  2. Dismiss Notice
What have you done to your A4 b6 today?
krisavant Mar 18, 2014
  1. QuattroCalum
    QuattroCalum Registered User
    2,049
    731
    Nice new disc next to scabby old one. [​IMG]
    Wahlstrom likes this.
  2. Avatar
    snack-media
    Advertisement
  3. Wahlstrom
    Wahlstrom Registered User
    596
    186
    43
    Spend most of the day at work refitting the tailgate, refitting wiring loom and motors.
    One odd thing I came across was the small antenna wire.
    There are different options when ordering tailgate window. One is with or without antenna.
    The guy who replaced the window ordered a new one from the license plate.
    Thing is, they do not fit together as the loom has an antenna cable, and the window has a small single wire.
    The old window was soldered, the inner cable to the window, while the outer net was isolated. Did the same and radio reception is the same.
    Could have an performance influence, I don’t know but I still get reception..
    [​IMG][​IMG]
    Anyway it’s nice to have a smooth freshly painted tailgate back on...
    QuattroCalum likes this.
  4. QuattroCalum
    2,049
    731
    Good job
  5. QuattroCalum
    2,049
    731
    Two advisories, not bad.
  6. QuattroCalum
    2,049
    731
    Fitted new injector seats, £14 odds from the dealer. Old ones broke half way out so I removed the inlet and vacuumed the debris out, they were really brittle, long overdue changing. [​IMG]
    Jonni3 and Wahlstrom like this.
  7. Wahlstrom
    596
    186
    43
    Spend some time on right front side, an annoying sound appears sometimes.
    Anyone know the importance of the spring and springseat placement in the strut?
    According to Haynes things need to line up. But dampers aren’t the same, sure it has the holes in it, but can’t figure it out...
    Anyone?
  8. QuattroCalum
    2,049
    731
    I took note of their position on disassembly and put them back in the same position.
  9. Wahlstrom
    596
    186
    43
    Haha, wish I could do the same..
    lowering spring was fitted before, don’t know if who ever fitted those, did it right..
  10. QuattroCalum
    2,049
    731
    Fitted new coolant temp sensor, feels noticeably better to drive already. The list is of parts I've replaced this year is growing.
    Diverter valve
    PCV valve
    Crankcase breather pipe x 2
    Turbo inlet pipe
    Injector O rings
    Injector seats
    Pressure control valve
    Two coil packs
    Clutch
    Front discs and pads
    Rear pads
    Full set of Eibach springs
    The amount of inlet and pcv components is just a joke but then again it's an old car, there's nothing like fixing these niggling little problems that spoil the way the car drives.
    Still to change the fuel filter which hasn't arrived yet! Who knows when or if it has ever been changed, the car had a new fuel pump fitted in it's past so you'd like to think it would have had a filter fitted then.
  11. Wahlstrom
    596
    186
    43
    Been troubleshooting the RVC as it stopped working a few days ago due to battery was drained. Left the key in ACC for lots of hours..
    After this, it wouldn’t engage RVC when reversing.. Pretty annoying as I’m pretty used to it..
    Got it working today when I remembered that the IMA (Kufatec) has a menu in the DIS.
    So I activated RVC and it worked again
    Hooray
  12. Avatar
    snack-media
    Advertisement
  13. Wahlstrom
    596
    186
    43
    Bought a freshly painted OEM RS4 wheelset and got them fitted with my wintertires.
    They are painted Porsche Polar Silver colour...
    [​IMG][​IMG]
    Just need to wash the car now to match the shiny rims...
    DieselJake and Jonni3 like this.
  14. sprento
    sprento Registered User
    27
    9
    Meant to throw this up a few weeks back, installed some aftermarket headlight unit with LED side lights and less reflective chrome backing. Wasn't sure if they were for me at first so when I saw a 'new other' set on the bay for £80, I took a punt. The seller had a B6 cab with different contours or so he said. I like them a lot. Apologies for the jizz stains on pics 3 and 4, just can't control myself sometimes.
      File size:
      597.6 KB
      122
      File size:
      423.8 KB
      107
      File size:
      480.2 KB
      108
      File size:
      631.7 KB
      115
      File size:
      577.7 KB
      115
    DieselJake likes this.
  15. DieselJake
    DieselJake Well-Known Member VCDS Map User
    3,786
    1,122
    Nice! Usually think they look a bit tacky on b6's but they look really good on yours.
    sprento likes this.
  16. sprento
    27
    9
    I was the same and it's not easy to see flaws in new parts but I think it looks ok.
  17. Wahlstrom
    596
    186
    43
    Im having some problems with the G85(clock spring) sensor.
    After a loose wire from the battery and some electrical faults while driving, my car giving a MIL every morning(or when sitting for a while). It only happens on right turns and only over some degrees of turning(sharp turns)
    It chimes three times while flashing the brake alert.
    In the beginning I could read the fault 01826 in ABS.
    But can’t read it now, at least not after driving it for a while..
    Some I’m thinking:
    1. something is faulty
    2. It’s only when car has been off for a while
    3. It disappears after some time driving(it relearns the calibration)
    So, something looses this calibration.
    It could be the G85, the J527 module or the ABS block it self...
    Any ideas???
  18. QuattroCalum
    2,049
    731
    Try disconnecting the abs, clean both parts of connector and connection with some electrical spray cleaner then reconnect. See if it sets any new codes.
  19. Wahlstrom
    596
    186
    43
    Ok I’ll try that
  20. Wahlstrom
    596
    186
    43
    Took headlights out, sprayed them with soap water to show leaks as they began to moist up again. Back lid was cracked. Took care of it.
    And, have had an annoying sound coming from right front tire.
    Lifted the car up, and found the bolt for the sway at had come loose...
    Tightened it, now it’s tight AF.
    Incredible how much driving pleasure is lost when your car has an annoying sound...
    Now it’s back
  21. jd26
    jd26 Registered User
    332
    19
    Sent it off for a quick pre-christmas detail :)
    Jonni3, DieselJake and Wahlstrom like this.
  22. SemedoB6
    SemedoB6 Black and white a4
    506
    143
    43
    Finally swapped the plate lights..
    The right one hasn't worked in almost 4 months..
    Sorted now. [​IMG]
  23. jd26
    332
    19
    Did you have to get a new light casing? I need to refresh mine as they are a bit worn out
  24. SemedoB6
    506
    143
    43
    I got a new set of light..
    Replaced the whole thing.. Mine were looking a bit worn too and black from the elements..
  25. jd26
    332
    19
    Dealer part dude? Don't suppose you have a part number and price?
  26. SemedoB6
    506
    143
    43
    Just from ebay.
    232564080881
    That's the item number.
    jd26 likes this.
  27. jd26
    332
    19
    Great stuff thank you! Nearly bought these ones the other day but wondered if they would be compatible/ a good fit.
    How are they at night not overly bright lighting up the floor?
  28. Wahlstrom
    596
    186
    43
    Why not the oem lights?
  29. SemedoB6
    506
    143
    43
    The ones I took off before were already LED.
    just needed a fresher look.
    And they are really bright.. And do light up the floor a bit.
  30. QuattroCalum
    2,049
    731
  31. Wahlstrom
    596
    186
    43
    Tried to get to the G85 clock spring. It’s possible without removing the covers.
    But what suffix letter will give me same specs on the clock spring
    Found that mine is 4E0953541B
    But not many second hand units come up when searching ebay..
    A models are abundant
  32. just20409
    just20409 Registered User
    i have just bought the same car as you my friend who did your remap/decat?????££££
    thanks in advance
    2004 a4 2.5tdi avant quattro sport black /with black leather standard at mo but not for long any advise on tuning/mods???
  33. Avatar
    snack-media
    Advertisement
  34. Wahlstrom
    596
    186
    43
    Front brakes
    Brakes like a dream again
    [​IMG][​IMG][​IMG]
  35. Lozzy90
    Lozzy90 Registered User
    20
    Could do with updating my brakes at some point there shockingly bad. Would love to fit some B5 RS brakes but there well expensive and rare as rocking horse ****.
  36. QuattroCalum
    2,049
    731
    Changed the fuel filter, I don’t know when it was last changed and I’ve had the car two years now, mpg was starting to suffer. Had a run today and it returned 36 mpg which is a good improvement on what it was. [​IMG][​IMG]
    There was no major debris when I emptied the filter and it didn’t look too bad but clearly it needed changed.
    No problem with the dreaded clips but the retaining torx screw was rusted so bad I had to drill the head off it.
  37. Wahlstrom
    596
    186
    43
    I fitted S4 brakes all around..
    From 288/255 to 345/300
    Big difference in both performance and looks
  38. Lozzy90
    20
    How much did that cost you in total to do?
  39. QuattroCalum
    2,049
    731
    This mornings drive to work resulted in this......
    I’m happy with that!
  40. xs2man
    xs2man Registered User
    812
    31
  41. Roland Wong
    Roland Wong Registered User
    73
    17
    Installed new license plate frame, door courtesy projector LEDs.
    And later a new armrest cover...seeing so many aftermarket replacements makes me think the OEM Audi ones must be defective, but at almost $180 USD for Audi one I tried this one for about $13 USD from www.amazon.com/ it fit perfectly and the leatherette grain matched the leather interior to a tee with METAL guide pins. Note the latch width is 6.2 cm. Bought this one because it had the dimensions annotated...!
  42. xs2man
    812
    31
    So I guess I better get some decent pics up. Between last night and today, I managed to clean it. Not a quick process.
    Pre-rinse
    Snowfoam - Gyeon Q2M
    2 bucket wash with Simoniz car shampoo and wax
    Autosmart Tardis
    Snowfoam again
    Meguires claybar with quick detailed as lube
    Machine polish with Mezerna PF2500
    Mezerna power lock sealant
    Windows done with Gteqniq G6 then G5
    Leather cleaned with autoglym leather cleaner, then treated with Raceglaze leather balm
    Interior carpets hovered then febreeze.
    Still to polish & seal wheels, and properly clean interior plastics.
    Roland Wong likes this.
  43. Wahlstrom
    596
    186
    43
    Project side mirrors
    Auto dim( not fully connected yet)
    Power fold
    Roland Wong and Jonni3 like this.
