What have you done to your A3 (8p) this week
fitted my heated fan washer jets work loverly and 2 minutes to fit no shims or any thing exactly the same as oe
8CA254A0 E7A6 4E5C 9E79 7001BE127170
A5 seats in and electric lumbar working perfectly too, easier than I thought they’d be to fit. Rears next
Reactions: JSB89, samisnake and Bryant1998
Sorting my front grill rings, going black, snapped the clips getting the first set off, had to order another silver set from Audi as the don’t do black rings for this grill, been a pain, but worth it in the end, just need clipping on when they are dry. I thought blacking the rear was fiddly, but sorting out the front grill rings where the worse.
Reactions: marcjwebb and ronniejack
Done a few miles in mine from Oxfordshire up to North Wales, and enjoyed a few mountain roads in the area including Snowdonia.
Rsz fb img 1560103382308
Rsz img 20190607 174137  01 01
Reactions: markbrown87, mechanic69, samisnake and 1 other person
Fitted revo induction kit to the S3 today, why did nobody stress how good it would sound
Because words cannot describe it you gota hear it for yourself
Sent from my SM-N960F using Tapatalk
Reactions: Bryant1998
C95E3D01 6F64 4C5A 8313 F961D83B70EA
Stripped down to this for inlet valve clean, rs4 fuel pressure valve install and a general clean up of parts. Replaced a O-ring seal on the vacuum pump too which was dripping oil onto the gearbox.
Started to paint the silver/black bits so it looks clean AF when you “pop the hood”
24th oil change today at 237,000 miles (381k km)
Still no issues to report:)
5e18e995-48cb-4983-94fe-e4721ae377d3-jpeg.184725
Reactions: mister.c.
Fitted a brand new set of rotor wheels from WSP ITALY and Dunlop Sportmax RT2 225/40r18.
Now I have to look for lowering it a bit since it has SE suspention.
Fitted my ashtray delete, slightly bodged as didnt realise I needed to remove the grab handles unfortunately all my tools are an hour away in my garage at my mums
Nice mod!
Have you got part numbers or a link to what’s needed?
Nice mod!
8P0863301A 4PK is the part number, brought from *** on Facebook for £13.80 delivered
Finally got around to fitting the fan windscreen jets, great coverage! Will need to see how they do on the motorway and possibly adjust :)
Reactions: ronniejack
I put a new set of Uniroyal RS3's on the front.
There was some life left in them, but the passenger side had a slow puncture and the uneven wear had caused excess wear on the edge so I got them both replaced. Very impressed at how them performed and lasted approx 20k miles.
this weekend I will be mostly fitting a new timing chain kit
What's the general consensus of what a "cam chain kit" is, best practice?
I see a varying selection of "kits" available ranging from just chain and tensioner (£60-80), to chain/tensioner and a handful of seals (around £108 for FAI), to a kit with seemingly just more seals etc around £250.
basic chain & tensioner - https://www.autodoc.co.uk/fai-autoparts/7814777
mid level - https://www.autodoc.co.uk/fai-autoparts/7814780
full kit - https://www.ebay.co.uk/itm/Genuine-...uattro&hash=item4d2f819048:g:jS0AAOSwrklVCyw0
You can check the wear with vcds to see if it needs replacing
Reactions: Daveyonthemove
Well it tells you how much the tensioner is compensating for stretch I believe
Yea I've got a rough idea but i just can't find anything credible to what the right figure tolerance is cause when i heard about hat i looked and saw mine was at -4 degrees which some stated is good but nothing solid from.audi to state but thwn im.checking on obdeleven not vcds but its supposedly the same thing
full kit - https://www.ebay.co.uk/itm/Genuine-Audi-A3-S3-A4-A6-2-0-TFSI-2TFSI-Cam-Chain-Tensioner-Repair-Kit/331509502024?fits=Car+Make:Audi|Cars+Type:S3+quattro&hash=item4d2f819048:g:jS0AAOSwrklVCyw0
the oe parts consist of the chain 2 slippers and tensioner 66 qwid chain 1 slipper 9.00qwid others slipper 18.00 qwid and 36. qwid for the tensioner all from tps audi fal do the same for 224 qwid **** nose where they get there prices from I actually got a complete kit from maxpeeding rods sell racing rods pistons and the like 87 qwid that's all the above plus oil chain and vvt pully and came pully also crank teeth oil seal
mind you chaps mine is a 1.4 turbo so different to those lonks you have
yours I a titally different engine to mine I have a 1.4 tfsi lol
Drove the S3 upto AKS tuning for a much needed haldex, gearbox oil change aswell as transfer box. Aparently the filter was full of gunk so never trust the B.S fed from a car salesperson... told me it was done prior to purchase of the car
Removed:
11757C08 BB67 416C BA6F 1E35D37A7DD6
And installed:
F0AF2E65 9CB6 4BD2 ACAC 5B59AADEFFDD
It’s the little things . Plus only £12 on eBay
Reactions: mechanic69
Normal bulbs. I’m not a fan of dentist waiting room white leds.
611D5BCD 60CC 4217 837F E53B38338A15
Reactions: Menelaos
