Weird noise from my tfsi bwa engine
Bazzaquattro66
Essex
Hi I need some help as cannot work out what the problem is the timing chain had snapped so I put new chain new tensioner and new cam adjuster and all gaskets including rocker cover gasket I started it up and all sounded good then as soon as I put my foot on the throttle it made this noise I don’t know how to describe it so here is a video of it It’s like a chirping noise this is on my YouTube
So if the timing chain snapped, did you remove the cylinder head to check if the valves are bent?
He said he did a compression test and that it was all good and that the car runs smooth but I’ve bought a tester myself today just to be sure
How do you do a compression check with a snapped timing chain?
Should of taken the head off to check internals
He fitted the chain so he could do one I’m going there today to find out more can a turbo even make that noise
