  2. Dismiss Notice
Water in spare tyre well-Avant
Mo-S3 Oct 6, 2019
  1. Mo-S3
    Mo-S3 Registered User
    859
    I was doing the wiring to a new sub install on my avant and when i pulled all the trim out under the spare tyre there was quite a bit of water sat there. Mainly under the metal reinforcement panels. Soaked it all up and dried it- must of been a good tea cup of water.
    Both side of the cubby's are dry, just the usual small stones that end up in there from the vent flaps
    So 2- days later after a rainfall the right side spare tyre area is full of water.
    Any one had any similar issues on their car and what the cause/culprit was?
  2. Avatar
    snack-media
    Advertisement
  3. Bulldog
    Bulldog Registered User
    843
    659
    93
    No idea but have you got a panoramic roof ? Maybe something with the rear washer ?
  4. Mo-S3
    859
    No pan roof and rear washer hasnt been used
  5. Bulldog
    843
    659
    93
    A friend had a pipe split on the rear wash wipe on his golf R & it completely soaked the rear of the car so could possibly be that or maybe a leak from the rear lights ? Or boot seal ?
  6. Mo-S3
    859
    looks like im going to have to give the water test....
  7. CHEZ
    CHEZ moderately amusing Supporter
    7,382
    1,673
    Be the pipe that goes through motor that carries the washer fluid.
    It gets corroded and/or the connection breaks off
  8. kjb12
    kjb12 Registered User
    13
    Wow I've just read your retrofit list, that is mega impressive!!!! I would say regarding the water in boot, check your seals obviously, clear all drain points at rear of the car, confirm the washer fluid is holding and pipework not damaged corroded. But the fact it was wet after heavy down pour suggests it be more in line with drain points and the rear seal. can you soak it up and then get the better half to spray hose onto rear of the car, starting from bottom up slowly with you sat inside boot, watching for the point where it comes in?
    Can I ask, was the high beam assist and the multilane climate difficult to retrofit? Im interested in this.
  9. Mo-S3
    859
    Thats the plan... get a water soak test done. Only bung ive found missing is a very small one on the boot floor which would defy gravity by letting in water and ending up in a higher resting area.
    High beam assist was was easy retrofit. new mirror with camera and some new wiring added. 4 zone climate was much more intense retrofit which involved dash removal, complete fan blower unit removal ( although i did without evaccing the AC system), seats removed, interior trim removed and carpet out.
    Its very doable but just a lot of work; not difficult if you know what your doing
  10. Mo-S3
    859
    Thanks, i think i will add some dye tot he washer tank and cycle it through to the rear and see if the coloured liquid ends up in the floor.
    Bulldog likes this.
  11. kjb12
    13
    Sounds like that would be a good idea.
    Right, the multizone climate. Could it be an easy retrofit to just change the control panel in the front? I just want the LCD display. Would it be a like for like swap with my current system? ( Mine is the two zone S-Line black edition ultra 2014 ).
  12. Avatar
    snack-media
    Advertisement
  13. Mo-S3
    859
    Nope,changing just the control panel will not work, even when you have CP the functions will not be recognised. Yes it works a little bit but when you need for eg full defrost on the screen you wont get it and coming intot winter you will suffer from recirculation issues
  14. kjb12
    13
    Bar changing the front panel what else would be needed to achieve full functionality then? Sorry for the off topic convo.
  15. Mo-S3
    859
    you would need:
    control panel
    4 zone heater blower/matrix box
    rear panel
    centre tunnel ducts
    underfloor ducts to b pillar vents
    new dash vents
    air quality sensor
    wiring
    cp removal & VCDS
  16. J10NMM
    J10NMM Registered User
    210
    61
    had a similar issue in the golf, turned out the rear boot seal was worn so replaced it for new and it solved it.
  17. Mo-S3
    859
    update:
    Done the heavy soak test with a pressure washer and a normal hose and nothing. Had a fair bit of rain over last 2 days and again nothing. Tried the rear washer as well and monitored it with dye and around the rear hatch- nope.
    Tyre well is still dry at the moment and still all bare.
    Plenty of rain yet to come so lets see. Sods law- i will end up putting everything back into the boot and it will get wet again
    Bulldog likes this.
  18. kjb12
    13
    Any luck with this?
  19. Mo-S3
    859
    Put all the boot back together yesterday as ive finished the sub install and its been bone dry. Nothing at all with the rain or the soak test so lets see. I will keep an eye on it
  20. Bulldog
    843
    659
    93
    @Mo-S3 any pics of the sub install ??
  21. Tim Reid
    Tim Reid Registered User
    21
    It's been a couple of months, any news?
    I think I might have a similar issue.
  22. Mo-S3
    859
    Ill report back in about a week or less as im still out of the country at the moment
  23. jetty
    jetty Registered User
    263
    75
    I may be a bit late and/or completely wrong but I had a similar issue.
    Previous owner had the fold out tow bar retrofitted. Where the crash bar used to be (now removed) there are two holes where it bolts into.
    The two rubber bungs which had been fitted in place of the bolts were letting in water.
    Worth having a look whether you have the tow bar or not, as it seems to be a weak point.
