What have you done to your A3 (8p) this week
Russell Miah
I have finally changed my headliner from cream to black soooo much better but deffo wouldn’t do it again. Whilst it was out I had to do the starlight’s. Did this all in 1 and half days. Best mod so far. Is there a way I can attract a video? Don’t know how too
R0cket
Active Member
Changed the cambelt and water pump due to time. Car only on 105k
Fitted gfb dv+
fitted forge quick shift up/down. Original plastic one was worn and forge wasn’t much more money. Not shortened the shift yet.
fitted new expansion tank with Porsche lid.
fitted black washer cap
Got the rocker cover gasket to replace and vis balance shaft delete to fit tomorrow along with oil and filter change using millers.
Not too far off getting it back on the road now!
JayA3sline
Active Member
Jay_rs3 for more oem+ rare mods. Going to replace the red LEDs for white to match the rest of my 8P interior
Nanz
Some of you may know from my threads here that I've been having some major issues with fuel economy (for quite some time). I have just had a new revision G diverter valve (both Audi original parts) installed and a new thermostat to see if this will sort the issue. The temp probs I have been having seem to have been sorted, temp now sits at around 93-94 deg and its not dropping when I drive.
The other changes made over the year were to try and address the fuel economy issue were:
  • Coolant Sensor
  • PCV
I've filled the tank so let's see how much I get out of it, I've not been able to get much over 200 miles on a full tank since I hit these problems 18 months ago.
Troubs12
Active Member
Finally got around to replacing my cluster with the 983G version. After a few tweaks I’ve sorted my needle sweep, boost gauge, lap timer, oil temp and all the other toys in my little 1.9 TDI.
e9_mustii
Boost guage ????? Show meeeee
Sent from my SM-N976B using Tapatalk
R0cket
Active Member
Got it built back up and went for a shakedown. First time I’ve driven it in 2 years woop. Cleared off all the issues causing lights on the dash ready for the mot. A few basic settings applied and steering calibration done. Funny how the power assist just comes back online while you’re doing that.
maybe bumper on tomorrow
JAYJAYB
I replaced my rear left brake calliper the other week as it was sticking and wearing down the pads quickly. When I took the old calliper off the rear shaped solid brake pipe broke off using the correct brake spanner. I bought a new pipe from Audi direct and replaced the calliper and bled through brakes.
All good.
Now the front brake calliper drivers side is doing the same and need to sort this out tomorrow. At least they are easy to replace.
JAYJAYB
Replaced the drivers side calliper today on my 54 reg bkd engine. What an easy job this was to do. Got a reproduction calliper from euro car parts. Bled the brakes and boom all done. Let’s hope nothing else goes wrong soon as I have just bought a house and finds are low.
but I do drive 67 miles a day to work 5 days a week so a fair amount of miles I cover a month.
R0cket
Active Member
Passed the mot after being off the road for 2 years.
1 advisory for a slight play in track rod end grrr
danrst171
I put a Milltek non-resonated cat back on the car this afternoon. What a pain in the backside that was! Probably should have purchased new exhaust hangers as the ones on there have probably hardened over time. Taking them off was easy with the tool you can buy, but putting them back on was a nightmare.
The backbox section was for an S3 and I have an A3 (purchased off JAYJAYB), and it seems to sit flush to the bumper cutout. No noise being made when driving but will eventually just cut the bumper a little more to give it some more space.
Loving these. I need these on my S3. Where from and how much can I ask?
Actually got them off AliExpress - £31 and came in less than 10 days and fit perfectly. Was genuinely surprised how good they are just thought I’d take a punt at that price and happy I did!
phateuk
That's quality, have you got a link cos I'll order the same ones
Sweet I'll have a look. Is yours a facelift post 2009?
Also, what's your front splitter, looks mint!
No pre facelift. Splitter is a generic one as didn’t want to pay the price of the ‘branded’ ones so again took a punt. Did abit of test fitting to get the best angle for car then just screwed it in place
Troubs12
Active Member
Got playing with my dash again I wasn’t sure if white needles would work but so glad I did it.
lafa3ro
Boring part, had a check-up done and an ecs tuning aluminum skid plate installed.
Fun part, brand new wheels and tires. Really happy with the look and fitment so far!
Envoyé de mon Pixel 4a en utilisant Tapatalk
Troubs12
Active Member
Did you only replace the needles?
Looking good!
Part numbers?
Thanks bud no new parts (apart from leds) I removed the red ones, rubbed them down and painted white. Then took the parts off to get at the pcb and replaced the red leds for white ones. It was a pain but worth it.
danrst171
My car right now...
hoping to remove the Aircon radiator, fit a toe strap, replace thermostat and if funds permit, a new intercooler. Will be removing the fog lights too and measuring for a home made front grille. Busy weekend!
phateuk
RS3 style honeycomb grille arrived this week. Decided to fill in the scratches on the front lip and undertray and respray gloss black. Really pleased with the final result. Looks so much better than the stock grille.
bronco
Vancouver BC Canada
Totally ! Looks great man !! :thumbs up:
Liam O'Brien
Looks bang on mate. I've noticed there's a few kits around. Which one is this?
Sent from my SM-G986B using Tapatalk
phateuk
Thanks pal. This is the one I bought:
It's one of the more expensive ones, but that YouTuber CarsWithSmithy did a video on this one and was exactly what I was looking for so went for it.
I'd also order a pack or two of these:
Some of mine were pretty rusty so I used new ones when putting the bumper back on.
You'll want a new badge too. You can take the OEM one off and could fit it with a bit of messing which is what Smithy said he did, but I just bought a new one that was gloss black:
Bit of a ripoff for £25 I'll be honest cos it's not metal it's just plastic but once it had arrived I couldn't be ***** trying to get the OEM badge to fit so just kept it. I didn't use the little clips it comes with I just used some nuts and washers on the back of it to fit it in place.
ch1z64
C'mon you's bhoy's in Green
Silver Supporter
Whats the odd 1 out lol. Pics on postcard
