dave_ph
Active Member
The off set (Et) might be different e.g et35 or et40
Yeah good shout I think they are. I’m thick when it comes to wheels, what issues if any would that cause?
Jamal Miah
Basically it’s the centre line of the wheel. At worst you might need to run 3 or 5 mm spacers.
dave_ph
Active Member
Thanks mate :)
Jamal Miah
I finely fitted the S4 front brake on and stainless steel braided hose on the Avant tonight
I'm Just Rob.
Moderating or something,
Staff member
Moderator
Gold Supporter
Yep very pleased with them, managed to find a good used mirror glass on eBay after being let down with an online company, will stick a pic up later.
boffin486
Didn't really want to but........ Got the Avant back up in the air to raise the front suspension back up a bit..... :frown new:
Love the look of it but can't live with the grinding of underside on anything higher than a fag packet.......... Also had some pretty heavy impacts when not treating speed bumps with enough respect......
Only going up 10mm to see if its better. :yes:
Of course that also means messing with the camber & tracking again . Oh Lordy........
I'm Just Rob.
Staff member
Moderator
Gold Supporter
Been out today a dinged two more alloys, both on offside on raised manhole covers, I maybe going back to 18" 8j with 235/40's on them, cant be dealing with all this rim dinging all the time …..235/35 on 8.5j don't make it any better either, slightest bump or manhole protruding catches the rim edges....arghhh
boffin486
I feel your pain Rob - used to have 35 profile tyres on one of my Calibras (in fact they're still on it) & suffered a lot of punctures (inner sidewall) from going over speed bumps/branders/stones - in fact damn near anything. Rims would also catch on anything sticking up more than an inch. Really annoying & pocket damaging......... :grumpy: I actually had to replace a tyre that was only about 1/4 worn once and a week later got a sidewall puncture that wrote the brand new tyre off! Oh happy days.
I'm Just Rob.
Staff member
Moderator
Gold Supporter
It's only become an issue since going to an 8.5j, when I had the 19" rs4 style rims on which were an 8j with the same 235/35 tyres it wasn't an issue , but 8.5j and 235/35 does appear to leave the rim lips much more exposed to contact damage due to the tyre stretch , it's not a lot but of stretch but enough to make the difference with the tyres I have fitted.
I'm looking at some new 8j's today so hopefully that will help resolve things as I do like 19" to be honest....so out goes the new recaro's for now….bummer or what.
I'm Just Rob.
Staff member
Moderator
Gold Supporter
Just been comparing profiles a 245/35 19 maybe a help with the problem as its less stretch across the rim, almost cancels out the stretch with the 235, and only 4mm tall overall compared to a 235/35 so may have better rim lip protection especially when cornering etc.
I'm Just Rob.
Staff member
Moderator
Gold Supporter
I've already got XL .
LloydB7
Just dropped my new (to me) DTM wheels off to Southwest Wheel Repairs to have them refurbished and changed to Titan grey. Been forced to do them a bit sooner after hitting a rather deep pothole last week and now have a very square BBS CH
P
Pedrödelabongo
Guest
I fitted a new headlight switch surround and twisty bit - the old ones had worn quite a bit. Less than a sick squid from the Bay of E and less than five minutes to fit.
i3oricua
Changed my headlight bulb today....
Man this was way more involved than I thought. Tomorrow I’ll swap everything over to my forged block and hopefully start putting it back in by the end of the day. Taking off the head will be interesting. Never done it before so I have to do some reading if I can find anything on how to do it.
I'm Just Rob.
Staff member
Moderator
Gold Supporter
looks like a fair bit of work Edgar, allways nice to see an ongoing project take shape....:icon thumright::icon thumright::yes:
Just noticed you are running a non standard valve cover, looks great, can I ask where you sourced it and any details .
good work chap :salute:, you can do my old bus next..lol
rob
i3oricua
rob
Thanks Rob. Hope to have it all buttoned up by Wednesday. Hope.
It’s an integrated engineering valve cover. I bought it through ECS tuning because integrating engineering wouldn’t ship to me. It’s a much more simple design than our standard cover but it requires you to have a catch can setup.
i3oricua
Welp. Progress. Albeit much less than I had hoped. Swapped most parts over. Installed my newish oil pump with the balance shafts deleted. Removed transmission and stock clutch. Don’t think the clutch had much life left in it. Last thing I need is to get the head off and transfer it over. The valves could use a good cleaning and I need to change the valve seals but I think I might wait on those since the clock is working against me. We’ll see how it goes tomorrow.
i3oricua
Spent a majority of the time on the head today. If it had been a straight forward swap then I think I would have the engine in the car by now but I got the valve seals replaced and the valves cleaned real quick. It was worth it. They came out great.
HOWEVER....I broke a bolt off on the cam cradle. I was torquing them down to 15 ft lbs but I think I must have misread and it was supposed to be much less.
I don’t know what I’m gonna do about. I might try to drill it out and retap the hole. I guess the smart thing to do would be to remove the cam cradle and then tap it that way but I’m getting worn down at this point.
I'm Just Rob.
Staff member
Moderator
Gold Supporter
good work Edgar, bit of a bummer about that bolt, still if things were to easy it would'nt be as much fun...
I'm Just Rob.
Staff member
Moderator
Gold Supporter
Bit the bullet and decided to book the old bus in for a full decoke, new clutch and DMF , and a cat back miltek system and a new remap to suit.......
I'm Just Rob.
Staff member
Moderator
Gold Supporter
nope, given up with the alloys for now martin....going to wait until the summer now before thinking about changing, rather channel funds to more important areas at present.
had a mad moment yesterday and nearly bought a b7 S4 , then sense took over..lol
martin1984
that wouldnt be a bad thing Rob better than me as seem to be drawn to 3series xdrive as on the look for something newer
I'm Just Rob.
Staff member
Moderator
Gold Supporter
I found myself looking at autotrader a lot recently, even had a quick look at nearly new Mondeo estate over the weekend...….what was I thinking..lol, but they are great spec car and " reliable" ..but just don't look anything special which is why I still love the b7 ….it just ticks so many boxes even for a 12 year old car.....I could swap it in and hate its replacement, I'd rather just stick with the b7 and at least I know what i'm driving..lol
I'm Just Rob.
Staff member
Moderator
Gold Supporter
No fussed really its more of a retune to make full use of the new exhaust and clutch.
AlexMac
Active Member
What clutch did you finally decide on Rob? Just had mine done, stuck with the stock LUK parts (and a new rear oil seal on the crank) 'cos I'm not taking this motor beyond STG1 anyway. Giving it 500 town miles to properly break in feels like it's taking FOREVER though...
i3oricua
Made some progress today. Had to go backward to move forwards. Pulled the head off and tapped the hole and put in an helicoil then stole a bolt from the outside of the cradle and used it on the cams. Repurposed a steel bolt and made it work.
Took me a while to set the timing too. Wanted to make sure it was right and not off a tooth or anything. I’m happy with. I’ve put most of the motor back together now. Tomorrow I’ll get the clutch and transmission in and have it bolted up. Might even be able to fire it up and drive it home. Should be a good day if I work hard and quick.
i3oricua
Got the engine in today but little things really held me up. Finding little connectors and the transmission took a little to get in too. And then connecting the line later and blah, blah, blah. If anyone ever decides to do something like this get a friend to help. It makes it much more enjoyable.
Clutchmasters flywheel
Clutchmasters clutch and pressure plate
Engine and trans together
Getting ready to go in
Took a while but got it in the engine mounts points
Hopefully the last of it is tomorrow and I actually roll out. I know I hoped that would have been today but no joy.
I'm Just Rob.
Staff member
Moderator
Gold Supporter
excellent Edgar, nothing better than a challenge, hope it all powers up ok.:icon thumright::icon thumright::yes:
i3oricua
Thanks Rob. I’m hopeful. Just gotta work these last few bugs out and I’ll be good to go.
I'm Just Rob.
Staff member
Moderator
Gold Supporter
Its a good job you have access to all that garage equipment, the same project without it would be very, very difficult.
i3oricua
I got the car back together today. Started her up and got misfire codes and the clutch pedal is stuck to the floor. I obviously have to bleed the slave because it leaked the fluid when I pulled the trans. I’ll get that done tomorrow and I hope that is the real problem with that. Cleared the misfire, turns out I didn’t connect the #2 injector. Still have to put the intake manifold back in but feeling better now. Thermostat is leaking and has been a steady problem. Luckily I have a spare one here that I’ll throw in tomorrow as well that should get her running. Fingers crossed. I think I see the light at the end of the tunnel. This was a difficult one man job, at least for someone with no experience.
I'm Just Rob.
Staff member
Moderator
Gold Supporter
You done very well Edgar, no mean task for anyone to be honest , you have done very well chap and you can sleep easy knowing exactly what's been done and its been done properly , unlike taking it to a garage and hoping they do it all properly.
i3oricua
Thanks Rob. There is a definite sense of assurance and satisfaction since I did it myself. Plus I know exactly where to look if something is not right.
I'm Just Rob.
Staff member
Moderator
Gold Supporter
Sun was out today, well for a short while so did a few jobs on the old bus.
Ran VCDS after having rear offside door electrical issues recently, noticed that the indicators were not flashing on lock and on closer inspection the door wasn't locking.
Vcds reporting electric circuit failure , intermittent and also glass break sensor-open circuit intermittent.
Add to the mix the door sometimes still will not unlock full stop meant time to look further into things, door card off and nothing to account for it, checked the loom from door pillar plug right through the loom with nothing either.
put it all back and its all working fine again, maybe an issues with the central conv module but i'll see how things go for now.
Gave the old bus a good old shampoo and set , and for a 12 year old bus she brush's up very well, almost to good to part with now, and love my S4 mirror covers
not brilliant pics so don't flame me just yet.lol
i3oricua
Happy days. Car is back together and running. Running real nice on initial drive. Clutch engages really early which is much different than the stock clutch but very manageable. I hear some clutch chatter. I’ll get used to it over time. Few odds and ends that need some clean up. Refill power steering. Torque the wheels down to spec. Fully bleed the coolant. Fix my methanol lines. Overall I’m pleased. I’ll post some updated shots of my upgraded methanol line when I finish installing them.
Some pics of the car on first start. Little smoke from the turbo area but that’s normal to burn off the oil and other contaminants.
And back at home.
