BenKH95
I posted a few months ago regarding a clunking/knocking noise from under my car (TFSI Quattro), I had it diagnosed at a local specialist as the rear diff and had that changed. The noise then became a constant vibration under acceleration up to around 40-50mph, relative to the amount of torque applied. I had my old diff looked at and it turns out it was fine all along!
I’ve had the car looked at by a transmission specialist, he can’t pinpoint the cause of the noise. I’m convinced it could be my propshaft centre bearing as there’s a decent amount of play in the bearing and some of the rubber looks perished/cracked. He says it isn’t this as the noise can’t be heard when driving the car in the air on a two-post ramp - surely there’d need to be some load/weight on the car to replicate the symptoms?
My questions to you guys:
- Has anyone experienced similar issues with vibration under load at low speeds/gears?
- Was it the propshaft centre bearing?
- If so, how is it replaced? It looks like the propshaft is all one piece, I’d rather not buy a second hand one in case it happens again
Cheers guys
Cheers guys
