  2. Dismiss Notice
What have you done to your A3 (8p) this week
lea323ci Jul 27, 2017
  1. mechanic69
    mechanic69 Registered User Gold Supporter VCDS Map User
    2,066
    784
    If you have swapped the back panel of the unit it should fit back in the hole correctly, have you checked for cables or connectors preventing it slide back into the connectors?
  2. Avatar
    snack-media
    Advertisement
  3. maccalo
    maccalo Norway
    116
    53
    I was referring to @ch1z64. Mine fits as it should and like yours @mechanic69. I swapped back panels.
    mechanic69 likes this.
  4. ch1z64
    ch1z64 C'mon you's bhoy's in Green Silver Supporter VCDS Map User
    4,203
    930
    Did you remove the back from the old CC and screw that on to the back off the Q3 CC. .
  5. ch1z64
    4,203
    930
    leonwilliams likes this.
  6. ch1z64
    4,203
    930
    Now i am understanding what you mean , i see the gap at the top so i might need to jiggle it about to sit better
  7. leonwilliams
    leonwilliams Registered User
    1,042
    197
    Ok will do next half hour
  8. ch1z64
    4,203
    930
    Start a new post about it
  9. Daveyonthemove
    Daveyonthemove Well-Known Member VCDS Map User
    1,827
    624
    This weekend my oil was changed (feel like I'm typing this every week lately) and the drivers side seat was pulled out i order to fix it and make it slide forward when pulling the lever on the top to let passengers in/out the back.
    I'm hoping the switch to Millers Nanodrive 5W-40 will reduce/stop oil consumption and give the engine some extra protection.
    I Will create a new thread about the seat fix.
    maxpayne likes this.
  10. maxpayne
    maxpayne Registered User
    1,041
    234
    Will be watching too as I have the same problem (currently on Quantum 5w30).
  11. Daveyonthemove
    1,827
    624
    Mine was on Quantum 5W-30 prior to yesterdays oil change, so I'm hoping to see the oil level remain at the full line, or go down much much slower than it has been doing.
    Got lots of driving to do this month, so I will watch it closely.
  12. Avatar
    snack-media
    Advertisement
  13. leonwilliams
    1,042
    197
    I was asked to do a write up of this mod. Fitted boot struts my 2011 a3 8p 5dr. It's a simple mod only tools required is a flat head screw driver. And a peice of wood to keep boot lid open. For when you remove struts. I got pics so will try to put them in order.
    Ok as you can see from pics prise little clip there is a recess this just comes loose. Repeat for the bottom one. Once it's off you just push the replacement new one into place it spring loaded and will click.
    Now I noticed from the sellers pic there where 2 colours sont know why but mines works fine.i did read about an issue with the brackets. Because the strength of the spring forces the boot lid up. And when it reaches the top it slight stops abruptly.
    When closing you have to use a little bit more force. This a great for £50.00 here s the link
    https://www.ebay.co.uk/itm/2X-AUDI-...178583?hash=item1a58653997:g:broAAOSwomJauUlb
    Quick delivery.[​IMG][​IMG][​IMG][​IMG][​IMG]
    mister.c., dp_motley and samisnake like this.
  14. leonwilliams
    1,042
    197
    Done.
    ch1z64 likes this.
  15. ch1z64
    4,203
    930
    Don't you just love your neighbours when there aving a Giraffe . But nice addition .:thumbs up::thumbs up::thumbs up: eve tho Cheesey . 20181001_155315-1440x1920.jpg
  16. Niffty9
    Niffty9 Guest
    Done oil & filter plus new plugs this week, plugs made a huge difference to off boost pick up. Bought a fuel filter too but one of the hose clips really doesn't want to come free and I REALLY don't want to break my only mode of getting to work so I'll let the garage play that game with a ramp and good access.
  17. leonwilliams
    1,042
    197
    Fitted Cree H11 fog lights simple mod only tools required is a Philip's screwdriver. Only thing is these throw up an error. I Have similar cree H11 for my drls no errors.[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    dp_motley and maxpayne like this.
  18. leonwilliams
    1,042
    197
    Slight error sorry H11 not used for my drls. But are error free.
  19. ch1z64
    4,203
    930
    You need to stop those kids writing on your Car mate.
    Have you tried to code them out as i know @t8ups coded out my lights that he put in my Drl's ( i know urs are fogs) worth a try especially if your getting error codes no good
  20. leonwilliams
    1,042
    197
    Ha ha ha ha ha. I didn't know you had to code them out mate. Thought plug and play. Will get it checked out .
  21. leonwilliams
    1,042
    197
    Or I could get H11 load resistors ?
  22. ch1z64
    4,203
    930
    I am not saying you can but i know on my 2007 i had led drl's and @t8ups coded them for me with no errors so ask around
  23. leonwilliams
    1,042
    197
    Found a few posts on here tupps does a kit with resistors built in. I 'll just buy the resistors.
  24. maxpayne
    1,041
    234
    Looks cool. Meaning to do that myself for a while.
    Shots of the new lights?
  25. leonwilliams
    1,042
    197
    Just waiting for it to get dark give me 5 mins
  26. leonwilliams
    1,042
    197
    Pics of lights.[​IMG][​IMG][​IMG]
    dp_motley, NevMan and lea323ci like this.
  27. ch1z64
    4,203
    930
    Just like the brightness from a plane , will see you from afar :thumbs up:
  28. leonwilliams
    1,042
    197
    Mate the way some people drive with blinkers on better to be safe then never. Don't use my fogs. See if i can get away using as driving lights lol
  29. samisnake
    samisnake Registered User
    864
    383
    s3_trev likes this.
  30. leonwilliams
    1,042
    197
  31. leonwilliams
    1,042
    197
    I see from that pic loads of different pressures is it accurate.
  32. samisnake
    864
    383
    i set the tyres to those pressures recently, so yeah its accurate. temperature im not sure about tbh, unless the temp inside the tyre is warmer than outside temp even if the cars been standing.
  33. Avatar
    snack-media
    Advertisement
  34. leonwilliams
    1,042
    197
    How easy to set up
  35. leonwilliams
    1,042
    197
    And where did you place the receiver?
  36. samisnake
    864
    383
    easy.
    take headunit out to plug the receiver into a usb socket, put headunit back. i placed the receiver on the flat back plastic behind the headunit.
    fit a nut to each valve, and screw on the sensors. they are marked for each wheel eg. FL is front left. when sensor is on tight, wind back the nut till it touches the sensor, then tighten the nut with the spanner. that stops it being removed (anti theft measure).
    install the app, should find the sensors immediately. go into the app settings to set things like alarm sound, low pressure limit, high pressure limit, displayed units (C/F, psi/bar). thats it.
    took about 10mins or so. longest bit is taking out the headunit.
  37. leonwilliams
    1,042
    197
    Sweet my head unit has 2 usb leads which I have slotted into the little tray out of the way. Have ordered it now thanks.
    samisnake likes this.
  38. s3_trev
    s3_trev Northern Ireland
    1,907
    660
    Is that an Android head unit?
  39. leonwilliams
    1,042
    197
    Yes it is
    s3_trev likes this.
  40. ch1z64
    4,203
    930
    Removed steering wheel to send it away to Jacks for a retrim , followed excellent youtube video but what an nightmare removing the airbag clip especially if you have chubby fingers plus recommend you av all the correct tools M12 spline i didn't but friend had .
  41. mechanic69
    2,066
    784
    Guess that’s royal steering wheels? Jack does a great job
  42. ch1z64
    4,203
    930
    Yip it is that . Looking forward to getting it back in 10days or so and excellent price .
  43. leonwilliams
    1,042
    197
    Painted wheel centres black. And from spoiler lip black. Not finished with it yet. [​IMG][​IMG][​IMG]
