  2. Dismiss Notice
VR6T 24V Question HELP!
cstmn Sep 13, 2019
  1. cstmn
    cstmn Member
    50
    10
    Hello guys. I want to swap a 2.8 vr6 golf engine mk4 4x4. I want to ask if everything fits into the engine bay of the S3 8L ??? I'm thinking of putting a R32 BUB head too? And how are things going to install a turbo kit on it?
  2. Avatar
    snack-media
    Advertisement
  3. Tj 0785
    Tj 0785 Well-Known Member Silver Supporter VCDS Map User Bronze Supporter Audi S3
    3,279
    946
    It fits a few mods need doing, need the v6 gearbox aswell, I’m doing the 3.2t swap and tuffty has done the 3.2 swap already and is also looking to turbo install as-well look at his build page for for swap info and be warned turboing the 3.2 and doing the engine conversion is expensive
  4. Tj 0785
    3,279
    946
    Also you don’t want bub engine that is mk5 you want the mk4 2.8,mk4 r32 and tt 8n 3.2
  5. cstmn
    cstmn Member
    50
    10
    I want to buy 2.8 bde and put a r32 head. I read inet information that the head of the R32 matches 2.8 block ?? This is my idea ???
  6. cstmn
    cstmn Member
    50
    10
    what kind of manual gearbox do I need exactly???
  7. Tj 0785
    3,279
    946
    The one from a mk4 Quattro as long as it’s from one of the cars above
  8. Tj 0785
    3,279
    946
    What power are you hoping to achieve
  9. <tuffty/>
    23,969
    5,360
    Mk5 engines are direct injection (TFSi) so not really suitable ... As TJ said... use a Mk4 chassis car head/engine if you really feel the need too... they are port injection
  10. baliszoft
    baliszoft Member
    41
    22
    BUB is still port injected.
  11. <tuffty/>
    23,969
    5,360
    BUB appears to be the 8P 3.2 engine so yeah... good spot :)
  12. Avatar
    snack-media
    Advertisement
  13. Daniel M
    Daniel M Active Member
    267
    79
    I’ve got a 3.2 V6 engine for sale at the moment if anyone’s interested.
  14. cstmn
    cstmn Member
    50
    10
    400hp
    Okay thanks .. is it plug & play with 2.8l engine from mk4 4motion? Or find a 3.2l engine from A3 8P with manual gearbox but ?? How things are with the ECU ??
  15. Tj 0785
    3,279
    946
    2.8 will work and will be cheaper than a 3.2 block You need to use ecu from the car you get the engine and and a manual boost controller and use maf readings so the ecu won’t see boost or go standalone ecu and fit a n75, all depends how much you want to spend, you will need to fit a head gasket spacer, info I found says you don’t need forged rods till Around 450bhp but I’d do it just for peace if mind, what turbo you planning on using? Also 400bhp you can still use the plastic inlet manifold, then there’s the clutch you will need something better than standard, same with engine mounts
  16. cstmn
    cstmn Member
    50
    10
    Wow.. many thanks for the info you need dude :)))
  17. Tj 0785
    3,279
    946
    That’s just the start of it there will be a few problems to over come on the that you will find , when you looking to start it
  18. <tuffty/>
    23,969
    5,360
    Not sure what injectors are available for the 2.8 heads... the design is different to that of the 3.2
    The 2.8 (also the same as the 2.3 V5 engine)
    ...and the 3.2....
    The 3.2 follows a more 'normal' bosch style injector and I am using a set of Bosch 630cc versions of these (with the long nose)... the 2.8 injectors have a double seal setup so not sure what is available thats a larger flow rate..
    I did flow test the 3.2 injectors just to see what they were and from memory they were 230cc at 3bar... the 3.2 has a 4bar fpr... I swapped to a 3bar FPR for the 630's I am using
  19. killfame
    killfame Active Member
    169
    70
    What about the head ports inbetween both heads 2.8 and 3.2 ?
    The question is
    Why they do this head swap, they put 3.2 head on 2.8 just for the stroker and because the in/out ports on 3.2 head looks more promising?
    What about the ECU adaptation to work with the turboed setup
    -How that works ? Or it’s info that only a Mapper needs to worry about...
    How to make all the electronics works together, maybe its non neccesarry to know, but it’s interesting thing to know here in the forum to get more in depth info about it..
    Inet is full of 3.2/2.8 swap threads, but no one explains certain details that are very important in this kind of Engine upgrade/swap
  20. <tuffty/>
    23,969
    5,360
    3.2 ports are larger iirc...
    ECU will need mapping to recalibrate injectors, timing etc for the hardware changes... I believe the 3.2MAF tube is larger but tbh not spent too much time looking into the 2.8's as I was always going to go 3.2...
    The engine itself is pretty much bolt in... there are subtle changes to things like the coolant lines, PAS lines etc but if you have a 4-motion donor car then you can more or less lift and shift...
    You will need to use the 4-motion looms if using the OE ECU... As I was using Ignitron ECU I just got away with using the smaller ECU plug loom (from a 3.2 TT) and added in the wires I needed and removed ones I didn't... made the conversion much easier but bare in mind IECU is a single lambda ECU currently so I only have one lambda in use... not ideal but as I will only need one for going turbo its fine for now...
    I have documented a lot of this in my build thread...
    cstmn and killfame like this.
