  2. Dismiss Notice
What have you done to your A4 b6 today?
krisavant Mar 18, 2014
  1. Manics
    Manics New Member
    29
    There's been some talk of where to install additional gauges. Personally, I think A pillar and air vent gauges take away from the OEM finish, let alone the instrument cluster blocking ones.
    I thought I'd share my chosen oil pressure gauge location down in the change drawer by the driver's right knee.
    It's a great choice as it maintains, complements even, the OEM finish, is right next to the fuse box to run a live, and also directly underneath the hole in the firewall through the ECU box to run the sender wire. The readout is easily read through the steering wheel when driving.
  2. Avatar
    snack-media
    Advertisement
  3. quattrogone
    quattrogone Quattro Back!
    173
    43
    Ideal spot that :icon thumright:
  4. stevey83
    stevey83 Member
    184
    21
    How does it read the oil pressure? I thought the oil switch on the b6 worked by setting the oil light on with low pressure, not an actual pressure reading.
  5. Manics
    Manics New Member
    29
    Yes stevey -the switch activates at sub 20 (I think it is) oil pressure. Below that and it throws a light. Therefore oil pressure data doesn't exist (which is why you can't read it in VCDS). The switch is just "is pressure above 20 psi yes/no"
    Nearly all electronic gauges come with two components -the gauge itself, and a "sender" which is about the size of the gauge again which you install on the AUX port on your oil filter housing. You need to run a wire from the sender (which creates and sends oil pressure data) to the gauge. You also need to earth the sender. A live wire to the gauge and that's you done.
  6. quattrogone
    173
    43
    Cleaned the back end so I can photograph for the insurance company! :sorrow:
  7. quattrogone
    173
    43
  8. stevey83
    stevey83 Member
    184
    21
    I feel your pain, hit a rock on the way home. I dont seem to have anything but problems
  9. quattrogone
    173
    43
    Ouch! that looks somewhat flat, won't be using that one again!
    I hate rocks in the road, tractors have got so wide that they constantly catch the banks in Devon which often pulls large rocks out into the road and that is quite a pain when the Octy VRS is so low that anything larger than a small Tangerine is a major obstacle :scared2:
  10. Andrew_avant
    Andrew_avant New Member
    12
    Fitted these 18” beauties today. Can’t decide what colour to paint the callipers now that they are much more visible.. suggestions welcome. Not red though
  11. Venomuk
    Venomuk New Member
    Looks tidy, I'd got gloss black? Somethings are best left subtle
    Andrew_avant likes this.
  12. Avatar
    snack-media
    Advertisement
