What am I doing wrong.......
RustyBucket
Buckinghamshire
I'm looking for some help or ideas. First off can someone confirm, or not, that the Mk2 RNSe 8P0 035 193G is capable of using SDS functionality with the SDS hack.
If it can I've reached a point from which I'm not sure how to proceed. Everything with the upgrade seems to work, so radio (although need to upgrade the antenna), Nav (using 2013 maps) Telephone (iPhone connected via bluetooth), which allows me to scroll the phone book on the DIS using the mode button on the MFSW and to make and answer calls. Can also see the phone/directory etc on the RNSe screen. I've downgraded the firmware to 150 then upgraded to 220 with SDS and within the unit I can select the SDS language which is set to English.
My issue is getting the SDS to work. I can use the PTT button and hear all the commands but what ever I do, it cannot seem to hear me. If I push the button and say 'next station' for example there will be a delay and then I will hear 'Pardon?' at which point I will say 'next station' again, followed by another delay. I will then either be told what the available commands are and when I try 'next station' again it says 'cancel', like it's timed out waiting for my command. I've included a bunch on information below on coding for the different modules and errors which includes the antenna fault that I'm aware of and in the process of getting sorted but any help/advice/suggestions would be greatly appreciated. Car is a 2006 S3 with MFSW & Audi bluetooth.
Bluetooth module? 0--8P0 862 335 H -- FSE_255x BT H26 0290
Radio coding: 0209727
Hardware/software: RNS-E PU EU H05 0220
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 35
Mileage: 119646 km
Time Indication: 0
Date: 2014.09.25
Time: 09:51:58
Freeze Frame:
Mileage: 119640 km
Count: 2509
Clock: 09:51
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 35
Mileage: 119646 km
Time Indication: 0
Date: 2014.09.25
Time: 09:51:41
Freeze Frame:
Bin. Bits: 00000000 00000000
Bin. Bits: 10000000 00000000
Telephone coding: 0011422
02619 - Communications Wire Adapter Set
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01110100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 145
Mileage: 2502 km
Time Indication: 0
Date: 2007.03.07
Time: 15:06:29
Navigation coding: 0209727
RNSe unit: 8P0 035 193G
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 35
Mileage: 119646 km
Time Indication: 0
Date: 2014.09.25
Time: 09:51:41
Freeze Frame:
Steering wheel coding: 0004012
I am keen to upgrade my mk2 RNSe from basic to full SDS but when I asked and researched a while ago it doesn't seem its possible. The mk1 can be hacked with discs and VCDS but apparently the mk2 is a unit hardware upgrade.
Here's hoping it can be done and I'm sure one of the retrofit gurus will be along to advise.
What I do is press the button on the rnse, a million times less annoying
Yes it is possible I can confirm that and I've answered my question above which is that the mic needs rewiring to the RNSe so just looking into that and I'll have full SDS with the Mk2 RNSe :icon thumright: Can find lots of posts but nothing with a diagram to give me the confidence at the moment.
I think the full SDS may require a different bluetooth module to support the operation of it, if I remember correctly when I installed RNSE and bluetooth.
I remember Nigel offered this feature.
Ah - hopefully Nigel will catch this thread and be able to confirm either way. I was under the impression that I should just be able to rewire but my head is swimming with the number of threads I've read trying to work this out :confused:
Like you, the sds just is rubbish, novelty at best, I just navigate with the buttons
Not quite sure why I'd need to rewire my mic as it works already, I just want some more functions.
