Facelift Weird Tyre Wear on RS3 (FL)
Daniel Knight Jun 22, 2018
  1. Daniel Knight
    Daniel Knight Member
    37
    35
    I've had my RS3 for 6 months from brand new. It's had a couple of ongoing issues during this time such as the oil consumption and squeaky brakes. After going back and forth with Audi (as they could never replicate the brakes) they finally discovered an issue with 2 of my pads. Whilst replacing these they discovered that my 2 front tyres had worn on the inside of each tyre, one of them was so worn the beading was showing.
    So I ask, has anyone else had tyre issues on their RS3, specifically wearing like this...
    *Car has done 10,000 miles. It's my family car so a lot of those miles are easy driving.
  2. Avatar
    Google AdSense Advertisement
  3. AudiNutta
    AudiNutta Well-Known Member Team Racing Blue Mica Sportback Audi RS3 quattro
    6,419
    4,098
    10,000 miles on the P Zero’s is about the expected lifespan for most people, which I’m sure most will back up... some people are seeing the fronts go after 7000 miles. Mine are on 4.5mm all around at 7500 miles, mixture of driving but the wear is definitely heavier on the inside than the centre to outside of the tread, despite proper wheel alignment.
    I’d put it down to wheel alignment out and just the amount of mileage done, change them and get the wheel alignment checked.
    What issue did they find with your pads out of curiosity? We all have squealing brakes, mine are probably used heavier than average as I drive locally, stop starting but spirited driving on such roads seems to keep them squeal free... I will still replace them for Ferrodo pads when they go though got good measure.
  4. D0C
    D0C Well-Known Member Team Nardo Team Panther Audi RS3 TTRS
    2,776
    2,532
    IIRC I did about 12k miles of reasonably hard driving and they were shot to bits. Worth getting all the alignment checked but doesn't sound a million miles away from what is expected. Even the FL is still a heavy car at the front.
  5. Hal Adams
    Hal Adams Well-Known Member Team Nardo VCDS Map User Audi RS3 Black Edition
    570
    289
    Well, if a dealer has discovered this wear but cannot give an explanation - then that is the final straw! It is basic mechanics for heavens sake!
    Inside wear is alignment, camber angle or ball joint wear. To narrow it down further, is the wear pattern sharp on one side and smooth on the other? If so, then alignment.
    sve170, DW81 and AudiNutta like this.
  6. Powerenhancer
    Powerenhancer Active Member
    158
    106
    43
    The tyres have worn on the inside fronts of every 4WD Audi I have owned, torsion and haldex based.
    Incorrect toe in is usually the main culprit, not camber, although it is exacerbated with neg camber. Neg camber on it's own is seldom a problem until the toe in is way out.
    What is the outside edge and centre depth?
    Slowracer likes this.
  7. Ellski
    Ellski Member
    55
    19
    I've been through 2 set of fronts and 1 set of rears in 14k miles.
    Found that tracking was out from new and after going to Audi twice to have the tracking done they still didnt get it right.
    Ended up going to a local European car specialist who have a Hunter 4 wheel alignment machine and its been fine ever since.
    KKOG, sve170 and Behind The Bins like this.
  8. Behind The Bins
    Behind The Bins Well-Known Member
    345
    254
    Same here
  9. XPOWER
    XPOWER Active Member Team Catalunya Audi RS3
    264
    110
    43
    I just checked my tyres and the right hand driver side one is down to the wire on the inside shoulder with the rest of the tyre not really worn that much.
    The car has only done 8,000 miles since the last tyre change which was done at 9,000 miles.
    The first tyre change had the same issue and the dealer said it was probably down to incorrect tyre pressure being applied.
    Since then I've made sure it wasn't over or under inflated.
    I have noticed a bit of a shudder at 70 mph so just thought the balance was a bit out.
    The tyres are under the Audi Service plan so I'm getting my money's worth from that.
    So when I go to the dealers I'll ask them to do a 4 wheel alignment so the tyres will last longer than 8k.
  10. XPOWER
    264
    110
    43
    Got all 4 tyres replaced with Audi Service plan.
    The dealer wanted £120 for 4-wheel tyre alignment.
    I was thinking of going to an tyre fitter to ask for a 4-wheel alignment to stop the wear on the outside of the tyre.
    Can any tyre fitter do the alignment or do I need to ask for something specific?
  11. AudiNutta
    6,419
    4,098
    Anybody with alignment kit.
    But find a place that has Hunter Alignment, it’s the best in the business and what Audi use... it’s commonly used now, can tell by the big hunter sticker in the middle of the laser bar on their alignment ramp.
    XPOWER likes this.
  12. Avatar
  13. XPOWER
    264
    110
    43
    I took the car for a wheel alignment over the weekend.
    The front was slightly out but in the green with the rear was out and in the red.
    They couldn't do one thing which I think was the camber but I could could have miss-heard what it was.
    I will keep an eye on the tyres to see if there is wear on the inside.
  14. T-800
    T-800 Well-Known Member VCDS Map User
    3,161
    3,095
    It’s usually Caster that cant be adjusted.
    No big problem.
    As long as everything else is in the green and as close on each side as possible.
    XPOWER likes this.
  15. AudiNutta
    6,419
    4,098
    Mine was all green but still shredded the inside of the tyres, 3.5-4mm tread remaining otherwise.
    Any ideas?
  16. T-800
    3,161
    3,095
    Not bothered in the slightest.
  17. D0C
    2,776
    2,532
  18. AudiNutta
    6,419
    4,098
    ... I’m a little confused where that’s come from, please enlighten
    This forum is a nightmare on times
    sve170 and Callump01 like this.
  19. T-800
    3,161
    3,095
    You asked if I had any ideas about your tyre wear
    Why would I ?
    I don’t drive your car do I ?
    I don’t know how you’ve modified your car....
    You say your alignment was in the green yet you have inner edge tyre wear on both fronts...
    If you for some reason still have an issue you need to seek professional help, all people will do on here is second guess the issue.....
  20. JamesBaby
    JamesBaby Active Member
    169
    89
    I have at least 19k miles out of my Pirreli RO2 tyres, even more on the rears. No issues on the wear either.
    I would get the alignment checked at a professional place. Just because they have a machine doesn't mean they know what they are doing. I suspect the Tow will be the issue IMO.
    Camber can be adjusted, by moving the subframe. Castor can at the least be equalised on each side.
  21. D0C
    2,776
    2,532
    That's fair enough @T-800 but I think the "not bothered in the slightest" comment was unnecessary. You probably need to change your signature details "...if Audi won't help...hire T-800" ;)
  22. Callump01
    Callump01 Active Member Team Nardo Audi RS3 quattro Saloon
    228
    203
    43
    Bit unnecessary I think with the original comment mate, he was only asking for a bit of advice which is one of the reasons this forum exists surely. :icon thumright:
  23. T-800
    3,161
    3,095
    Yeah I’ll do that.
    Better still to get my account deleted.
  24. T-800
    3,161
    3,095
    If he needs advice the he should seek a true alignment / geometry expert.
    How can we be expected to diagnose a tyre wear issue ? When he has already had it done.
    I agree with James comment above, if the car has been set up correctly there will be no issues.
  25. D0C
    2,776
    2,532
    There's clearly some underlying issue here that's making you grouchy (more than usual ;) ) but for what it's worth, I think you're one of the most knowledgeable and generally helpful guys on this forum.
    terminator x likes this.
  26. AudiNutta
    6,419
    4,098
    Ok but your comment suggested you have a bit of a problem with me, it wasn’t very nice was it.
    I’ve been to the professionals who have said they don’t know what it could be. You seemed to be well in the know, I thought I’d ask but I know better now, thanks anyway.
  27. AudiNutta
    6,419
    4,098
    That’s what the comment told me.
    The reason I asked T-800 specifically is because of his apparent knowledge.
  28. T-800
    3,161
    3,095
    Sick of reading about certain people moaning about every little issue with their car.......
    It’s not just me either, several other owners have said the same thing....
  29. Callump01
    228
    203
    43
    Gotta understand though bud, this is the internet and we're on a forum for motoring enthusiasts. We all care a lot about our cars or we wouldn't be here talking about them all the time. There's going to be people complaining here and there but it doesn't mean you need to respond to them. Just read the post and move on rather than posting a grouchy response that's no help to anybody imo :blush:
    Back on topic though, I had a similar issue @AudiNutta. I have 4mm of tread left on the front insides when I measured yesterday but my outsides are bare, so I've just ordered a set of MPS4S' and will see how they fair. I've had a ****** good offer from Michellin themselves that if they cause any issues with TC (as has been seen from others) then they'll refund me in full! Couldn't say no to that.
  30. T-800
    3,161
    3,095
    Ok ‘Bud’ I’ll do just that....
  31. terminator x
    terminator x Well-Known Member
    3,936
    4,346
    Don't go T800 some of us still like you :) we just stay away in the AM cos you are grumpiest then ;)
    TX.
    D0C likes this.
  32. T-800
    3,161
    3,095
    Sorry John I’m grumpy in the pm too......
    Am off to see if I can find an issue with the car.
    Then I can post freely.
    A_Davison, D0C and terminator x like this.
  33. Avatar
  34. Callump01
    228
    203
    43
    Cool, nice one 'bud' :icon thumright:
  35. AudiNutta
    6,419
    4,098
    Ah this forum really ain’t worth the hassle, pi**es me off every time I come on here.
    That’s the end of it, back to enjoying my holiday and updating my never ending list of issues.
    .... into the shadowsssssss :salute:
    Jonny B, sve170 and Callump01 like this.
  36. terminator x
    3,936
    4,346
    Callump01 likes this.
  37. AudiNutta
    6,419
    4,098
    Aw ain’t that sweet ;) Had to come back from the shadows to reply to that level of niceness.
    Jonny B, Callump01 and terminator x like this.
  38. terminator x
    3,936
    4,346
    Imho the two of you are both "characters" on ASN and the place is better with you here #grouphug
    TX.
    AudiNutta likes this.
  39. AudiNutta
    6,419
    4,098
    Aye who else would bring a wave of negativity if it wasn’t for me? :haha:
    Jonny B and terminator x like this.
  40. Callump01
    228
    203
    43
    All four Pirellis are now off and Michellin PS4S are on.
    Some pictures below showing the weird tread wear on just one of the tyres. Had the alignment checked and it was all green too, tyre pressures also checked and kept within the sticker spec every couple of weeks.
    Will not be going back to the Pirelli's unless they can sort out the uneven wear issues that lots of other owners are facing.
  41. Toshers
    Toshers Active Member Team Nardo TFSI Owners Group Audi RS3
    114
    92
    Wow, they are proper f*****! What is going on indeed? The PS4S are a cracking tyre though :icon thumright:
  42. Callump01
    228
    203
    43
    Yep, terrible isn't it?
    Agree with these PS4S' though - the level of grip is absolutely phenomenal in comparison to how my Pirellis were; especially happy with the wet weather performance! We should have had these fitted to our cars from the factory.
    sve170 and AudiNutta like this.
  43. Tristan2
    Tristan2 Well-Known Member Team Nardo Bronze Supporter Audi RS3 saloon quattro DSG
    627
    489
    How much are you guys paying for the Michelin’s ?
