  2. Dismiss Notice
What have you done to your A4 b6 today?
krisavant Mar 18, 2014
  1. Wahlstrom
    Wahlstrom Active Member
    596
    186
    43
    It does, it comes back every time the car stalls.
    The things changed are removing ecu, shipping it, remap through boot, ship it back, install.
    Did the same 6 years ago when a got a normal remap
  2. Avatar
    snack-media
    Advertisement
  3. Wahlstrom
    596
    186
    43
    So, I went out and refitted the ecu and battery..
    Put it in acc and cleared codes in engine, abs, instrument, and a few others. They all had some ecu related codes.
    Started it and it ran normally. Took some readings.
    After 5-6 minutes it stalled..
    No codes, no lost communication. Just stalling.
    Can start it again, sounding normal, but stalls again after 10-15 sec.
    Tried to press the accelerator. The turbo and engine spooled normally, until just before it stalled, then turbo wouldn’t spool and it died
  4. Wahlstrom
    596
    186
    43
  5. QuattroCalum
    QuattroCalum Well-Known Member Saloon saloon Audi A4 Black Edition Manual
    2,020
    718
    I think you need to speak to the person who mapped the ECU.
    Sent from my ANE-LX1 using Tapatalk
  6. Wahlstrom
    596
    186
    43
    Yes.. that my last resort..
    Just one thought, could it be related to temperature.. as soon as the engine gets warmer it reached a point and stops.
    Could be why it could idle for 10 minutes to start with, and after it stalled the first time, cools down 0.1 degree and then idles for 10 sec and stalls
  7. QuattroCalum
    2,020
    718
    Try disconnecting the coolant temperature sensor and see if that changes anything. Also inspect the wiring from that sensor.
  8. Wahlstrom
    596
    186
    43
    Ok, I’ll try later
    just went out and started it. Idled fine and rev’ed fine.. this time I shut the engine off.. as it gives some proof that perhaps the temperature could be the reason it stalls
    QuattroCalum likes this.
  9. Wahlstrom
    596
    186
    43
    Engine won’t start with the G62 unplugged..
    It just starts and stops..
    Fitted it again, cleared the coded, then it ran fine again until it reached ~41 *C, then stopped..
    I’m trying to reach out to the tuner, but with Easter coming up, it will be hard.
    So I’ll be going through Easter with no car
  10. QuattroCalum
    2,020
    718
    Did you check the wiring for the coolant temperature sensor?
  11. Wahlstrom
    596
    186
    43
    No but can’t see why it should break on its own through Thrusters night.
    Must be an error in the map..
    If only I could get it to drive in limp
  12. Avatar
    snack-media
    Advertisement
  13. QuattroCalum
    2,020
    718
    Do you have an old coolant temperature sensor? You could plug that in and secure it to the wiring loom, so it won't see the engine temperature.
    Wahlstrom likes this.
  14. Wahlstrom
    596
    186
    43
    The tuner guy says that the reason is the injectors being worn and can’t deliever enough diesel for the map..
    But I can’t believe that the injectors are the culprit.
    Not according to the data from vcds..
    He requested a film, filming from cold start until it stalls..
    It stalls exactly around 41 degrees every time
  15. Wahlstrom
    596
    186
    43
    Damn.. disconnected the wrong sensor.. the fuel sensor..
    Will try to disconnect the right sensor tomorrow. Tuner says it should be able to drive then..
    What causes it, he’s now unsure off..
    But we’ll find out when it gets on the dyno
  16. Wahlstrom
    596
    186
    43
    Well disconnecting the right one didn’t do anything.
    Code came on, G62 no connection.
    Vcds Engine Block 1 still showed coolant temperature, and it went out at ~41degrees.
    Ecu shipped today to tuner, he will put on a standard map, car ran before, but with crazy idle.
    I’ll then drive to him(about 130miles) and get a custom map while on dyno...
    Best solution, should have started with it...
  17. Wahlstrom
    596
    186
    43
    While the car isn’t moving, I had time yesterday at work to reassemble my wheels...
    Just 3 more to go
    [​IMG][​IMG]
    winterrB6 and QuattroCalum like this.
  18. QuattroCalum
    2,020
    718
    Those rims are beautiful.
  19. Wahlstrom
    596
    186
    43
    Well I just can’t get rid of problems l.
    Received the ecu with a map that the engine can run, but when it reached 90 degrees, I checked block 13
    Either the injector seat/hole is oval or it’s a bad injector l
    Will try and swap injector 3 and 4
  20. QuattroCalum
    2,020
    718
    Could be the o rings on the injectors, notoriously bad for leaking. Even after changing the injector seat and o rings, they still leak. You can buy billet alloy ones at £50 for a set.
  21. Wahlstrom
    596
    186
    43
    Already gave them new O rings..
  22. Wahlstrom
    596
    186
    43
    How come the values were fine before, and now with the new map, suddenly one is off???
  23. QuattroCalum
    2,020
    718
    Maybe the injector seat has cracked, try spraying in there with Plus Gas or Brake cleaner, you'll hear the engine note change if it has.
  24. Wahlstrom
    596
    186
    43
    Can’t image how I’ll do that
  25. QuattroCalum
    2,020
    718
    Use the straw, place next to the injector/ injector seat and spray it.
  26. Wahlstrom
    596
    186
    43
    With the top off oil will spray all over the place??
    And brake cleaner for example will get in the oil
  27. QuattroCalum
    2,020
    718
    I don't think you understand what I mean. Where the fuel injector sits in the inlet manifold, that is the injector seat.
    To check if it's cracked spray plus gas into the injector seat when the engine is idling, if it is cracked you will hear the engine note change and possibly see it draw the fluid in. The engine will burn it off, no need to worry about your oil or anything.
  28. Wahlstrom
    596
    186
    43
    It’s a PD.. the injectors are located top of the head
  29. Wahlstrom
    596
    186
    43
  30. QuattroCalum
    2,020
    718
    Forget everything I posted, I have zero experience with diesels.
  31. Wahlstrom
    596
    186
    43
    Went for a longer test drive today.. car pulls fine, better than before.. so something positive has happened.
    Tuner requested a boost log, to make sure it didn’t go over 2750mbar for longer periods.
    It stays right around 2700 at full throttle/boost
    But the thing with cylinder 4 is a mystery for me.
    When the injectors were fitted I drove home but with very rough idle.
    Back then I checked block 13, and they had close to perfect values.
    Now with the remap, cylinder 4, shows a + 1.4-2.0 mg in idle..
    So something is bad in cylinder 4..
    Have the values changed to a more realistic number now that the ecu is remapped?
    And what is wrong, bad injector? Or misfitted O rings?
  32. Wahlstrom
    596
    186
    43
    Found this measuring block(18)... after 1 min, still 0.0 and all 4
  33. Avatar
    snack-media
    Advertisement
  34. Wahlstrom
    596
    186
    43
    Another block found.. don’t know how and when, but in idle, cylinder 4 goes above -100 periodically
  35. QuattroCalum
    2,020
    718
    It's it driving okay? If so I wouldn't get hung up over those numbers.
    DieselJake likes this.
  36. DieselJake
    DieselJake Well-Known Member VCDS Map User
    3,733
    1,102
  37. Wahlstrom
    596
    186
    43
    It drives very good..
    Experienced a very very short lag in power around 4K
    But other than that it pulls imo perfectly
  38. Wahlstrom
    596
    186
    43
    I just can’t get the reading from cyl 4 In block 13 out of my head
  39. QuattroCalum
    2,020
    718
    Personally I'd just drive it and try to forget about those numbers. It's easy to over think things.
  40. Wahlstrom
    596
    186
    43
    But it’s not normal values.. something is wrong
  41. winterrB6
    winterrB6 Active Member
    167
    136
    43
    Stared painting it with rusty paint :whistle2:
  42. winterrB6
    167
    136
    43
    Rusty paint on the bonnet and started fitting the FMIC, realised the SAI has to be removed though so I can route the FMIC pipework to the turbo
  43. stevey83
    stevey83 Active Member
    219
    27
    is it possible to remove the front bumper without taking the front wheels off?
