washers and fluid?
Kingfisher Nov 1, 2018
  1. Kingfisher
    Kingfisher Active Member
    392
    90
    What fluid is everybody using? I was told (unofficially) some years ago that I should really use the VAG stuff as the workshop guys reckoned that some 'cheaper' fluid was solidifying and causing the lamp washers to clog up and blow off the pipes ( that then needed the bumper taken off to refix ! ).
    I bought quite a lot of VAG fluid some years ago and it's now running out.
    Are you guys using VAG stuff ( I have heard that it's cheaper if you buy from a Skoda dealer - hearsay? ).
    It's going in her S3 saloon and my B6 with screen and light washers.
    Her S3 has just had new screen washers as the old ones, even after cleaning, were still providing a poor wash/low flow, clogged up - and cleaning didn't work sufficiently well. Only ever had VAG stuff in though!
  2. Avatar
    Google AdSense Advertisement
  3. AlS3BE
    AlS3BE Well-Known Member
    2,061
    1,107
    Cheap screen wash coagulate and blocks everything. The other problem is the mix between water and screen wash can cause this.
    I’ve been using prestone yellow and blue one for years and not had any issues
    S32B likes this.
  4. S32B
    S32B Well-Known Member Audi A5 S tronic Coupe
    5,358
    6,225
    I also use Prestone screen wash, think it's in Costco stores to buy as well!
    I found some old ready mixed screen wash a while back (supermarket stuff) looked inside and there was all tiny black bits floating around in it!!!
  5. jassyo06
    jassyo06 Voodoo Man ! Gold Supporter Audi S3 Black Edition Porsche Voodoo Blue S3 Saloon
    17,233
    35,267
    Angelwax Clarity
  6. AlS3BE
    2,061
    1,107
    Ooooh posh stuff:wink:
    jassyo06 likes this.
  7. jassyo06
    17,233
    35,267
    Saves your headlight washer/ bumper caps freezing /clogging up/staying out, this happened on my last S3 and by doing so there's a risk of losing the painted plastic inlay
    AlS3BE likes this.
  8. Kingfisher
    392
    90
    neither of the cars do many miles - together about 8k miles so I can afford to be generous!
  9. Trevolly
    Trevolly Active Member
    193
  10. AlS3BE
    2,061
    1,107
    That’s the stuff I use. There’s a concentrate and pre mixed version. There’s also a green one that’s summer use only. On my Halfords trade card the prestone stuff was only £2.56
    https://www.halfords.com/webapp/wcs...goryId=255225&productId=1466987&storeId=10001
    Out of stock by the looks of it.
  11. Fatbloke
    Fatbloke Active Member
    245
    75
    Lidl (-60deg) 5 litres was around £6.
    Been using it for years with no probs.
    Even worked in -9 deg with non heated fan washers in my van.
  12. Avatar
  13. oli356
    oli356 Well-Known Member Team Sepang Sportback Audi S3 Black Edition S tronic
    1,662
    1,426
    Whatever is cheap lol..
    TRIPLE QX -7c All Season Screenwash (Tutti Fruity Fragrance) - 5ltr at the moment as it was £2.31
  14. Svenedin
    Svenedin Well-Known Member Team Navarra Audi S3 quattro S tronic
    696
    512
    93
    I was using Halfords stuff but it blocked my jets and they were never right even after unblocking them. I changed the jets to A6 fan jets and now use VAG screenwash (you can buy it in bulk on eBay).
  15. Audi Bairn
    Audi Bairn Moderator Staff Member Moderator Team Navarra TFSI Owners Group Gold Supporter Audi S3 saloon quattro S tronic DSG
    4,201
    5,612
    I buy two of the 5 litres containers of the Costco stuff at a time (can’t recall the brand without going out to check in the garage). No issues.
  16. HertS3
    HertS3 Active Member
    245
    74
    It's Prestone (the blue stuff), I use it too and changed the washer jets (as per Svenedelin's useful tip) to those from A6 so got a nice mist now and so easy to adjust (turn with a Torx 9 I believe)
    Audi Bairn likes this.
  17. Audi Bairn
    4,201
    5,612
    That’s the stuff, and smells good too!
  18. Sparks43
    Sparks43 3rd Gear
    405
    122
    43
  19. SamR92
    SamR92 Well-Known Member Team Floret Silver Sportback TDi Audi A3 S-line owners group
    454
    428
    What’s the dilution ratio for that stuff? and is it suitable for winter use?
  20. Sparks43
    Sparks43 3rd Gear
    405
    122
    43
    Hi the dilutions are on the bottle - yes fine for winter 1 to 1 if I remember right - I usually top up with half a bottle and winter just pour a whole bottle in
    I tend to top up when car washing rather than wait for the low fluid light
    SamR92 likes this.
  21. HertS3
    245
    74
    Can't believe it - car just came back from Audi Watford (after spending a whole week trying to program an air bag!) and they advise that the windscreen wipers need replacing (quoted £50) - the Bosch AeroTwins I put on were about a week old when I put the car in!! Surely they can't have looked at them otherwise they'd see they were brand spanking new!
  22. Flowrider99
    Flowrider99 Active Member Team Mythos Supercharged TFSI Owners Group Team V6 Sportback Audi S5 Black Edition quattro S tronic
    303
    134
    43
    I use Halfords concentrate, never had a problem with blocked washer jets. In the past i have used anything cheap and not had any issues.
    Philip Davies likes this.
  23. Svenedin
    696
    512
    93
    For th
    For the VAG Screen wash concentrate:
    -70C Use Neat
    -40C 2 parts screen wash +1 part water
    -35C 1 part screen wash +1 part water
    -16C 1 part screen wash +2 parts water
    Summer 1 part screen wash + 4 parts water
    So for UK Winter use 1 + 2 parts water unless Armageddon hits us!
    Audi Bairn and SamR92 like this.
  24. Carefree69
    Carefree69 Well-Known Member
    720
    515
    93
    FFS people, it’s just another marketing ploy, “you should only use VAG screenwash otherwise your washer jets will get clogged up”.
    I’ve had VAG cars for the last 20 years (Golf, Fabia and two A3’s) and I’ve never used the VAG screenwash and have NEVER had any issues.
    I’m amazed that people still fall for that cr@p:laughing:
  25. Svenedin
    696
    512
    93
    Nobody is actually saying you have to use VAG screen wash but there is no doubt that certain screen washes DO block the jets. I have used Halfords screen wash in all of my cars over 30 years of motoring and I don't recall the jets ever blocking until my S3. If they do block it is a tedious chore trying to unblock them and in my car after 2 goes at unblocking them they were still not right so I changed them for A6 fan jets and decided I would use the VAG screen wash because I haven't got time to p**s around. If you have headlight washers as well and they block and either get stuck or blow a pipe off good luck with that. Of course there are other screen wash choices, take your pick.
  26. Carefree69
    720
    515
    93
    My post was referring to the OP’s comments about being told by “workshop guys that non VAG washer fluid can clog up the jets”.
    I didn’t say that anyone here had said it.
  27. Svenedin
    696
    512
    93
    Well the VAG stuff is good, it is true that non-VAG stuff can clog the jets and they are bound to recommend that. They are hardly going to have a list of washer fluids they think are OK. That's asking a bit much.
  28. Carefree69
    720
    515
    93
    Of course not, but to say that ONLY vag washer fluid should be used is frankly rubbish.
    I remember being told the same thing by a dealer when I purchased my first vag car (VW golf), and suffice to say I ignored the advice and my washer jets worked flawlessly in the 3 years of ownership.
    Fatbloke and AlS3BE like this.
  29. Damo S
    Damo S Active Member
    306
    118
    43
    My washer jets are utterly *****. Fitting A6 ones sounds like a plan, good call!
  30. Svenedin
    696
    512
    93
    They are a direct swap. No tools needed and very easy. There are several threads about it on the forum and part numbers. Cardiff Audi sells on eBay
  31. scoss
    scoss Active Member
    574
    190
    43
    Mine were realigned last month, however I’ve noticed the middle jet on the right is too powerful and this water is just bouncing off the screen and over my car. Waste of water def. will look in these A6 jets! I had an Merc A class last month and the only thing I liked about it (160D) were the jet washers!
  32. Sparks43
    Sparks43 3rd Gear
    405
    122
    43
    I changed mine last weekend to the A6 ones - So much better
  33. Avatar
  34. Svenedin
    696
    512
    93
    Yes, they are much better. Amazing how a small detail like the screen washers can irritate and annoy. I really hate dirty windscreens-it’s a safety issue especially at night.
  35. Sparks43
    Sparks43 3rd Gear
    405
    122
    43
    I know but what annoys me is that they have these A6 ones which are a straight fit and easier to adjust so why don't they just fit them anyway and do away with the other ones - I can't see them being much more expensive than the pistol ones
  36. Ormesome
    Ormesome Well-Known Member TDi quattro S-line owners group S tronic Q2 owners group
    1,290
    822
    My Q2 has the spray ones so must be the same as the A6. I never understood why people cared so much about changing the wiper jets but its so much better. The A3 had the normal ones but the Q2s are way better. cover more area and. just more effective. Defo worth an upgrade.
  37. Fozzer
    Fozzer Member Team Navarra TFSI Owners Group Audi S3 Black Edition Navarra Blue Classic S3 Saloon Saloon S tronic
    84
    35
    Sonax Xtreme Clearview Screenwash for me.
    Anyone got a link for the A6 jets to fit a S3 8V please.
  38. Sparks43
    Sparks43 3rd Gear
    405
    122
    43
    The link doesn't work anymore but part numbers listed below:
    Audi A6 Right Heated Front Washer Jet 4G0955988A
    Audi A6 Left Heated Front Washer Jet 4G0955987A
    My mate works at Audi so cost me £18.60 for the pair with discount - so assume will be about £22 - £25 retail - Parts on here might be able to supply them - Cardiff Audi are usually good in their ebay shop as well
    Fozzer likes this.
  39. Fozzer
    84
    35
    Thanks Sparks, appreciate your help.
    Will these fit the S3, mate as I don’t think mine are heated
    Thanks again.
  40. Sparks43
    Sparks43 3rd Gear
    405
    122
    43
    Hi mines an S3 and they are heated as standard so will fit perfectly
  41. Fozzer
    84
    35
    Thanks for quick reply.
  42. Fozzer
    84
    35
    Presume when referring to left and right washer jets it’s as looking from the front of the car
  43. Phutters
    Phutters .
    239
    270
    Nope. It's from the driver's position. The ones you replace are marked anyway - just swap like for like.
    Fozzer likes this.
