, headliner , boot.
    Any ideas on how to turn the headliner black the most cost,time effective way?
  22. David Cox
    David Cox Member
    102
    23
    Only seem to post when have a problem, so here's what I've done today.
    Replacement rear spring on the avant, noticed one side sitting slightly lower, so ordered some eibach springs, but they are delayed due to current situation so fitted a standard one until they arrive.
    Also have finally upgraded the front discs to 320mm from memory, hopefully they will feel better than the original ones. Brembo discs and pads, fill the 18" wheels a bit better too.
    Might even get round to dropping front bumper and fitting the mesh grille that's sat in the shed for a while, centre armrest and few other bits, if weather holds and still lockdown. Other cars have been sorted before the Audi lately.
    Sidrick likes this.
  23. David Cox
    David Cox Member
    102
    23
    One mid fitment shot too.
    UisT4 likes this.
  24. Pie-eyedpiper
    504
    231
    43
    "What did I do to my A4 yesterday".
    Here's my B8 seats fitted. They upholstery needs a proper clean though.
    (the armrest lid is mid change). Leather door cards also to be fitted
    DHL delivered the last parts of my rear seats today, the backrests. And I have to say they look lovely. Will photo when fitted.
  25. I'm Just Rob.
    14,221
    6,753
    Today I was due to be working but a change of client plans meant I managed to get the day off, so a bonus there.:yahoo:
    Sun was out so decided to address some ongoing issues .
    Off with all the wheels and gave them a good spanking clean both sides, I do like clean alloys on both sides, a few minor marks but still happy with them.:icon thumright:
    Found a split in the inside edge sidewall , not good as they are not that old so i'll be having words with my tyre centre that fitted them , well when they are back at work that is.
    Started out with a plan to pressure wash under wheel arches but my pressure cleaner threw a wobbly within the first minute so had to use the manual method of a bucket of soapy water and stiff brush.:yes:
    Worked to a degree and at least I have clean dampers and springs now, but also found my damper bump stops have disintegrated on both sides so i'll need to order a set, they are the oem ones from the original s-line dampers so cant really complain.
    On the front I gave it a clean and all seems ok but my Brembo's are looking very tatty now after a good few years so a refurb is on the cards in the next few weeks as the 8 pot set i wanted are not available now until November:sob:.
    I've been planning on a repaint for sometime but just kept putting it off , seems like I cant delay any longer and just need to decide on colour.
    So all those bits done it was time to mess around with wheel spacing , replaced the fronts and rears with different thickness spacers so now on effective offsets of, ET27 on the rears and ET31 on the fronts .
    That is about it for today, I was going to give the old bus a wash aswell but that may have been a step to far in one day for it..lol
    piccy's as we all like a piccy or two.
    AvantMike, TOM.S and David Cox like this.
  26. BakPak
    BakPak No Gear
    1,484
    218
    Don't like that tyre split at all, is it bulging?
  27. I'm Just Rob.
    14,221
    6,753
    No its not as yet but a bit of a concern , I have seen a few reports of Avon zz's suffering from sidewall splits and cracking etc so i'm going to have words with avon as they are only a couple of years old and not even half worn yet.
  28. Sam1989
    Sam1989 Active Member
    157
    127
    43
    B5149DE2-8352-4A43-A24D-9E6DA7DF5997.jpeg Today I fixed my cup holder :yahoo: Nothing exiting but it’s been getting stuck and was driving me mad before isolation. Got quite a few 034 mounts on the way from awesome gti so look forward to getting stuck into them once they arrive!
    Bobbytea, AvantMike, TOM.S and 2 others like this.
  29. Shaun Osborne
    127
    10
    Are the B8 seats a straight forward swap?
  30. Pie-eyedpiper
    504
    231
    43
    Absolutely, they bolt straight in, everything lines up.
    The only issue is with the seat wiring harness. It depends what functions you have. Mine were only basic anyway, non-heated, non-memory. I have had to change my airbag plug over to my original one too, soldered and heat shrink.
    Big improvement though, especially over my cloth B7 originals.
    Shaun Osborne and I'm Just Rob. like this.
  31. AvantMike
    AvantMike Active Member
    306
    166
    43
    Few cosmetic bits whilst working on grill mod.. replaced logo with gloss black & de-badged the Sline badge i'd stuck on there last year.
    Ricky Burrows and Shaun Osborne like this.
  32. Ricky Burrows
    1,478
    725
    Looking good mike looking forward to seeing it with the wheels on as were in lockdown can you tell us what wheels you have now? pweaaaseeeee
  33. Avatar
    snack-media
    Advertisement
  34. I'm Just Rob.
    14,221
    6,753
    Been doing some thinking and browsing , I've decided to do my Brembo's ….
    Yep Banana split yellow and before you all fall over in shock and horror I think it suits a black bus very well.:yes::yahoo:
    AvantMike, Sidrick, David Cox and 3 others like this.
  35. i3oricua
    i3oricua Well-Known Member
    665
    310
    Congrats Rob. Great color choice. I just repainted mine this weekend.
    Sent from my ONEPLUS A6013 using Tapatalk
    Sidrick, David Cox and I'm Just Rob. like this.
  36. I'm Just Rob.
    14,221
    6,753
    I love Red calipers well I have them at the moment , just fancy a change , something a bit more on the edge appeal.:yes:
  37. I'm Just Rob.
    14,221
    6,753
    Did you do them insitu Edgar or remove them to repaint?
  38. i3oricua
    665
    310
    I removed completely off the car. Had to rebleed the system but that was fairly easy with my son helping. Took about two days since I wanted to make sure the paint cured decently well.
    I'm Just Rob. likes this.
  39. Pie-eyedpiper
    504
    231
    43
    I do like the yellow against a red or black car. Red is good, but with a red car I think is too much.
  40. Pie-eyedpiper
    504
    231
    43
    Fitted my half leather rear seats today.
    I know they don't match my B8 fronts, but B8 rears won't fit without serious modification and I could find any B7 half leather fronts. All just need cleaning now.
    Also being from Germany the rear seats have the through ski bag option. Ideal when on the piste in Lincolnshire!
    AvantMike, Sidrick and I'm Just Rob. like this.
  41. BakPak
    BakPak No Gear
    1,484
    218
    Yellow calipers (especially with Porsche) get massive kerb appeal behind a black wheel.
  42. I'm Just Rob.
    14,221
    6,753
    They look nice but you really need to loose the rubber floor mats and get some carpet mats, would make all the difference.:icon thumright::yes:
  43. Pie-eyedpiper
    504
    231
    43
    Thanks Rob.
    I've had carpet mats in the past, but they but never stay clean long and the heel pad wears through. Rubber don't look as good, but are far more practical.
    AvantMike likes this.
