  2. Dismiss Notice
What have you done to your A3 (8p) this week
lea323ci Jul 27, 2017
  1. Genius
    Genius Registered User
    253
    Y'know the splitter cover is literally just a cover only 2 screws holding it in place on the underside, much easier to paint off the car
  2. Avatar
    snack-media
    Advertisement
  3. leonwilliams
    leonwilliams Registered User
    1,042
    197
    No I didn't mate I was laid on my back masking it up. Will take it off tomorrow and finish it off. Thanks for that
  4. Genius
    253
    No worries, was gonna mask mine off like you did but realized when I had the bumper off to replace the grille how easy it was to remove. Probably still a little bit of laying on the floor to get the screws out though lol T20 I think they are but maybe smaller, took a lot of screws out of the car that weekend
    leonwilliams likes this.
  5. leonwilliams
    1,042
    197
    Thing having a I'd finished and took masking tape off I'd realised that I hadn't followed the contour or the lip. Which you don't notice so I've just to redo that not tomorrow .
  6. samuelh_888
    samuelh_888 Registered User
    2,081
    858
    Fitted Mintex 1144 front pads to my Yellow Speed Racing BBK (MDB1977M1144). This is the final piece in getting my car certified for New Zealand roads.
    S. and ch1z64 like this.
  7. leonwilliams
    1,042
    197
    Fitted H11 resistors yesterday works perfect no errors. Also my mate has vcd. Modded fogs to come on when turning corners at night. Any idea how to do needle sweep on clocks ?[​IMG][​IMG][​IMG]
    D7YAB likes this.
  8. mechanic69
    mechanic69 Registered User Gold Supporter VCDS Map User
    2,066
    784
  9. leonwilliams
    1,042
    197
    Front lip finished. Also anybody know where I can get this aluminium part from ?. Doing my head in now with all scratch marks on it [​IMG][​IMG]
  10. ch1z64
    ch1z64 C'mon you's bhoy's in Green Silver Supporter VCDS Map User
    4,203
    930
    Off a 5dr doorcard
  11. dp_motley
    dp_motley 2019 A3 35TFSI S line
    1,287
    506
    I have a set of s3 brushed aluminium door trims in better condition than yours. Not perfect but a lot better, without such deep scratches.. I want £100 for the set.
  12. Avatar
    snack-media
    Advertisement
  13. leonwilliams
    1,042
    197
    You got a pic mate. I only need the one
  14. dp_motley
    1,287
    506
    I won't sell one. Also, mine trims are different from yours: brushed aluminium vs dotted.
  15. leonwilliams
    1,042
    197
    Ah ok mate I've just seen one on eBay like mine quite cheap. Just waiting for a better pic
  16. downtothebone
    downtothebone Registered User
    832
    200
    43
    Replaced the center speaker with a pair of Audison Prima AP1 tweeters. Cover doesn't quite sit flush - need to work out what can be done. IMG_0726.JPG IMG_0725.JPG
  17. downtothebone
    832
    200
    43
    Some dash bling ...
    D7YAB and maxpayne like this.
  18. maxpayne
    maxpayne Registered User
    1,041
    234
    Didn’t even know there were speakers there! Does it make a difference?
  19. s3_trev
    s3_trev Northern Ireland
    1,907
    660
    By any chance did you take a pic of the OEM speaker before you replaced it?
  20. Daveyonthemove
    Daveyonthemove Well-Known Member VCDS Map User
    1,827
    624
    Wasn't the case with mine, it was moulded into the bumper.
    I took the entire bumper off and masked it up before spraying.
  21. leonwilliams
    1,042
    197
    Didn't bother taking bumper or splitter off just masked and painted .
  22. downtothebone
    832
    200
    43
    No pic of it in situ - but if you want a pic of the speaker itself then just search for Audi A3 8p dashboard speaker. I still have the speaker so can photo it if you wish?
  23. dp_motley
    1,287
    506
    It's true for the S/S-line bumper. The SE one is moulded as one piece without any separate splitter.
  24. downtothebone
    832
    200
    43
    Yes - very noticeable. The OEM speaker produces very little sound and maybe this is deliberate as you would interfere with stereo imaging. The reality is in a car given the odd seating pattern imaging is not going to be too much of an issue (purists would disagree). Anyway I’m getting a more ‘full’ sound in the drivers seat. The Audisons are quite smooth so I’d match very carefully as anything too harsh will be exaggerated. I have Audisons in the front doors as well.
  25. leonwilliams
    1,042
    197
    Next mod puddle lights for my wing mirrors. I need a donor mirror if anyone has one even if it's just the shell.
    So I can do a test run. Happy to travel not too far and pay for a mirror. Doesn't have to be exact. But size and shape would be better. [​IMG][​IMG]
  26. dp_motley
    1,287
    506
    Replaced corroded rear door triangles.
    Than run Dyno test as I didn't do it at the time of remapping the ECU a year ago. I was surprised that my small 1.6 TDI could produce 150HP and 372Nmn :) Here's a video of two first test runs.
    And the graph
    maccalo likes this.
  27. downtothebone
    832
    200
    43
    The 034 Motorsport billet aluminium dogmount insert has been on for about three weeks now ... There is still some vibration once on the move 5-10mph and I did get a little in reverse tho that seems to have gone now. Let’s see in another 3 weeks.
  28. ch1z64
    4,203
    930
    Have done SFA to mine not even driven it for a week cause Jack got my steering wheel , chatted to mate in NZ to see how he's enjoying the driving off his S3.
    Thats it Folks
  29. Niffty9
    Niffty9 Guest
    Checked my timing chain tensioner wear using the method from this video:
    Great video and 1° KW (I guess clockwise?) is a very happy result. One less thing to worry about.
    For those with a vagcom, video summary:
    Go to Engine, Block 93 Read 'inlet camshaft phase angle' under 4° good 4 - 5° risky >5° replace.
    From my understanding this measures the long term correction added to the cam phase. More correction = more wear.
    Also fixed the seatbelt warning whilst I had the vagcom linked :)
    Shady0808, ch1z64 and Daveyonthemove like this.
  30. Gregsy16
    Gregsy16 Registered User
    15
    - Mot
    - Racingline intake
    - Miltek sportcat & downpipe
    - Service
    - Cam follower service
    - TTS engine cover
    Now skint and eating toast & beans for the rest of the month
  31. ch1z64
    4,203
    930
    Now lets see the pics , beans n toast ones :thumbs up:
    maxpayne likes this.
  32. Gazpot0111645
    Gazpot0111645 Registered User
    61
    19
    Retrofitted High Beam Assist to my S3 8P using an Audi TT dimming interior mirror with forward facing camera. 20180902_161204.jpg 20180902_161252.jpg
    Dave-v-v, ch1z64, mechanic69 and 2 others like this.
  33. Avatar
    snack-media
    Advertisement
  34. tcardio
    tcardio Registered User
    1,456
    548
    just when i thought nothing else could be done....
  35. samisnake
    samisnake Registered User
    864
    383
  36. mechanic69
    2,066
    784
    You can’t leave us hanging there, any details on the retrofit part nos, guide, etc???
    Can this be used for active cruise control??
    Nice mod
  37. mechanic69
    2,066
    784
    Dropped her off to the local garage for cam belt, water pump and fuel filter cos I can’t be ***** with the hassle of doing it myself.
    Just the rear BCS to arrive and be fitted before booking into RTech for a tune, happy days
    samuelh_888 likes this.
  38. downtothebone
    832
    200
    43
  39. mechanic69
    2,066
    784
  40. Gazpot0111645
    61
    19
    HAHA Sorry,
    The kit I purchased consisted of an Audi TT interior mirror with the forward facing cmos sensor and a wiring harness. Unfortunately you cannot use it for adaptive cruise. Here is the kit I bought as its hard to find a mirror at a decent price. The mirror in this kit is also brand new and a genuine part.
    https://www.ebay.co.uk/itm/AUDI-A3-...h=item3d3e78da21:g:TvUAAOSw9RdbDjjJ:rk:1:pf:0
    The kit came with new wiring harness with a new 8 pin connector to the new mirror. All you have to do is wire the CAN + and the CAN - into the CAN Gateway. As for the other end at the mirror you use the new 8 pin connector and swap your other 4 wires to it from your old 6 pin connector. Code in using VCDS and job done.
    I will be doing a full write up soon and including all pictures and video in the retrofit section. This was just short and sweet for you.
  41. mechanic69
    2,066
    784
    Thanks for the heads up, look forward to more info. Looks like you need the auto dimming/rain sensor stuff fitted before to work, mine never hand that but all the other upgrades, never really worked that out
  42. mechanic69
    2,066
    784
    checked mine today and at -3.0
  43. leonwilliams
    1,042
    197
    Done test run with 8p mirror for puddle light. Hardest part was figuring out how to run wire but sussed it.
    Next job fitting reckon full day to do will post pics when done. [​IMG][​IMG][​IMG]
    Dave-v-v and samisnake like this.
