Water leak through fan blower (pics)
MS3 Aug 26, 2018
  1. MS3
    MS3 New Member
    DSC08857_2.jpg Hi, I have caught a water leak in the act trying to leak into the passenger footwell. See the pictures below. I put cling film over the air filter so it is definitly coming in around the interface of the fan housing with the Plenum area.
  2. Avatar
    Google AdSense Advertisement
  3. <tuffty/>
    23,657
    5,200
    Not sure if you are just showing everyone or asking for advice but... this is common and is typically due to the plastic scuttle panel not clipping into the bottom of the windscreen properly... this means it can't seal and then water get past, drops onto the pollen filter and leaks into the fam hosuing
    There is a plastic strip glued to the bottom of the screen... this comes loose over time and moves when trying to clip the scuttle panel in preventing it from sealing
  4. MS3
    MS3 New Member
    It was a bit of both - I was showing and asking. I thought I had covered the pollen filter with cling film to prevent water getting in that way. Th.e cling film is so fragile I might put some plastic over. Obviously I am not using the blower when covering up the intake.
    That plastic strip on the windscreen you talk about is all messed up.
  5. hydro s3
    hydro s3 S3 amk Team Ming Blue Audi S3
    1,048
    272
    If you take it of and give it a good clean as a lot of **** can get stuck between the plastic and windscreen you might find it will go back on and seal for you.
  6. MS3
    MS3 New Member
    I've now given myself a bigger problem now... I've cracked my windscreen putting the rear-view mirror back on (the ball and socket joint)! windscreen_crack.png
  7. syncro
    syncro Active Member
    219
    75
    I had the same leak in the passengers footwell, I rebonded the lower strip on to the horrible nordglass windscreen and it still was not a success, in the end I made a cover from a rubber floor mat and attached it to the metal scuttle panel above the pollen filter with some rivets through the existing holes and some washers on the inside, it has been dry as a bone since then, I replaced the carpet with one from a much lower mileage car and now I have no more wet dog smell and no more condensation inside the car. I’ll be getting a brand new genuine Audi screen fitted soon
  8. MS3
    MS3 New Member
    Thanks for that info Syncro.
    I know I am going off topic but how do I tell if I have my original windscreen? This is the current (now cracked) one: windscreen_make.png
  9. syncro
    219
    75
    That’s a genuine screen, not sure if it’s a replacement or not though as the previous owners could have gone to Audi for replacement, my last one was done through my insurance by mr windscreen 3 years ago and they used a poor quality screen
  10. GeorgieS3
    GeorgieS3 Active Member
    324
    75
    I had this problem as well, took scuttle of and cleaned out the groove with a toothbrush. Loads of **** came out and the scuttle panel clicked in nicely afterwards.
    hydro s3 likes this.
  11. MS3
    MS3 New Member
    Photo0163.jpg Hi, I seem to have overcome the leak - This sheet of plastic has to be correctly placed and it has diverted the incoming water.
  12. Avatar
  13. MS3
    MS3 New Member
    On the glass itself does that number and the dots indicate when it was manufactured (i.e. 9 ...... )
    Looking around the car, the various window glass is made by the follwing manufactures: Splintex(windscreen + rear quarterlights), SIGLA(NS door), GUARDIAN(boot), SOLIVER (OS door)
