Video in motion
serhat yildiz Jul 3, 2018
  1. serhat yildiz
    serhat yildiz Member
    43
    Hi guys how would i go about installing this i jave an a7 c7 2012 without the techpack so no simcard slot?
    Sent from my SM-G955F using Tapatalk
  2. Avatar
    Google AdSense Advertisement
  3. RJ-8V
    RJ-8V Active Member Team Daytona Audi A3 S-line owners group
    589
    149
    43
    But do you have a MMI Plus? Then it can be enabled with vcds.
    Verstuurd vanaf mijn SM-G925F met Tapatalk
  4. serhat yildiz
    43
    Mmi plus?
  5. RJ-8V
    589
    149
    43
    Do you have harddisk and touchpad?
  6. serhat yildiz
    43
    No got the dials nd sd card based nav
  7. RJ-8V
    589
    149
    43
    Can you post a picture of your mmi
  8. serhat yildiz
    43
    Here[​IMG]
  9. serhat yildiz
    43
    ...[​IMG]
  10. RJ-8V
    589
    149
    43
    Video in motion is possible, but you need an AMI cable with video capabilities.
    You have RMC system, not a "full mmi" .
  11. serhat yildiz
    43
    But i done have an insert for the ami cable where will that go?
  12. Avatar
  13. paultaylor
    paultaylor Active Member
    392
    25
    I have touch pad and large screen with SIM card for data. My A6 is the 2015 facelift.
    A friend has Vcds.
    Any tips on where to enable video in motion?
  14. RJ-8V
    589
    149
    43
    Can't be done with vcds m facelift need s vcp
  15. DJAlix
    DJAlix VAG Car Coding Site Sponsor Team Ibis VAG Can Professional VCDS Map User Gold Supporter quattro ODIS (Offboard Diagnostic System)
    4,580
    3,733
    As Mr RJ says. If you are able to get to north London I can activate this for you.
  16. serhat yildiz
    43
    Hi djalix where in north i work in holloway
  17. serhat yildiz
    43
    Can you do this for me also?
  18. DJAlix
    4,580
    3,733
    I am based in Muswell Hill, not far from you :)
  19. serhat yildiz
    43
    Thats great can it be done on my rmc system also?
  20. DJAlix
    4,580
    3,733
    Yes however the RMC systems will only play video via an AMI connected device and not from the DVD drive or SD card slots. What does this mean? Using an iPhone with a lightning connector as as example, in order to view video media you would need the following:
    • AMI (audi music interface) to RCA Cable
    • Male to Male RCA adaptors
    • RCA to HDMI convertor box
    • HDMI cable
    • Apple lighting to AV cable
    You would then also need a 12v to USB x2 socket so you can pour the HDMI box and the Apple Lighting to AV cable.
    Basically, in this example, Apple devices with lightning connectors only output digital video. Audi does not make a digital video cable or interface so you need to add the smarts and convertors in the middle. Seems like a faff but all the above should only cost you £80 max (without the cost of the VIM activation from me) and it will allow you to play video and even mirror your devices screen so you can use youtube etc. The main benefit of doing this however is that you could mirror apple / google maps or WAZE to your MMI screen and get cheap and up to date navigation :)
  21. serhat yildiz
    43
    Ok gota sorce these from ebay i suppose nd den you jst need to activate it?
  22. DJAlix
    4,580
    3,733
    Correct. You can source from eBay / amazon and once everything is connected you will; be able to video media which the vehicle is stationary. You will need the Video in Motion activation in order to video while the car is moving. Just a note, some of my customers opt to use a google chrome cast or amazon fire stick so they can stream wireless :)
  23. serhat yildiz
    43
    Ok nice mate i will order these tonight but again where does the ami cable slot into cause i cant remember seeing anything in the glove box
  24. DJAlix
    4,580
    3,733
    You should have an AMI socket in either the glovebox or in the armrest.
  25. paultaylor
    392
    25
    Even though I have google earth and 2018 maps on my MMI plus I’d still like to get Google maps from iPhone working on the screen
    I’ll check out this solution
  26. DJAlix
    4,580
    3,733
    You might only have USB ports with your system as opposed to an AMI port. If this is the case then the above will not work.
  27. serhat yildiz
    43
    I will check thoroughly tonight before ordering mate can i get your number thru pm i could whats app you and come see you on a sunday or something
  28. DJAlix
    4,580
    3,733
    VAG Car Coding - 07950 737 899 - hello@vagcarcoding.com
    Sunday I am exhibiting at VAG Tuner Live 2018 all day. I do offer daytime and evening appointments during the week though.
  29. serhat yildiz
    43
    Cheers mate i will get in touch during the week
  30. serhat yildiz
    43
    Just noticed i dont have an ami insert is that possible?
  31. DJAlix
    4,580
    3,733
    Totally possible, not common but I do come across systems which have not been spec’d with an Ami port.
  32. serhat yildiz
    43
    Well thats out the window is there a fix?
  33. Avatar
  34. DJAlix
    4,580
    3,733
    Might be possible to retrofit the AMI. RMC is different to MMI for retrofits and I would need to do some research in order to know what’s possible. Someone else might know different.
  35. serhat yildiz
    43
    What a ****** i was so excited for it too
