Washer jet upgrade?
foursprungdwarf Feb 15, 2015
  1. foursprungdwarf
    foursprungdwarf Member
    70
    Is there a direct replacement upgrade for the front washer jets?
    Was thinking non heated but a fan type spray.
  2. Avatar
    Google AdSense Advertisement
  3. Marc B7
    Marc B7 Active Member TeamMisano TFSI Owners Group Audi A4 Audi Avant Owner Group Black Edition quattro S-line owners group
    131
    82
    LloydB7 and foursprungdwarf like this.
  4. SamFishlock
    SamFishlock Member
    I must get round to doing this, much better coverage. Looks better too.
  5. foursprungdwarf
    70
    Excellent, thanks
  6. SDHA4SLine
    SDHA4SLine Well-Known Member Team Silver Audi Avant Owner Group S-line owners group
    2,631
    525
    Nice, was looking for my next quick and affordable upgrade. Think I've just found it :)
  7. Just Rob.
    Just Rob. Moderator Staff Member Moderator Team Daytona Team Brilliant Black TFSI Owners Group VCDS Map User Audi A4 Audi Avant Owner Group quattro S-line owners group Manual
    8,462
    4,533
    me too, nipping down to my local VAG tommorow morning to get them, hopefully fitted before window tint man comes to do the glass on wed, oh yes the mods have begun now.:D
  8. SDHA4SLine
    2,631
    525
    Seems these are heated jets, can these be retro fitted to non heated original system?
    The standard jets are 5M0955985C9B9 at around £12 each heated one £25 each
  9. SDHA4SLine
    2,631
    525
    Only just noticed these are jets, are there any mist ones about, other than the Passat ones that need gluing in place :eek:
  10. foursprungdwarf
    70
    The heated ones are mist/fan type, I assume they can be used unheated.
    No need for gluing with the shims.
    ** Edit - Oh, I see... Same fan spray but unheated are half the price, result. **
  11. Just Rob.
    8,462
    4,533
    before i start ripping the old jets of etc, i want to order the vw ones, but is the indentification obvious for heated audi or non heated items on my a4.
    rob
  12. Avatar
  13. imz
    imz Member
    344
    17
    How are these spray fans fitted? Is there a guide and is just unplug one and plug the other?
    Thanks guys
  14. jdp1962
    jdp1962 Grumpy Old Man TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 Black Edition quattro S tronic
    9,081
    3,678
    Click here for a thread on how to fit. One caveat though. Since this guide was published, Audi now supplies an adapter shim that bridges the gap between the VW part and the aperture in the Audi bonnet, so no glueing required.
    Details of the adapter shim can be found in here.
  15. SDHA4SLine
    2,631
    525
    see post number 2,
    did you find out about this rob or is it a case of just popping them off to see if they have an electrical connection
  16. Just Rob.
    8,462
    4,533
    no, i meant to have a look this morning but completely forgot about it as i had the window tinting man around to do the avant, looks nice now......................:cool::cool::):):):).
    going to get clafication in the morning , i did speak to audi about breifly though and gave them the chassis number, they said it did have heaters, but i thought i double check myself.
  17. jdp1962
    9,081
    3,678
    If the jets are heated, they'll have an electrical connector as well as the water pipe. The part number for the heated Passat fan jet is 5M0 955 986 9B9.
  18. imz
    imz Member
    344
    17
    I have just done the washer jets but only after taking them off I had an electrical connector so assume it's heated versions I have??
    Ignore me just read post above. Anyone want to buy none heated versions?
  19. ANDYTQ
    ANDYTQ Well-Known Member
    1,186
    106
    Bought mine today,should fit tomorrow ☺
  20. SDHA4SLine
    2,631
    525
    Having established mine are heated type jets, out of curiosity I wondered if someone can advise when the heating element comes on? And for that matter when do the heated mirrors come on :confused:? I've always assumed mirrors where on when the rear window de mist was activated?
  21. jdp1962
    9,081
    3,678
    Mirrors are definitely heated when the heated rear window is on. Not sure but I think the washer jets are heated permanently.
  22. SDHA4SLine
    2,631
    525
    Only when ignition is on I hope:eek:
  23. jdp1962
    9,081
    3,678
    Sorry, yes.
  24. ANDYTQ
    1,186
    106
    Did mine today only took 5 mins,so much better.
  25. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    OMG! When did they start producing shims for these!? :chargrined: I ended up holding mine in place with epoxy putty and went over with a black paint pen to make it less obvious.
  26. jdp1962
    9,081
    3,678
    Me too, Azeem. Anyway, get 'em ordered and get 'em on. Best £2.26 you'll ever spend. :)
  27. dt-tdi
    dt-tdi Member VCDS Map User
    200
    20
    Will this slot straight into an A4 or does it require the shim as well?
  28. SDHA4SLine
    2,631
    525
    As I understand it they will fit without shims but need silicone sealant or similar to hold in place. Shims are only a few pounds, worth buying I think :thumbs up:
    dt-tdi likes this.
  29. SDHA4SLine
    2,631
    525
    Anyone know what the small allen key nut next to the nozzle on these upgraded Jets are for? I'm hoping its to adjust the angle of spray up and down as mine is fine when at slow speeds but at high speeds the jet just sprays the bottom of screen :(
  30. jdp1962
    9,081
    3,678
    Yes, that's exactly what it's for. :thumbs up:
    SDHA4SLine likes this.
  31. gary_a4_quattro
    gary_a4_quattro Active Member Team Meteor Team V6 Audi Avant Owner Group
    594
    186
    43
    A much better way of adjusting the jet direction than ******' about with a pin in the nozzle itself :mad: !
  32. jdp1962
    9,081
    3,678
    Careful you don't end up washing the windscreen of the car behind you. ;)
  33. Avatar
  34. SDHA4SLine
    2,631
    525
    Now that's one thing I do like... If a tailgater is too close I just hold down the washer button. Especially funny if they're a boy racer with a freshly polished car :lmfao:
    jdp1962 likes this.
  35. ESD1711
    ESD1711 Active Member
    691
    219
    43
    Maybe also worth noting that I think the part numbers for the washers are a Skoda part also if that's any easier for folk to get a hold of...... they can actually be foundon ebay if you punt in the part number as a search :)
  36. Darrenkellum
    Darrenkellum Active Member
    176
    35
    Posted this in the affordable mods section but thought worth copying here -
    Annoyingly bought a pair of fan spray non heated washer jets from Shop4Volkswagen when I needed heated. If anyone wants a non heated pair, PM me and I'll post. £20 for the pair.
  37. SDHA4SLine
    2,631
    525
    have you advertised them in the classifieds on here? may stand more chance of selling them if you do
  38. Euans2
    Euans2 Active Member Team Brill Red TFSI Owners Group Sportback Audi A3 S-line owners group MQB Platform Manual
    261
    47
    I've just done this upgrade to my car but even after adjusting them they are still hitting the bottom of the screen. i think I'll have another look at them today seeing as it's not raining
  39. SDHA4SLine
    2,631
    525
    Did you like I me not transfer the 90 degree elbows from the old jets to the new ones?
    I had the same problem until I realised I should have done this. I assume its because without them the direct fit of hose puts strain on the jets which pulls them ever so slightly down. Also the spray is much more of a mist now than without the elbows fitted
  40. SDHA4SLine
    2,631
    525
    this is what I mean by 90 degree elbow
    Also do you have your shim positioned as below? (by the way this is not a picture of my car!)
  41. Euans2
    261
    47
    Thanks for the advice. I have the 90 degree elbows fitted but I'll need to check how I've got the shims fitted this afternoon.
  42. Euans2
    261
    47
    Problem solved, I had the shims on the wrong side, thanks SDHA4Sline for your help
  43. Ewan Hoozarmi
    Ewan Hoozarmi New Member
    Thanks to all who have posted on this thread.
    Got my VW fan versions today and fitted them in 10 minutes flat. It was the fact that Audi now sell the shims that swung it for me. Certainly improved my B7 Avant.
    Now all I'm waiting for is the brushed silver gear surround and a new gear knob. Should do me on the mod front for a while....
