  2. Dismiss Notice
What have you done to your A4 b6 today?
krisavant Mar 18, 2014
  1. QuattroCalum
    QuattroCalum Well-Known Member Saloon saloon Audi A4 Black Edition Manual
    2,021
    718
    Yes, headlights out and reach down for the three 10 mm bolts on each wing.
    Then two torx bolts above the foglights.
    Sent from my ANE-LX1 using Tapatalk
  2. Avatar
    snack-media
    Advertisement
  3. winterrB6
    winterrB6 Active Member
    167
    136
    43
    Yeah it is :icon thumright:
  4. winterrB6
    167
    136
    43
    bit more detailed then my reply haha
    QuattroCalum likes this.
  5. stevey83
    stevey83 Active Member
    219
    27
    Yeah, it was to the point!
    winterrB6 likes this.
  6. donsajid
    donsajid Member
    115
    audi a4 2.5 tdi, front lower arms, upper arms, suspension top mounts, discs and pads all round, timing belt, cvt oil change, full service, rocker cover gaskets, all suspension bushes, anti-roll bar links, water pump and thermostat.
    Car has just gone past 193,000 and running as nice as ever. Hopefully for many years to come.
  7. QuattroCalum
    2,021
    718
    Well done that man timing belt on the 2.5tdi looks a daunting task compared to the 1.8t.
    I guess you had coppaslipped the pinch bolts previously?
  8. sauk538
    sauk538 New Member Audi A4 Audi Avant Owner Group Manual
    27
    Took mine to a breakers yard today and bought her some new (to me) headlights, fogs and few plastic trims to neaten up the engine bay, then to thank me she broke down on me 7 times on the way home (1hr drive) love her to bits though
  9. QuattroCalum
    2,021
    718
    What was the problem, crank angle sensor?
  10. sauk538
    27
    I have no Idea, EPC light has come on before but goes off within second but yesterday it kept coming on and staying on until the engine cut out, drives as normal today.
  11. QuattroCalum
    2,021
    718
    Can you scan for fault codes?
  12. Avatar
    snack-media
    Advertisement
  13. sauk538
    27
    This is a code that never seems to save in the ECU, I have a fault with my Nox sensor (cant seem to find a cheap enough replacement) other than that, nothing else comes up
  14. QuattroCalum
    2,021
    718
    Do you mean 02 sensor?
  15. sauk538
    27
    Its the Nitrogen Oxide sensor that reads the final gases coming out of the exhaust, ive been told there are 2 lambdas (oxygen sensors) and then the Nox sensor
  16. QuattroCalum
    2,021
    718
    I'm in the UK, we don't have Nox sensors just the two 02 sensors. It should just throw a code, there's no way it should make the car break down.
  17. sauk538
    27
    Ill find thw paperwork from Audi and QuattroTech (VAG specialist) and upload a picture
  18. sauk538
    27
    For some reason my phone camera wont focus on the page but it reads
    Z44- heater for NOx sensor
  19. sauk538
    27
    G247 - fuel pressure sender
    Z44 - heater for NOx sensor
    G336 - potentiometer for charge motion flap no adaption
    N276 - fuel pressure regulator valve
    Check fuel low pressure.
    All faults have been cleared and havent returned but the NOx sensor fault
  20. QuattroCalum
    2,021
    718
  21. stevey83
    219
    27
    Probably the Lambda sensor.
  22. sauk538
    27
    I just dont understand why both Audi and QuattroTech would tell me its a Nox sensor if it isnt that, a friends diag computer came up with Nox fault too, car tries to stall when started cold and after 20 seconds or so it smoothes out abit but doesnt idle right, fixed the coolant temperature sensor fault and now it seems to be running better and my miles to empty seems to be more consistent
  23. QuattroCalum
    2,021
    718
    Where is the mounting position of this Nox sensor?
  24. Gaz!
    Gaz! Member
    165
    17
    Finally decided to put my new bumpers and non rusty wings on. Only taken a year to get around to it. [​IMG][​IMG]
    sauk538 likes this.
  25. sauk538
    27
    Ive read on other forums that it is screwed into the exhaust (like a lambda) and the wiring and control unit are under one of the front seats, apparently because its hard wired to the control unit, its more expensive
  26. S-Star
    S-Star New Member Audi A4 Audi Avant Owner Group
    25
    gave her a good wash and polish.. as she's now up for sale.. only selling as i bought an Audi a4 Avant..
  27. Andrew_avant
    Andrew_avant New Member
    12
    9
    Tinted my fogs yellow.
    sauk538 and BakPak like this.
  28. BakPak
    BakPak No Gear
    1,465
    215
    Looks good mate.
    Is it legal to put yellow film on the headlights?
    Just thinking the indicator orange bulb will effectively be obscured by the yellow film??
  29. Andrew_avant
    12
    9
    Thanks dude! Cheapest mod to do haha!
    There is no MOT requirement on the colour of the fogs but I’d imagine headlights have to be clear.
    You could always change the bulb to a chrome bulb? That would get rid of the orange nicely
  30. S-Star
    25
  31. sauk538
    27
    Headlights can be tinted but only to a certain transparency, google it, you can have all sorts of shades and colours.
  32. quattrogone
    quattrogone Quattro Back!
    248
    93
    Paid for it! Then had to drive straight to work and do an 11 hour shift before I could get back in it...
  33. Avatar
    snack-media
    Advertisement
  34. LoveMaAudi
    LoveMaAudi New Member
    Don,t have photos yet cause I just bought my Audi A4. So excited to get her out on the road!
  35. quattrogone
    248
    93
    Fitted honeycomb upper front grille
  36. quattrogone
    248
    93
    Oh and yesterday I retro fitted full nav plus RNS-e
    Who ever spec'd the car new ticked every single box apart from that one :persevere:
  37. joinerman
    joinerman Well-Known Member
    13,464
    597
    Tidied up the front wing wheel arch ( rust ), just a temporary job to get through winter then i'll have a pair of new wings.
  38. quattrogone
    248
    93
    Put even more petrol in it.....again and again and again :scared2:
  39. quattrogone
    248
    93
    Gazwould likes this.
  40. stevey83
    219
    27
  41. quattrogone
    248
    93
    Yeah I wasn't sure at first but after fitting my bargain OEM mud flaps that I'd also refurbed in matt black the whole lot ties together, after all the window surrounds and roof bars were already black. Just need to work out how to remove the chrome bumper strip as it's the only bling bit left :grin:
  42. AudiAnnie
    AudiAnnie New Member
    Hi, was wondering where you got the stickers from? I could really do with those!!
  43. stevey83
    219
    27
    Id be interested to see these fitted as well, my buttons are all worn and look terrible! Even worse at night now as all the red light shine through.
    Theres loads of sets on ebay.
